Mk2 4wd 16vt Bready
Billet Recirc Bung I've made for a few people now
it fits mk2 golf and jetta diesel engines think they are GTD ones
IMG_3537 by pjdirtjumper, on Flickr
IMG_3538 by pjdirtjumper, on Flickr
finished clocking the turbo tonight and its all back together ready for trial fitting on the engine in the bay to make the manifold. Before I modify it further ;)
IMG_3541 by pjdirtjumper, on Flickr
IMG_3542 by pjdirtjumper, on Flickr
IMG_3543 by pjdirtjumper, on Flickr
IMG_3544 by pjdirtjumper, on Flickr
Jenolite is a pre treatment before paint Jim it converts the rust there and then and turns it black so you can see its sorted.
you then rub it back a little and primer over it.
always worked for me I've used it for years the jelly stuff is better than the liquid imo it applies a lot better and easier
Edited by StinkyPete
  • Replies 1k
  • Views 110.9k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
This is no longer a Polo..... its a crazy mad engineers idea of what a Polo should be. I Love it. keep it up pal. good work.
few more things have turned up
presents
IMG_3557 by pjdirtjumper, on Flickr
New exhaust silencers proper slimline 4" diameter 12" long body 16" overall with the pipe ends
IMG_3558 by pjdirtjumper, on Flickr
IMG_3559 by pjdirtjumper, on Flickr
aluminium sheet 2.5m x 1.25m x 1mm thick 2 sheets of it
its so light its unbelievable this is the new roof, some of the non structural flooring and interior panels
IMG_3560 by pjdirtjumper, on Flickr
IMG_3562 by pjdirtjumper, on Flickr
more to come hopefully cracking on this weekend
some more pictures from yesterdays progress
managed to get the car the right way round now
IMG_3563 by pjdirtjumper, on Flickr
IMG_3564 by pjdirtjumper, on Flickr
IMG_3565 by pjdirtjumper, on Flickr
and the floorpan from the inside of the car now rather than just underneath
IMG_3566 by pjdirtjumper, on Flickr
IMG_3567 by pjdirtjumper, on Flickr
IMG_3568 by pjdirtjumper, on Flickr
IMG_3569 by pjdirtjumper, on Flickr
IMG_3570 by pjdirtjumper, on Flickr
IMG_3571 by pjdirtjumper, on Flickr
IMG_3572 by pjdirtjumper, on Flickr
IMG_3573 by pjdirtjumper, on Flickr
IMG_3574 by pjdirtjumper, on Flickr
IMG_3575 by pjdirtjumper, on Flickr
IMG_3576 by pjdirtjumper, on Flickr
bit more progress today
more floorpan sheets being made up for the rear
IMG_3607 by pjdirtjumper, on Flickr
then finished off the rear X Brace for strengthening and also seperating the fuel tank from the cabin
IMG_3608 by pjdirtjumper, on Flickr
IMG_3609 by pjdirtjumper, on Flickr
IMG_3610 by pjdirtjumper, on Flickr
IMG_3611 by pjdirtjumper, on Flickr
managed to get some more time in the garage last weekend and heres the progress.
first off i used an old bust dizzy to start making a dizzy blank as a friend has requested one as they will be using aftermarket management and i also want one too so after finding about 6 old dizzies in my boxes that i honestly cant recall getting I'm making them into dizzy blanks. heres a pic of the first so far its not completely finished but only need to make a press in bung for the centre.
These are basically OE dizzy blanks ;)
started like this
IMG_3643 by pjdirtjumper, on Flickr
ended like this
IMG_3645 by pjdirtjumper, on Flickr
IMG_3646 by pjdirtjumper, on Flickr
IMG_3648 by pjdirtjumper, on Flickr
anyway back onto my car as I'm sure thats what you want to see.
i got the rear vertical turret braces notched and welded into place
IMG_3649 by pjdirtjumper, on Flickr
IMG_3650 by pjdirtjumper, on Flickr
IMG_3651 by pjdirtjumper, on Flickr
Started on the front tunnel roof this is where the template sheets start getting complicated from here on.
but it turned out alright
IMG_3653 by pjdirtjumper, on Flickr
IMG_3654 by pjdirtjumper, on Flickr
IMG_3655 by pjdirtjumper, on Flickr
all welded in
IMG_3656 by pjdirtjumper, on Flickr
IMG_3657 by pjdirtjumper, on Flickr
looking down the tunnel now
IMG_3658 by pjdirtjumper, on Flickr
looking at the rear from inside
IMG_3659 by pjdirtjumper, on Flickr
Wow, this gets more crazy by the minute!
started plating up the bulkhead
IMG_3660 by pjdirtjumper, on Flickr
IMG_3661 by pjdirtjumper, on Flickr
IMG_3662 by pjdirtjumper, on Flickr
IMG_3663 by pjdirtjumper, on Flickr
IMG_3664 by pjdirtjumper, on Flickr
IMG_3665 by pjdirtjumper, on Flickr
IMG_3666 by pjdirtjumper, on Flickr
IMG_3667 by pjdirtjumper, on Flickr
IMG_3668 by pjdirtjumper, on Flickr
IMG_3669 by pjdirtjumper, on Flickr
IMG_3670 by pjdirtjumper, on Flickr
IMG_3671 by pjdirtjumper, on Flickr
IMG_3672 by pjdirtjumper, on Flickr
inside passenegers footwell
IMG_3673 by pjdirtjumper, on Flickr
IMG_3674 by pjdirtjumper, on Flickr
tunnel top inside the car
IMG_3675 by pjdirtjumper, on Flickr
IMG_3676 by pjdirtjumper, on Flickr
inside view of tunnel and footwells
IMG_3677 by pjdirtjumper, on Flickr
better rear pics of rear bulkhead separator
IMG_3678 by pjdirtjumper, on Flickr
IMG_3679 by pjdirtjumper, on Flickr
Keep going mate, looking spot on!!
This build is like nothing else I've seen, it should have gone viral by now. Can't wait to see the hardware going in.
Every short block 16v twin belt engine, so around the 99-07 era, has two dizzy blanks fitted to the cylinder head as standard. I've been throwing them away. Shoulda said lol
got the drivers side wheel well bulkhead plated and welded up at the weekend
so its coming along just the main top and front to do now and then the bulkhead is finished
IMG_3755 by pjdirtjumper, on Flickr
IMG_3756 by pjdirtjumper, on Flickr
IMG_3757 by pjdirtjumper, on Flickr
IMG_3759 by pjdirtjumper, on Flickr
IMG_3760 by pjdirtjumper, on Flickr
need to grind the welds down and clean it all up but I'm going to hit all that up at once on the whole car and do it in a oner
Looking awesome Pete, by far the most serious engineering project on the forum. Keep it up dude!
P.s did you find that Boss Rubber thingy?
drilled the new dog bone mount arm
its aluminium extruded U section so more than strong enough for the job and less than half the weight of the old steel 25mm box section I was using
IMG_3779 by pjdirtjumper, on Flickr
IMG_3781 by pjdirtjumper, on Flickr
started sorting the new turbo exhaust manifold so ordered a T3 lasercut flange for the exhaust inlet which is what I was told it was to find out it doesn't fit.
so ordered a T2 lasercut flange to find out this was too small so it was bloody in between in the end after £15 spent I just made one which I could have done from the start was just being lazy and trying to save my time to do other bits.
so correct flange
IMG_3746 by pjdirtjumper, on Flickr
in the middle of the T2 and T3 flanges
IMG_3747 by pjdirtjumper, on Flickr
and fitted to the turbo
IMG_3748 by pjdirtjumper, on Flickr
IMG_3749 by pjdirtjumper, on Flickr
IMG_3750 by pjdirtjumper, on Flickr
the intercooler will be welded up tomorrow when I nip down to welding at college to play on the a/c Tig machines
also modifying my radiator so it works better with how I want to route things
Etches I haven't found it yet its definitely around somewhere I just cant remember where I put it but il be having the shed out tomorrow night anyway as long as its dry as I need to find something else anyways
parts have started arriving for my Cam Chain conversion not seen this done on the AFH before but will hopefully be a benefit over cambelt I'm definitely sure of this
IMG_3752 by pjdirtjumper, on Flickr
new sprocket versus old
IMG_3753 by pjdirtjumper, on Flickr
IMG_3754 by pjdirtjumper, on Flickr
Cheers Pete, I've personally never even heard of converting a head to a chain set up, whats the benefit? Sprockets look boss though, custom expensivo?
They do it on race engines from what I've been told and have seen.
It gets rid of belt failure basically and will help with the extra torque
It also minimises stuff on that side as I can run smaller items
It's actually cheaper than people would think ;)
