Mk2 4wd 16vt Bready
Thanks guys appreciate the positive feedback
il be going to get some more tube tomorrow to make a bolt on front lower brace to sit the rad on and also put an engine front steady mount on like in mk1 and 2 golfs for extra engine support
will also start making the mounts for the front panel to bolt on
  • Replies 1k
  • Views 110.9k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
I bloody love this thing!
Looks good Pete since I last checked in you've done alot! keep it up!
another quick update the bolt on front lower brace is on and nearly finished just need to add a little extra support for it as it will have the radiator sat on it and also the intercooler and maybe oil cooler.
also made the supports that the front panel will bolt to
heres the pics
so made up some little plates that bolt onto the front panel
front of front panel with bolt heads basically how it will look on the car
then started by bending the front brace bar and kept matching it up to wher ei wanted it to fit til the bends were right
then welded on the steel mount plates
front lower brace in place sitting under the front panel
chassis mount plates tacked into place
welding the chassis mount plates on (just enough for now til I can get better access when the cars out)
then made up the chassis brace mounts for the bolt on front panel (not fully welded on yet as need better access)
not too long now til il be getting the car on its side ready to put all the new floor pan on underneath and sorting out the smaller bits
just got to make it a rolling chassis first on its own wheels and not on the chassis dolley
Fucking hell its coming on now man!
Fair play haha!
Welding is getting better and better as you go also ;)
this still going on air ride? I'm about to flog my valves,tank, compressor if your interested
It may go on air ride at some point of one form or another
I already have a tank and a 380c Viair compressor
Would be interested in the valves what price you looking for them Kiz
wont be for sale on there own I'm afraid as i want to sell it all as a management kit. I've a brand new 5 gallon airlift tank, brand new 380c compressor, ViAir tank switch (120psi on 145psi off)the 2way F&B setup with the digital pressure gauge and 3 senders (1 for tank) all the wiring and switchs and 8mm lines with a bucket load of fittings.
i wasnt even sure what to ask for all of it let alone splitting it. i was expecting £350 for all of it- what did you get your tank and comp for?
I've actually got all of the kit except valves and bags tbh
I have one solenoid valve just not bought the rest yet as I was working out sizes and wanted bags before buying more
I've designed my own static+ sort of system that I may use with my coilies just need to make the prototypes and trial them instead of running full airbags to make handling better
And I paid around the £300 mark for all of it
I would be interested in your full setup tbh just not right now as there is some other bits I need to buy ATM to progress the car first before I think about it and would want to have made these
So it's a pity your not selling in a month or two
What are you doing with your airbags you keeping them
ahh right i see, I'm keeping my bags and struts as there being used still.
its always the same - bad timing lol i thought id give you first shout before i put them up for general sale.
Weldings coming on aint it - looking good
Thanks mate and appreciate the first dibs
I'm gutted as there is loads of stuff popping up this month and I'm mega skint due to really whacking up my savings for a house deposit before I move out
But my own place with my own garage will be worth the times of being poor :)
this is amazing!
right little update
but to start I just want to vent the fact there is a certain PATHETIC Moderator on this forum I wont name names if your reading my build bugger off don't want your help, advice or anything to do with you so just don't even bother reading this or following it
Just to clear something else up I'm not running Digifant management as for my needs its shit and couldn't cope at all
I will be running Emerald K6 management
anyways heres a little update
made some bolt on mounts
this is where they will go
then made some more weld on braces and lightened them before welding them into place
weld on braces in place
started welding in the rear bulkhead X brace
also started notching the outer front chassis rail to allow extra space for suspension camber adjustment
then started adding strengthening braces to the turret corners
then started closing the turrets up by adding the side on
these obviously aren't finished yet but its started
you checked if the bonnet fits yet dudee?
and careful on the whole freedom of speech thing, itl get you banned.
progress is rapid!
bonnet will practically close needs a little modification but no big gaps will get a pic next time I pull the car out properly
just waiting on payday now so I can buy the bits to make the front wishbones as I'm not using the escort adjustable tcas and compression struts on the front I'm making my own complete adjustable wishbones now just need to order the parts
yeah I know about this freedom of speech thing getting people banned tbh I didn't do anything wrong I was trying to help Tominator yet I was in the wrong
itll affect CP as a whole as the more knowledgable members will get pissed off and stop coming on here I already know of a few who cba to come on here anymore due to all the crap at least I'm still trying to help
Good update again, and I don't see what everyone's crying about, it's varied opinions and different ways of looking st things, if everyone thought the same everything would be boring and the same, I disagree/would do lots different to how you are on this build, but that's what makes it yours not mine ;)
I have valves and air springs Pete will give you all four way shift,we can sort something out.
And remember mate opinions are like arse holes everyone has one but few are worth a listening too,
Keep it up buddy your doing well! very fukin well!!
finally another update its been a while and I've been doing little bits as and when I can due to doing a lot of work for other people and also life getting in the way too and I'm back riding my bmx and getting back to scratch on that.
anyway the front suspension turrets are now finished I've filled in the gaps and seam welded them fully outside and the majority inside for extra strength
Turret inside seam welded
also started sorting out the headlight mountings as I'm getting rid of the front slam panel full stop
how the front end looks with nothing bolted on
started making the custom adjustable front wishbones
I have all the rose joints and clevis joints to make the arms so these will be being made up over the next week or two and then I can starting mocking up the chassis mounts for the wishbones once the engine is moved into its new place
bought a spotweld gun attachment for my arc welder this will come in real handy with putting the floor pan and body panels in
also bought some M5 and M6 captive weld on nuts
these will stop me having to use nuts and bolts for a lot of the bolt on parts
so I started by welding some on for the bolt on front panel
the front end coming together panel wise
decided I wasn't happy with how far forward the engine sat in the bay so front of the tranny tunnel/firewall choppy choppy for version 2
How it started
chopped out
new bracing started
Just waiting on some more tube to finish it off then I can move the engine 2 inches further back which will give me more room in front for the turbo setup and clearance for the radiator and will also bring the driveshafts back level with the suspension turrets
also did the windscreen braces
paint cleaned off back to bare metal
all welded in place I used 2mm thick sheet for strength
then Welded the tunnel vertical braces that will have the seat cross braces welded to them
actually quite a lot since the last update I didn't realise
anyway more to come now just waiting on picking up more tube and sheet steel on Tuesday to finish off the front of the tunnel and to start getting the floor in
not too much left of the chassis and bracing left to do now so il be getting onto the bodywork once that's done and its back on 4 wheels
I can't believe the amount of work that's going into this :shock:
Keep up the good work Pete, It'll be amazing when complete :-D
I hope it will be pretty amazing
I've actually put hundreds of hours into it and probably more and so much effort but I'm enjoying it and I'm hoping it will be as fun to drive as its been to build
Its bloody special mate. In the good way :) I love everything about it
I'll echo whats been said too.
I'm glad you moved the engine back. I was never 'happy' with the drive shaft angle but this looks like it should be much better. Will you have to get a new Prop made?
The driveshaft angles weren't a problem they were well within good angles of drive tbh
Only reason I'm not happy is the clearance situation in front of the engine
For the turbo, radiator and inter cooler
And I haven't finished making the prop yet as that is one of the last things to do chassis wise
Reckon I'll give you a shout Pete when i want a roll cage in mine!!
Welds look great. Pure engineering going into this, so easy for people to pick stuff apart when they couldn't get near this level of fabrication. Great work man!
Stinkypete - single handedly keeping the steel trade afloat in Britain.
