Mk2 4wd 16vt Bready
Awesome as usual, its so fucking wide!
Why not get some GRP arches made using the steel ones as a template. Weight saving and money making. And I think you should fuck the sun roof off all together and option C would be the best
  • Replies 1k
  • Views 110.9k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
The roof is now cut out but i shall be trimming some more away to make the original roof minimal and will be ordering aluminium sheet to replace it in the near future once the shells near completion which hopefully wont be too long
also have the majority of bits now to start building the engine so the block and gbox will be pulled out tonight to get the chassis on the dolley and then flipped on its side this weekend for the floorpan to go in next week
may also be ordering a G60 flywheel with VR6 carbon kevlar clutch this weekend too for the beast
its coming together
progress is abit slow atm due to doing alot of work for other people but I'm getting round to it while also sorting the house from moving still as it takes so long to unpack everything.
thanks for the comments guys more proper updates to come soon
This thing just gets more insane by the minute! I'd love to see this in the metal!
Woah, monster in the making here, nice work!
well finally time for another update:
took the turbo apart to clock it ready for trial fit but didn't have a 12 point 6mm socket so had to order one
IMG_3308 by pjdirtjumper, on Flickr
IMG_3309 by pjdirtjumper, on Flickr
IMG_3310 by pjdirtjumper, on Flickr
Edited by StinkyPete
links don't work :sad:
x2!
wanna see the progress!
Cut the roof out of the polo ready for the lightening
IMG_3312 by pjdirtjumper, on Flickr
IMG_3313 by pjdirtjumper, on Flickr
IMG_3314 by pjdirtjumper, on Flickr
IMG_3315 by pjdirtjumper, on Flickr
bought myself a TIG Welder so I can start fabbing up stainless stuff like exhausts, downpipes etc
IMG_3360 by pjdirtjumper, on Flickr
some work in progress pictures my mate got of my car at my last house
IMG_3367 by pjdirtjumper, on Flickr
IMG_3368 by pjdirtjumper, on Flickr
IMG_3369 by pjdirtjumper, on Flickr
IMG_3370 by pjdirtjumper, on Flickr
IMG_3371 by pjdirtjumper, on Flickr
IMG_3372 by pjdirtjumper, on Flickr
Then finally got the shell on its side after I stripped everything off it.
IMG_3374 by pjdirtjumper, on Flickr
IMG_3375 by pjdirtjumper, on Flickr
IMG_3376 by pjdirtjumper, on Flickr
IMG_3377 by pjdirtjumper, on Flickr
IMG_3378 by pjdirtjumper, on Flickr
IMG_3379 by pjdirtjumper, on Flickr
IMG_3380 by pjdirtjumper, on Flickr
IMG_3381 by pjdirtjumper, on Flickr
Started getting the tunnel sides cut and welded into place
IMG_3399 by pjdirtjumper, on Flickr
IMG_3400 by pjdirtjumper, on Flickr
IMG_3401 by pjdirtjumper, on Flickr
IMG_3402 by pjdirtjumper, on Flickr
IMG_3404 by pjdirtjumper, on Flickr
IMG_3405 by pjdirtjumper, on Flickr
more floorpan panels cut
IMG_3406 by pjdirtjumper, on Flickr
IMG_3407 by pjdirtjumper, on Flickr
IMG_3408 by pjdirtjumper, on Flickr
Harness mounting points
IMG_3403 by pjdirtjumper, on Flickr
IMG_3409 by pjdirtjumper, on Flickr
IMG_3410 by pjdirtjumper, on Flickr
IMG_3411 by pjdirtjumper, on Flickr
tunnel sides finished
IMG_3412 by pjdirtjumper, on Flickr
IMG_3413 by pjdirtjumper, on Flickr
under seat mounts primed ready for main floorpan fitting
IMG_3414 by pjdirtjumper, on Flickr
IMG_3415 by pjdirtjumper, on Flickr
IMG_3416 by pjdirtjumper, on Flickr
Main Floorpan fitting
IMG_3417 by pjdirtjumper, on Flickr
IMG_3418 by pjdirtjumper, on Flickr
IMG_3419 by pjdirtjumper, on Flickr
IMG_3420 by pjdirtjumper, on Flickr
IMG_3421 by pjdirtjumper, on Flickr
IMG_3422 by pjdirtjumper, on Flickr
IMG_3423 by pjdirtjumper, on Flickr
IMG_3424 by pjdirtjumper, on Flickr
IMG_3425 by pjdirtjumper, on Flickr
IMG_3426 by pjdirtjumper, on Flickr
rear tunnel sides the 0.75mm sheet didn't flex as easily as I thought it would so I need to sort the shaping out
IMG_3427 by pjdirtjumper, on Flickr
IMG_3428 by pjdirtjumper, on Flickr
IMG_3429 by pjdirtjumper, on Flickr
IMG_3430 by pjdirtjumper, on Flickr
IMG_3431 by pjdirtjumper, on Flickr
IMG_3432 by pjdirtjumper, on Flickr
IMG_3433 by pjdirtjumper, on Flickr
IMG_3437 by pjdirtjumper, on Flickr
IMG_3438 by pjdirtjumper, on Flickr
IMG_3439 by pjdirtjumper, on Flickr
IMG_3440 by pjdirtjumper, on Flickr
IMG_3441 by pjdirtjumper, on Flickr
IMG_3442 by pjdirtjumper, on Flickr
IMG_3443 by pjdirtjumper, on Flickr
main floorpan tunnel edge seam welded in
IMG_3434 by pjdirtjumper, on Flickr
IMG_3435 by pjdirtjumper, on Flickr
IMG_3436 by pjdirtjumper, on Flickr
inside the cockpit views
IMG_3444 by pjdirtjumper, on Flickr
IMG_3445 by pjdirtjumper, on Flickr
IMG_3447 by pjdirtjumper, on Flickr
More progress to come as I have more floorpanels cut ready for welding and making more templates to cut more panels daily
hardest bit is going to be joing it back up with the shell especially with the plans I have in mind but you will all find out as they come to fruition
enjoy some real progress
Bought a G60 Lightened and balnced flywheel with Carbon Kevlas VR6 clutch and also a hydraulic slave cylinder bearing.
IMG_3385 by pjdirtjumper, on Flickr
IMG_3386 by pjdirtjumper, on Flickr
IMG_3387 by pjdirtjumper, on Flickr
IMG_3388 by pjdirtjumper, on Flickr
IMG_3389 by pjdirtjumper, on Flickr
Looks good mate, Tig welder helped
The panels n the tunnel look poor as they didn't bend and just buckled, shame you went ahead with that, seems a little half arsed when you consider the effort you have put in everywhere else.
Where will your exhaust run?
I'd personally have bead rolled the floor panels to add some strength too, & what higgo said.
Masses of progress again though!
I don't need anymore strength in the Floorpan it's more than strong enough for what's needed and bead rolling it would ruin the completely flat bottom I'm going for
As for the rear tunnel sides I'm not finished with them yet. I have just purchased and received a panel beating hammer and dolly kit to sort out the creases and get the panels how I want them so they do not ruin the effort of the car.
The exhaust is all ready planned just need to make sure it will fit so wait and see
Pure porn Pete. Keep it up.
well its update time again
used the hammer and dolly set quite a bit already and tidied up the rear tunnel sides as best I can pictures don't really do it justice but they do look a hundred times better now
IMG_3463 by pjdirtjumper, on Flickr
IMG_3464 by pjdirtjumper, on Flickr
IMG_3465 by pjdirtjumper, on Flickr
IMG_3466 by pjdirtjumper, on Flickr
IMG_3467 by pjdirtjumper, on Flickr
IMG_3482 by pjdirtjumper, on Flickr
IMG_3483 by pjdirtjumper, on Flickr
template making
IMG_3484 by pjdirtjumper, on Flickr
IMG_3485 by pjdirtjumper, on Flickr
clocking the turbo
IMG_3486 by pjdirtjumper, on Flickr
IMG_3488 by pjdirtjumper, on Flickr
IMG_3489 by pjdirtjumper, on Flickr
the 6mm 12 point socket I needed for undoing the turbo vgt bolts which just happen to be Inconel bolts :0
IMG_3487 by pjdirtjumper, on Flickr
only got halfway with clocking the turbo as I needed to drill and tap an extra hole to spin the exhaust housing round
this is now done so just need to put it all back together and will take pictures as I do
and as far as I'm aware no one else has managed to clock one of these turbos before I'm not sure why as its a piece of piss for what needs to be done and even if you cant drill it properly yourself a machine shop would do it for less than a tenner. took me about 5 mins if that on the milling machine :)
also started to refurb my tappets and start stripping my head down for full rebuild
IMG_3494 by pjdirtjumper, on Flickr
IMG_3495 by pjdirtjumper, on Flickr
IMG_3496 by pjdirtjumper, on Flickr
just need to rebuild these with some fresh oil now
Looks amazing Pete! I can't believe how much work/effort has gone into this! :)
a bit more progress now
spotwelded the floor pan along the sill edge and also to the sill. Then rather than cut off the excess sheet I folded it over the original sill to strengthen it further
IMG_3509 by pjdirtjumper, on Flickr
IMG_3510 by pjdirtjumper, on Flickr
IMG_3513 by pjdirtjumper, on Flickr
IMG_3515 by pjdirtjumper, on Flickr
IMG_3516 by pjdirtjumper, on Flickr
found some surface rust on the sills but I cleaned it all back to bare metal and jenolite zinc treated it
also cleaned the sill lip back to bare metal and zinc treated that before rolling the excess floorpan over and I will seam weld along the outer edge now for strength
Nice work! Is jenolite any good? I've been using POR 15 paint.
