Mk2 4wd 16vt Bready
sweeeeeet lol, whats going on with the flooring/bulkhead and stuff then? guessing you cant leave it like a skeleton obvs so what you gonna do use thin metal sheet to cover any gaps?
  • Replies 1k
  • Views 110.9k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
yeah I'm using 1.2mm sheet steel for main floorpan where you sit then I have 0.7mm thick sheet to weld in all the rest of the safelt places like bulkhead etc but still weight saving
then for where I want removable bolt on panels for access I have some 1mm thick ally sheet to save weight
will be starting all of that pretty soon just need to finish off the rest of the chassis structure
ah i see thats cool then! will look proper bo when thats all in!
Hench update mate! Going well.
You having shafts etc balanced?
jjust read this. absolutely nuts!
not going to have shafts balanced unless they really need it Nick
I've seen people shorten them proper pikey style and they have been fine so hopefully me doing it the proper way they should be a lot better than that
Awesome update :) talk about poke lol!
Awesome work Pete, incredible update!
Loving the work here very neat and tidy also i love your jack
Amazing stuff mate!
Love your updates Pete looks mint!
Pete...you crazy!
more has happened
so this is how far I am now
it got put back on all 4 wheels with the tie rod flip kit installed
IMG_3201 by pjdirtjumper, on Flickr
IMG_3202 by pjdirtjumper, on Flickr
IMG_3203 by pjdirtjumper, on Flickr
IMG_3204 by pjdirtjumper, on Flickr
IMG_3205 by pjdirtjumper, on Flickr
IMG_3206 by pjdirtjumper, on Flickr
IMG_3207 by pjdirtjumper, on Flickr
IMG_3208 by pjdirtjumper, on Flickr
made some ally spherical rod end spacers for the front TCA's
IMG_3218 by pjdirtjumper, on Flickr
IMG_3219 by pjdirtjumper, on Flickr
steering rack bottom mount finished
IMG_3220 by pjdirtjumper, on Flickr
IMG_3221 by pjdirtjumper, on Flickr
IMG_3222 by pjdirtjumper, on Flickr
IMG_3223 by pjdirtjumper, on Flickr
rolling out the old garage
IMG_3248 by pjdirtjumper, on Flickr
into my new garage
IMG_3251 by pjdirtjumper, on Flickr
IMG_3252 by pjdirtjumper, on Flickr
picked up the new possible arches I had custom made for me
quick trial fitting
IMG_3267 by pjdirtjumper, on Flickr
IMG_3268 by pjdirtjumper, on Flickr
IMG_3269 by pjdirtjumper, on Flickr
IMG_3270 by pjdirtjumper, on Flickr
I am having some more made up that are longer so will fit around the wheel and with the bodywork more
these ones are too short as the guy thought I was running 13's and not 15's my mistake for not letting him know
new cnc alloy 3 bar map sensor all the way from finland stupidly good price posted and a lot better than the plastic expensive ones in the uk at around £95
full 1 year warranty that covers extreme competition use so perfect for this build
IMG_3271 by pjdirtjumper, on Flickr
IMG_3273 by pjdirtjumper, on Flickr
new AVY headgasket ready for the engine build up coming soon
IMG_3274 by pjdirtjumper, on Flickr
took the sunroof out finally will save a lot of weight and the roof is so flexible but have some plans for this (ideas below so opinions welcome)
IMG_3275 by pjdirtjumper, on Flickr
IMG_3276 by pjdirtjumper, on Flickr
IMG_3277 by pjdirtjumper, on Flickr
Bias pedal box mounts welded in and pedal box fitted
IMG_3281 by pjdirtjumper, on Flickr
IMG_3282 by pjdirtjumper, on Flickr
IMG_3291 by pjdirtjumper, on Flickr
IMG_3280 by pjdirtjumper, on Flickr
IMG_3278 by pjdirtjumper, on Flickr
IMG_3279 by pjdirtjumper, on Flickr
alternator trial fitted to see clearance
IMG_3283 by pjdirtjumper, on Flickr
starter motor trial fitted
IMG_3284 by pjdirtjumper, on Flickr
Prop mounts all made and welded in (drilled the plate to carry on the weight saving theme)
IMG_3285 by pjdirtjumper, on Flickr
IMG_3286 by pjdirtjumper, on Flickr
IMG_3287 by pjdirtjumper, on Flickr
IMG_3288 by pjdirtjumper, on Flickr
IMG_3289 by pjdirtjumper, on Flickr
IMG_3292 by pjdirtjumper, on Flickr
IMG_3293 by pjdirtjumper, on Flickr
IMG_3294 by pjdirtjumper, on Flickr
Passenger seat rails all welded in and passenger seat in
IMG_3297 by pjdirtjumper, on Flickr
IMG_3298 by pjdirtjumper, on Flickr
IMG_3296 by pjdirtjumper, on Flickr
IMG_3295 by pjdirtjumper, on Flickr
also cut off the last bits of the front chassis rails that are no longer needed gives more access aswell for finishing bits off
IMG_3299 by pjdirtjumper, on Flickr
IMG_3300 by pjdirtjumper, on Flickr
IMG_3301 by pjdirtjumper, on Flickr
that's it for now but I'm getting everything sorted to get the car on its side so I can finally start getting the new floor pan in
right ROOF options are:
A: buy some polycarb and bolt it in as a light weight sunroof
B: have the roof fibreglassed over (using roof as mould) then trim all excess metal from middle and tigerseal the fibreglass roof ontop basically roof skin it.
C: cut out as much metal from middle and replace with ally sheet for mass weight loss (1mm ally Sheet)
roof thickness is 1.0-1.2mm mild steel sheet
B would look normal but be light weight but not too bothered about it looking original as none of the rest of the car does
C is what I prefer and if done right would look amazing IMO plus would save 50-55% of the weight of the actual roof that would be removed
any other ideas or opinions are welcome and please don't just give negative comments give reasons as to why you think something is a bad idea if it is
thanks People
why are you going to all the effort of saving weight, then welding on some hench metal arches??? why not get some fibreglass ones made dude?! berg cup style?
also id deffo go for a perspex sunroof for easyness.
other than that looking cool man
I don't want fibreglass arches as I don't want them stuck on or bolted on
I want something permanent so going with the steel ones and welding them on
They aren't hench metal arches as they are only 0.8mm thick sheet and they won't be left solid
Just wait and see
Regarding the roof I'm not bothered about easiness otherwise I wouldn't be doing this build at all
I would rather the weight saving
A was just an option to put out there but it's the least likely to happen
Thanks for the input though Eric
Top work as usual Pete!
fair enough dude! interested to see where you go with the arches. hopefully you can pull it off!
I was going to raise the exact same point as Ric about the arches should be fibreglass to make a diff in weight. You seem to know what your doing so go with the best option for yourself. Don't do what is easier or cheaper at the time if you will regret it in the long term. Do as you always have, do what you want and what suits you buddy, if it means more graft then tough shit crack on ;)
Keep it up bro, fantastic work as always.
Keep it going man, Buzzing to see it sunday!!
Nice map sensor! What management are you going to run?
I'm going to be running Omex 600 now and will hopefully be buying it next month
Just to add some more info about arches for people concerned about weight
It will only be the rear arches adding any weight to the car as I plan on getting fibreglass copies made of the front wings and arches as a whole one piece part
so that will save a lot more weight on the front where needed
Love this build. A proper 'Build Thread'. Some awesome work going on in here, cant wait to see this thing finished :-)
insane work ! . just awesome !. Much respect
any more updates on this amazing build ?
Awesome work mate!
Anyone else would have lost heart in this by the now, but not you!
