Mk2 4wd 16vt Bready
I'm wanting a roll cage in mine mate, just a basic one though roof and door bars etc.
  • Replies 1k
  • Views 110.9k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
sheet steel for the floor pan now collected as well as more steel tube and that should practically be one of the last lots of tube I need probs just the odd few bits and bobs left to get really
got 1.2mm thick sheet for the main front side floorpans
and 0.75 for the rest of the floorpan to save weight
also to save even more weight and where I will want to remove parts of the floor pan for better access to underneath I will be using 1mm ally sheet
lets see how light I can make this tank now the weight saving can commence now most of the structural bits are out of the way
this is coming along looaaads since i seen this last!
the 1.2mm sheet is now cut to size ready to have one side bent over to meet the sill properly and then just need to trim it to fit around the jacking points
it can then be fully spot welded in place once I get the car on its side still not sure how I will do this yet as I do want to make a car spit but will see what funding allows
also did a little tidying around the rear TCA mounts sorting out the last of the bracing just need to weld it all in place then the rear end suspension and wishbone wise is finished apart from making the steering tie arms which I just need to weld up quickly
omg stinkey pete please don't give up with this build you have come so far with it i wait for it love it and want to see it finished
o top job on the steel fabrication side of things i wouldn't want to get it on a weighbridge when you finished tho
:unibrow:
Edited by g40dabbsy
What's made you think he's going to ditch this?
It's already been weighed in :(
Naaaaaaaaatttttttt I'm working on it right now and spent Saturday remaking mounts to sit the engine the 2 inches further back for more frontal clearance today I'm finishing remaking the front of the tunnel where I've altered it for the prop to sit in further
It's still going and il never give up on it don't worry guys
Il do a proper big update this week as I've been doing a lot of bits for it
So new update time as its been a while due to doing a lot of work for other people so not a lot of progress on this for a while but I've been getting bits and bobs done
new main floor panels cut from sheet
IMG_2696 by pjdirtjumper, on Flickr
using this bad ass tool (air shears)
IMG_2698 by pjdirtjumper, on Flickr
then got the floor panels bent down one side to match up to the sill
IMG_2705 by pjdirtjumper, on Flickr
IMG_2706 by pjdirtjumper, on Flickr
started stripping and sorting out the new driveshafts ready for shortening as the ones before had the wrong inner CV
these are Bora 1.8t ones and use the correct trapezoidal inner CV whereas the ones I made before used 100mm inner CVs and rather than making CV adapter plates its just as easy to shorten these new ones that are correct
IMG_2710 by pjdirtjumper, on Flickr
driveshafts all welded up
IMG_2724 by pjdirtjumper, on Flickr
Moved the engine 2 inches further back into the bay also by firstly chopping out the firewall bracing I had fabricated and remaking it
this is how it began from last proper update
IMG_2737 by pjdirtjumper, on Flickr
and this is how it stands now with all bracing redone and some extra bits added in
IMG_2740 by pjdirtjumper, on Flickr
IMG_2741 by pjdirtjumper, on Flickr
IMG_2742 by pjdirtjumper, on Flickr
IMG_2743 by pjdirtjumper, on Flickr
IMG_2744 by pjdirtjumper, on Flickr
IMG_2745 by pjdirtjumper, on Flickr
IMG_2746 by pjdirtjumper, on Flickr
IMG_2747 by pjdirtjumper, on Flickr
just needs finishing off and tidying up, a lot of it will be hidden when I weld the firewall panel in but il weld up the open tube ends and making them look pretty for my own piece if mind
the engine sat further back in the bay
IMG_2711 by pjdirtjumper, on Flickr
prop sat further back
IMG_2712 by pjdirtjumper, on Flickr
IMG_2713 by pjdirtjumper, on Flickr
made myself a new nylon gbox mount bush with stainless inner sleeve
IMG_2730 by pjdirtjumper, on Flickr
IMG_2728 by pjdirtjumper, on Flickr
welded plates to the back of the rear TCA mounts to give more protection to the rose joints
before
IMG_2702 by pjdirtjumper, on Flickr
after
IMG_2700 by pjdirtjumper, on Flickr
bought myself a brand new Hydraulic Bias Pedal Box top mount
IMG_2715 by pjdirtjumper, on Flickr
IMG_2716 by pjdirtjumper, on Flickr
IMG_2717 by pjdirtjumper, on Flickr
After some extensive research I managed to find myself some OEM Kolbenschmidt Big end Bearings real cheap a considerable amount less than the cheapest I had found so far
Heres a pic of some spherical bearing alloy top mounts I have just made for some one
IMG_2735 by pjdirtjumper, on Flickr
also started sorting the propshaft out the main middle part is done just need to fit then work out the lengths of the two end ones and that can be fitted too once the engine is fully in
more to come hopefully will be making the new adjustable wishbones for the front this weekend to finally get it back on all 4 wheels
Edited by StinkyPete
Fixed the picture for you.
Keep it going Pete, You can do it man, Something very special, When you next up north?
New mk2 fibreglass bonnet just purchased RACECAR for sure now
Ash: how do you mean up north as in Sheffield or your way
hah if you did weigh it in you would be ritch theres a lot of clean steal on that polo
and its prob put on a few pounds with the spaceframe in it
do not give up with this car its looking better each time i log on here :thumbsup:
Edited by g40dabbsy
Sheffield way mate :thumbsup:
fuck me... i have been reading through this for a bit but haven't inputted... this thing is awesome! all the custom work looks top notch!
keep up the good work man, it'll all be worth it in the end!
more updaterzzz
so basically had last Friday afternoon off to get some more work done on this and I managed to do loads I was working on it from 1pm til 9pm :0
so the majority of the rear TCA mountings are now fully braced just one or two little bits left to do
IMG_2758 by pjdirtjumper, on Flickr
IMG_2759 by pjdirtjumper, on Flickr
IMG_2760 by pjdirtjumper, on Flickr
IMG_2761 by pjdirtjumper, on Flickr
IMG_2762 by pjdirtjumper, on Flickr
IMG_2763 by pjdirtjumper, on Flickr
IMG_2764 by pjdirtjumper, on Flickr
IMG_2765 by pjdirtjumper, on Flickr
IMG_2766 by pjdirtjumper, on Flickr
IMG_2767 by pjdirtjumper, on Flickr
I then decided to get the engine fitted properly finally and so pressed the new nylon bush I made into the gearbox mount ready for fitting
IMG_2768 by pjdirtjumper, on Flickr
IMG_2769 by pjdirtjumper, on Flickr
IMG_2770 by pjdirtjumper, on Flickr
I also welded in the floor middle brace for extra strength where drivers + passengers feet will be
and got the seat cross braces in ready for what the seat runner will attach to (need to add the attachments for seat runners yet but haven't order the runners for mock up either yet
IMG_2771 by pjdirtjumper, on Flickr
IMG_2772 by pjdirtjumper, on Flickr
IMG_2773 by pjdirtjumper, on Flickr
then last sunday morning I got cracking on my milling machine to skim the wishbone ball joint plates and Monday after work I welded them all up
IMG_2781 by pjdirtjumper, on Flickr
IMG_2782 by pjdirtjumper, on Flickr
IMG_2790 by pjdirtjumper, on Flickr
IMG_2791 by pjdirtjumper, on Flickr
IMG_2792 by pjdirtjumper, on Flickr
IMG_2793 by pjdirtjumper, on Flickr
IMG_2794 by pjdirtjumper, on Flickr
IMG_2795 by pjdirtjumper, on Flickr
IMG_2796 by pjdirtjumper, on Flickr
IMG_2797 by pjdirtjumper, on Flickr
The weight saving also begins as I purchased a fibreglass single skinned bonnet last week its so light and also trial fitted it to show the bonnet will clear the suspension turrets
IMG_2783 by pjdirtjumper, on Flickr
IMG_2784 by pjdirtjumper, on Flickr
IMG_2785 by pjdirtjumper, on Flickr
IMG_2786 by pjdirtjumper, on Flickr
IMG_2787 by pjdirtjumper, on Flickr
IMG_2788 by pjdirtjumper, on Flickr
IMG_2789 by pjdirtjumper, on Flickr
that's about it for now so hoping to get the front wishbone mounts welded to the frame this weekend and get the adjustable arms welded up then I can drop it on all 4 wheels and start getting the steering rack in the right place its a tight squeeze but I have it sitting in the rough place atm which is good
its starting to really come together now
also going to order some ally sheet to save some weight in non critical areas of the floor pan and have quite a few special titanium bolts on there way to me ;)
Love reading your updates, cant wait to see this finished, would love to come check it out.
Just keeps getting better :)
Keep at it Pete, there is light at the end of the tunnel haha. Looking awesome dude!
Solid amount of work going into this Pete - what's the reason for not going to a better suspension system (double wishbone for example) would be just as much work as this (maybe easier).
Pete
Pete
I'm in there also double wishbone stronger better handleing etc
Edited by g40dabbsy
Il be honest I would love to double wishbone it but having never tackled something like this before I just went for a simple tried and tested idea and there is always room for improvement in the future then
even if it means redoing all the suspension mounts to accommodate double wishbones
Il see how the car handles with all this setup and go from there really
Never know it might be great like this unlikely but you never know
Currently working on the car right now finishing the rear mount strengthening/triangulation and making rear tie arms
More updates this weekend
so heres the update not much done this weekend due to having to do some travelling and also breaking a mk2 coupe anyway heres whats been done
first up I made the rear adjustable tie arms
IMG_2808 by pjdirtjumper, on Flickr
IMG_2809 by pjdirtjumper, on Flickr
IMG_2810 by pjdirtjumper, on Flickr
IMG_2811 by pjdirtjumper, on Flickr
IMG_2812 by pjdirtjumper, on Flickr
IMG_2813 by pjdirtjumper, on Flickr
also finished bracing and triangulating all of the rear TCA mounts
IMG_2814 by pjdirtjumper, on Flickr
IMG_2815 by pjdirtjumper, on Flickr
IMG_2816 by pjdirtjumper, on Flickr
IMG_2817 by pjdirtjumper, on Flickr
IMG_2818 by pjdirtjumper, on Flickr
Saturday morning I took delivery of this mk2 coupe and started to take all the bits off it I wanted ready for it to be collected for scrap Saturday Afternoon
IMG_2819 by pjdirtjumper, on Flickr
IMG_2820 by pjdirtjumper, on Flickr
IMG_2821 by pjdirtjumper, on Flickr
I'm sure you can guess whats happening due to the panels that are now missing off this coupe also managed to get a good wing from it too
fitted the passenger side rear TCAs and Tie arm etc ready to put the rear on wheels to help me mock up the front wishbones correctly
IMG_2829 by pjdirtjumper, on Flickr
IMG_2830 by pjdirtjumper, on Flickr
IMG_2831 by pjdirtjumper, on Flickr
IMG_2832 by pjdirtjumper, on Flickr
and a quick pic looking through the rear window
IMG_2833 by pjdirtjumper, on Flickr
Have some bits for sale off this coupe all cheap so check the forsale threads
new Aircraft Titanium Secure bolts
IMG_2835 by pjdirtjumper, on Flickr
got them so cheap and I'm sure il use them somewhere definitely worth having especially for less than £13
£12.99??!
That cap looks mint mate, cheers
That's alright mate give it a nice polish for me so its nice and bling will look right at home in your bay
