Mk2 4wd 16vt Bready
In regard to your ITB manifold, how do you plan to shape tubes from the clover shaped holes to a normal cylinder for the itb boots?
  • Replies 1k
  • Views 110.9k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
Wait and see Dan I'm not shaping any tubes I'm making it complete from that billet ;)
And Si I more than likely couldn't do your block as you won't have the castings to machine in it
Mine does because it is an AVY block basically
That seems impossible to make it entirely from that billet as the bodies wont line up exactly surely? and now you have drilled the clover shaped holes you cant offset that into a smaller hole for the bodies?
Edited by higgo
It will flow mate don't worry all the port machining is done just a little port matching and that side of its finished
Just need to machine all the excess material off now
Dan I'm guessing you've got whatsapp add me mate and il send you pictures before I upload them on here this weekend so you can see
Edited by StinkyPete
so i have finished the majority of my new ITB manifold just need to machine all the excess material off it to save weight and make it look prettier
The manifold so far
will hopefully get on this and machine the excess material off in the next week or so
also drilled the block for fitting the mk3 shallow sump as this block usually runs an alloy sump and they are slightly wider that the steel ones and so the bolt holes on one side are different
but easily fixed for me ;)
the difference
the new holes drilled
while i was up in Sheffield this weekend i popped over to Leeds to a compant called Mount Panels to collect my new old stock front panel and slam panel
got them seriously cheap so not too much i need now front panel wise as i should be getting some standard wings to modify soon off a good old Guy on here
managed to do some work on the polo as well today when i got back
i now have the passenger main door bar in to protect the passenger and make the shell more rigid on thats side
thats all for now but more to come this week
hope you enjoy ;)
Excellent work Pete! i like to look at the machining you do :thumbsup:
Was good to see your work in the flesh Pete! Also it was nice to meet you. Hopefully again sometimes soon! (y) keep going!!
Lucky! You got a slam panel. Was that listed on ebay too?
yeah i dont actually need a slam panel as i made mine bolt in but as i want the front end removable i thought i could use a new one to do it
and yeah he has a few on ebay left not bad either at £40 mate
Juat had a browse, didn't see them the other day. I was up there today, but I don't really need a new one. I butchered the bottom of the bracket where it's spot welded to the lower valance, but I think I'll just ask my brother nicely if he would weld a little bit on for me :-)
Just had a browse, didn't see them the other day. I was up there today, but I don't really need a new one. I butchered the bottom of the bracket where it's spot welded to the lower valance, but I think I'll just ask my brother nicely if he would weld a little bit on for me :-)
I'm probably gooing to chop that bit off anyway
i want it so i can make the front of the car bolt off and removable so i can work on the engine real easy or if i need the engine out for reasons its easy peasy
i was thinking about making the front end panels into one piece so its like a flip front mini they can be removed in a oner like american hotrod racers
but not sure yet il see when i get to it
Exactly what I'm going to do. Was just going to have around 4 bolts holding the valance on, 2 bolts bolting the slam to valance, then 2 more attaching the slam to the 'wings'
Good progress,
Is the non-matched ports not going to cause issue pete?
Nope it will flow Max I haven't finished fettling with the port matching yet
right well heres an update of progress from this weekend feels like i got quite a bit done too
saturday morning the car inside started like this
and i had all this ready
so work began
tunnel bottom lengthway braces
rear bottom braces around diff front
Tunnel top lengthways braces going in
rear top tunnel braces above diff
tunnel vertical supports rear and mid
Tunnel bracing all fully welded in
Also lowered the chassis onto the new chassis dolley i made so it is now movable and can move it in and out the garage
will be nice in the good weather as i will be able to work on it outside on the driveway
also made a little quick start on sorting the rear old floor pan out
removed all the seam sealer ready to drill out the spotwelds to remove
i have now started on the rest of the front frame starting with the front bottom tunnel bracing that the bottom engine chassis frame will mount off
finally worked out a plan of action and design for it tonight and started bending the two tubes for the front bottom tunnel bracing
its really starting to come together now
enjoy
Wow ..
Your gonna be fucked if you drop somethign in the rear when its complete ;) lol
Looking good though :)
Fancy making me a rear cage ;)
The floor pan isn't on yet lol it will be open plan so to speak
Just need to finish the front, get engine and gbox into right place to sort mounts
Then I can get in on a roll over jig and do all the floor pan and rear arches
Mental! Looks like the Eifel tower in there!
hope thats a nice complement Simon lol
quick update new sills arrived
and heres some pics of my Audi TT quattro 6 speed 02M gearbox ;)
then some of the front fire wall and the front bottom braces of the tunnel in the making
gearbox on the floor in rough place in engine bay
loads of room
supposedly the 6 speed gbox is 25kg's heavier than a 5 speed i honestly dont think there is that much of a difference
plus its shorter so will fit in the bay better just need to sort some driveshafts now :) then can get front wishbone mounts sorted and engine mounts done
can we nickname this project cobweb? haha awesome :)
Ahh so youve gone for the 02M now, good choice ;) Might make mine a 6speed when i get an LSD.
yeah i got the gbox quite cheap its not a direct fit some modification is going to be required but i wont be machining the bell housing this time around to keep all parts standard and easily replaceable
may need to mod the block a little but I've already done alot of modding on that anyways so no biggy
6 speed 4wd it is just need a shifter tower and the rest of the cable end linkage bits for the box as not all of them come with it :/
Go to a scrappers mate
