Mk2 4wd 16vt Bready
Plate work looks mint Pete!
I wouldn't worry to much about the welds you will be able to loose all that with seem sealer and stone chip.
I am coming round to the chain conversion now much more compact than the belt set up and its pretty much fit and forget.
Good progress mate,
Ow and I've found a bottom bolt and pulley if you still need it I can get it posted Monday.?
  • Replies 1k
  • Views 110.9k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
excuse my language, but you are a fucking madman. This is looking real good. cannot wait to see it finished.
Unreal - literally
Didn't realise I haven't updated in so long as there's actually more progress to report than I thought. Just a pity my internet at home is fubarred. But as soon as it's back working there's a massive update coming
This is properly bonkers
this needs more pictures ;) get your net sorted! lol
yeah I can't really add anything again that's constructive other than its epic! :)
That cam chain conversion looks epic! How are you gonna tension it are you modifying one of another
Car or making it? Are you robbing a chain aswell from a car and modifying it
Or getting on specially made? Keep up the mental work I'm sure this thing will win awards.:p itleast on here Haa
the Cam Chain conversion will have a hydraulic self adjusting tensioner which is a generic one from older cars I have managed to get hold of cheap.
This means it will be more of a fit and forget conversion
The chain I have bought a 5 metre long length of the correct pitch chain to match the sprockets so I just de-link it and rejoin it with the split link at the correct length I wish to run
right now I have some internets il do an update and it will be a massive one as I haven't done one in a while and lots of progress has been made.
Edited by StinkyPete
started machining the sprockets
cam and crank sproclets
3789 by pjdirtjumper, on Flickr
new main crank sprocket bolt
3790 by pjdirtjumper, on Flickr
new chain 5 metres worth
3795 by pjdirtjumper, on Flickr
Intercooler all welded up may need some more modding to fit piping at some point
IMG_3791 by pjdirtjumper, on Flickr
IMG_3792 by pjdirtjumper, on Flickr
IMG_3795 by pjdirtjumper, on Flickr
alloy radiator modified to move the bottom outlet from the right to the left to give more clearance for turbo and downpipe
IMG_3796 by pjdirtjumper, on Flickr
IMG_3797 by pjdirtjumper, on Flickr
new outlet welded on
IMG_3798 by pjdirtjumper, on Flickr
started the new turbo manifold I'm making an equal length one rather than another log manifold
collector pipe
IMG_3802 by pjdirtjumper, on Flickr
IMG_3804 by pjdirtjumper, on Flickr
IMG_3805 by pjdirtjumper, on Flickr
IMG_3806 by pjdirtjumper, on Flickr
more of the bulkhead completed
3803 by pjdirtjumper, on Flickr
3807 by pjdirtjumper, on Flickr
started primering alot of the bare metal also as the cold nights are causing condensation which is causing some surface rust
3810 by pjdirtjumper, on Flickr
3811 by pjdirtjumper, on Flickr
3812 by pjdirtjumper, on Flickr
IMG_3814 by pjdirtjumper, on Flickr
IMG_3815 by pjdirtjumper, on Flickr
bearings and a seal for the chain conversion turned up
IMG_3818 by pjdirtjumper, on Flickr
crank drilled for the new drive of the chain sprocket
IMG_3837 by pjdirtjumper, on Flickr
crank sprocket drilled to match for drive pins
IMG_3850 by pjdirtjumper, on Flickr
other side of crank sprocket
IMG_3851 by pjdirtjumper, on Flickr
hardened and ground dowels pressed into crank
IMG_3865 by pjdirtjumper, on Flickr
sprocket in place
IMG_3866 by pjdirtjumper, on Flickr
IMG_3867 by pjdirtjumper, on Flickr
IMG_3868 by pjdirtjumper, on Flickr
vernier cam sprockets in the making
IMG_3873 by pjdirtjumper, on Flickr
standard sprockets split
IMG_3875 by pjdirtjumper, on Flickr
IMG_3876 by pjdirtjumper, on Flickr
IMG_3877 by pjdirtjumper, on Flickr
cam sprockets fully finished
IMG_3879 by pjdirtjumper, on Flickr
IMG_3880 by pjdirtjumper, on Flickr
A pillar windscreen strengthener brace welded into place
IMG_3883 by pjdirtjumper, on Flickr
IMG_3884 by pjdirtjumper, on Flickr
IMG_3891 by pjdirtjumper, on Flickr
center floor strenghteners welded in
IMG_3885 by pjdirtjumper, on Flickr
IMG_3886 by pjdirtjumper, on Flickr
IMG_3887 by pjdirtjumper, on Flickr
decided to get the shifter mech mounted so made a bracket to weld accross the tunnel top
IMG_3892 by pjdirtjumper, on Flickr
IMG_3893 by pjdirtjumper, on Flickr
all welded in place
IMG_3894 by pjdirtjumper, on Flickr
IMG_3895 by pjdirtjumper, on Flickr
all mounted into place
IMG_3903 by pjdirtjumper, on Flickr
the other 3 arches arrived to add to the parts collection
IMG_3897 by pjdirtjumper, on Flickr
lasercut AFH exhaust flange turned up
IMG_3900 by pjdirtjumper, on Flickr
so started working out runners
IMG_3909 by pjdirtjumper, on Flickr
IMG_3907 by pjdirtjumper, on Flickr
and the turbo manifold so far i have TIG'd it all up rather than MIG it for a cleaner look and stronger welds
IMG_3933 by pjdirtjumper, on Flickr
IMG_3934 by pjdirtjumper, on Flickr
IMG_3935 by pjdirtjumper, on Flickr
IMG_3936 by pjdirtjumper, on Flickr
IMG_3937 by pjdirtjumper, on Flickr
IMG_3938 by pjdirtjumper, on Flickr
IMG_3939 by pjdirtjumper, on Flickr
IMG_3940 by pjdirtjumper, on Flickr
IMG_3941 by pjdirtjumper, on Flickr
IMG_3942 by pjdirtjumper, on Flickr
machined the idler sprocket and checked the new bearings fit
IMG_3914 by pjdirtjumper, on Flickr
IMG_3915 by pjdirtjumper, on Flickr
IMG_3913 by pjdirtjumper, on Flickr
bought a brand new water pump and removed the belt pulley
IMG_3924 by pjdirtjumper, on Flickr
and the new sprocket that will be going on the water pump its smaller in ratio compared to the older one this is so it spins faster more rpm so will flow more water around the engine aiding in the cooling to help with the turbo
IMG_3925 by pjdirtjumper, on Flickr
new hydraulic chain tensioner for conversion
IMG_3926 by pjdirtjumper, on Flickr
started making the stainless turbo exit flange
IMG_3916 by pjdirtjumper, on Flickr
working out where to fit the hydro handbrake
IMG_3944 by pjdirtjumper, on Flickr
IMG_3945 by pjdirtjumper, on Flickr
the chain sprockets are now all finished and have been sent off for heat treating and tempering
I'm not sure how i will go about lubrication yet i have two options
drip feed lubrication or bathed
so once i start installing it all i will work out which one I'm going to use
more than likely bathed and will be making a custom aluminium end engine casing to keep it all clean and sealed up
door top corner braces welded in
IMG_3965 by pjdirtjumper, on Flickr
IMG_3975 by pjdirtjumper, on Flickr
IMG_3955 by pjdirtjumper, on Flickr
IMG_3956 by pjdirtjumper, on Flickr
tunnel top brackets
IMG_3957 by pjdirtjumper, on Flickr
Bulkhead tunnel front finished
IMG_3966 by pjdirtjumper, on Flickr
IMG_3967 by pjdirtjumper, on Flickr
IMG_3968 by pjdirtjumper, on Flickr
IMG_3969 by pjdirtjumper, on Flickr
Front Bulkhead so far
IMG_3970 by pjdirtjumper, on Flickr
started making the tranny box mount
IMG_3971 by pjdirtjumper, on Flickr
drivers side door Cross Brace
IMG_3976 by pjdirtjumper, on Flickr
IMG_3977 by pjdirtjumper, on Flickr
IMG_3978 by pjdirtjumper, on Flickr
IMG_3979 by pjdirtjumper, on Flickr
IMG_3980 by pjdirtjumper, on Flickr
yes i know its not even and there is a reason for this
firstly to make it easier to get in the car so its lower at the front and secondly the A pillar mounting is opposite to a front chassis rail mounting
i will be adding gussets into the centre soon aswell
Sweet, some major work gone into this thing now pete, can't wait to see its first 1/4.
So are you making you are own end casing for the engine so the chain can be lubricated by the engine oil like normal chain driven engines?
Because u can't run the chain dry surely?
Well great read! I've just spent my whole morning reading your thread, about 3/4hrs! And I'm only at March 2013!
Will continue to read another time!
Great work though, extremely inspiring!
Max
