Mk2 4wd 16vt Bready
i Plan it but then modify stuff to suit as i go along normally but sometimes i do just make it up out of my head lol
  • Replies 1k
  • Views 110.9k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
Best way ;) I might hit you up if you fancy machining some bits for me ;)
I usually use a company work uses and get bits on the side but he takes forever and is very unreliable. Do you prefer replica's to make from or Solidworks drawings?
Edited by Mattnaz
I can work from whatever mate prefer a replica as its easier to hold and visualise but no real bother either way and yeah anything you want send me a pm me and we can sort it out mate
Highly reccomend petes machining work to anyone, I've had a few bits along with 90 percent of my running gear off him. Top lad to deal with, reccomended seller/fabricator haha.
*stops blowing smoke*
A deal shall have to be struck then with this sort of feedback ;) Ill hit you up as and when Pete cheers!
so on friday lunch at work i bent the front bulkhead brace that will also support the front of the tranny tunnel
Tacked in place
then made some b pillar main loop to rear sus braces
b pillar to rear diff cross brace
Then started on the front space frame and have got alot of it planned out just need to buy more tubing this week to get alot of it done over crimbo
also took the windscreen out trying to do it carefully without damaging the the seal as its a genuine vw that cost me £50 odd last year and cracked the f'ing screen which was also brand new last november :( so i kicked the fucker out so i can get to more places around the front easier now and gusset the side of the windscreen a pillars to the front cage
thats this weekends work and slowly building up alot of work to do over the holidays
Good progress pete.
Cant tell where half of that is haha, looking forward to seeing the final finished car!
Reply to my sale thread by the way.
how can you not tell where the bits are lol your not properly following the build then :0 nah only messing
Its a right mess in the car atm because I'm just getting on with bits and not tidying up much after so il take some better pics through the windscreen hole of all the back end inside of the car next weekend
Lol sorry mate
I cracked my screen too, went mental!
Regarding the tube bending, did you pack it with sand! haven't even tried mine yet...
nope haven't tried packing it with sand yet just getting better at it now tbh but that is quite thick walled tubing so i might pack the thinner wall tube with sand to stop that deforming a bit
the annoying bit about the screen is I've gotta pay £80 to replace but i will wait til the cars roadworthy as it saves me having to store it and at least i dont have to find somewhere to store the once i just smashed either now
right finished removing all of the soundproofing off the bulkhead tonight fook me there was alot and it weighs alot too tbh so should have saved a fair bit of weight getting rid of all that also started marking bits out for where i need to get the grinder on it :) next week holidays should be good as I'm also aiming to get all the back end or most of it stitch welded and get alot more of the front frame done its coming along finally
also bought some more eccentric alloy spherical bearing top mounts off ebay today that i will modify and use for the new front turrets
and nearly finished refurbing my transfer box just waiting on one more bearing to turn up so i can press it in and then i can reassemble same as the gearbox this weekend :)
no pics but tough luck :p
X2
Loving the alloy work peter :thumbsup:
Edited by Mclovin
I had a look at that thread Nick pretty good until the get to the end and the updates stop and no finished car :(
anyways around work, family and shopping I've managed to get a few bits done on the polo finally
Transfer box rebuild basically finished
then thought i would get the grinder out on the car again and ended up with this :/
view from inside the car
then thought i would lighten my standard bonnet for something to do in a bit of spare time i had
Also popped to my new Local Euro car parts where it turns out i know a few members of the staff :)
came away with a new headgasket for when i fit the decomp plate £15 and also some 256mm vented discs for the rear
I have my own little scrapyard too i think half of my polo is outside of garage :/
Edited by StinkyPete
neatened up the floor on either side
made some vertical braces for the front spaceframe rails
new toys
Stitch welding attachment for my ARC welder
60 LED Rechargeable light
new 1/2 ratchet to replace my good one thats disappeared :/
Alloy eccentric spherical bearing top mounts for the front
Today around fixing my mums car i managed to make the diagonal braces for the front spaceframe rails
also used my new wire knot wheel attachment for the grinder today and cleaned loads of seamsealer/mastic off the front wheel arch inside the car ready to start stitch welding all the seams
view of the inside front of the car
view of the back from the garage door also cleared alot of shit off the roof of the polo too today so just the fuel cell, slam panel and some wiring and seals on the roof now.
enjoy more work being done tomorrow and saturday
Why have you cut that huge hole into the engine bay?
I'm getting rid of the battery tray area and it gives me more access for what I'm doing atm you will see later on once the front space framing is finished it will all make sense then
because racecar?
lol. i was also gonna ask
obviously the SMOOTH look is what I'm going for ;)
This thing actually amazes me, Hats off to you Pete
I remember all but a while ago when you were at Santa Pod and you asked mine and a few others advice on what to do next as you had built not such a safe place for the tank in the rear, Now this is miles apart, superb work, keep it up, I look forward to seeing the front frame take shape.
Glad it does Dan i dont want a normal build or one thats the same as alot of other peoples i want it one of a kind and i have most of the skills to do the work so why not show off everything i can do
and at the Pod last year i wasnt planning on taking it this far not even close really i was just going to roll cage it and maybe eventually turbo it and i would be done
The 4WD came as a spur of the moment thing more so when people told me the box wouldnt fit to the afh block so i had to show it could be done and managed to get a box and rear diff at a very good price
then the rest of the ideas started to form and come together
It really is inspiring mate, keep it up.
omg this thread is AUSOME keep up the hard work with what will be a very noce car when finshed
There is a lot of fibreglass behind the rear right hand door card (looking from front) I take it that was for your rear arches?
