Mk2 4wd 16vt Bready
RyanC
Pete states that he will be most likely creating and end plate for that reason.
Seems to be moving on again pete which is great.
You still seem to be adding brace bars and extra supports..... More and more material and added weight?
Don't you wish you had of shaped the original bars different to begin with?
Do you still look or refer to other space frame builds? Such as the golf I showed you on edition?
Anyway, I am amazed at where your at with this, some fantastic workmanship and skill in some of the new stuff, I particularly love the idea of trying to convert to chain drive, If you get that to work problem free I will be impressed.
Be careful regarding the extra water pressure your creating by increasing the drive speed of the water pump, It was a set flow rate for a reason, too high and you could see problems.
  • Replies 1k
  • Views 110.9k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
the water flow rate increase has already been done.
a few lads on the lupo forum have done it they use pulleys off Audi TT water pumps as they are the same profile just a smaller pulley.
mainly by people charging the gti and afh engines to help with the increased cylinder temperatures caused by boosting
Shaped which original bars better Dan
and a lot of the braces in welding in now have been in the plans generally since the start just not had chance to get them sorted. the material has been sat there quite a while waiting for me to get a chance to do it.
I know I'm adding a lot of weight but its extra strength and I already have plans of where I'm reducing weight from elsewhere
I will also have a lot less inside compared to a standard car
currently lightening my doors I'm aiming for fibreglass weight with them but obviously will be stronger still so around 5kg a door
il be having polycarb windows all around, lightened panels, lightweight ally roof, aluminium inside panels, lightening the shell as much as possible with drilling holes while also retaining strength by flaring the holes this will be a recurring theme around the car like most lightweight track cars. and lots of other weight saving happening too
Yep Ryan I will be replacing the plastic cambelt covers with custom ally ones I'm making to keep the chain setup sealed and it will be a hydraulic tensioned bathed chain setup
also sorting out a dry sump setup too as it seems to have a lot of benefits and will give me better clearance under the engine.
and now going to be running an audi tt rear diff, so I will have haldex but currently working with my dad to make my own manual/electronic controller for it
Awsome will be cool to see it all together, good work!!
This is mad
Have you thought of maybe using some ABS plastic or similar for interior panels instead of aluminium? Or maybe some thin carbon sheet for door panels etc?
The aluminium sheet is only 1mm thick and really light plus the fact I've already bought it as needed it for other parts and il be using the excess for te interior panels so it's win win really
work so far up to date
door bar gussets
IMG_4033 by pjdirtjumper, on Flickr
IMG_4034 by pjdirtjumper, on Flickr
IMG_4037 by pjdirtjumper, on Flickr
IMG_4038 by pjdirtjumper, on Flickr
IMG_4039 by pjdirtjumper, on Flickr
all welded in
IMG_4283 by pjdirtjumper, on Flickr
IMG_4284 by pjdirtjumper, on Flickr
IMG_4303 by pjdirtjumper, on Flickr
IMG_4304 by pjdirtjumper, on Flickr
rear floor mid upright made ready to weld in
IMG_4035 by pjdirtjumper, on Flickr
IMG_4036 by pjdirtjumper, on Flickr
dog bone mount machined out to save some more weight and fitted into place
IMG_4297 by pjdirtjumper, on Flickr
IMG_4308 by pjdirtjumper, on Flickr
IMG_4309 by pjdirtjumper, on Flickr
IMG_4311 by pjdirtjumper, on Flickr
Tranny box stabiliser mount started
IMG_3971 by pjdirtjumper, on Flickr
IMG_4045 by pjdirtjumper, on Flickr
IMG_4046 by pjdirtjumper, on Flickr
IMG_4312 by pjdirtjumper, on Flickr
Had to alter the front top of the tunnel inside the car for clearance too and then plated up the top of the tunnel inside the car
IMG_4040 by pjdirtjumper, on Flickr
IMG_4338 by pjdirtjumper, on Flickr
IMG_4341 by pjdirtjumper, on Flickr
IMG_4345 by pjdirtjumper, on Flickr
IMG_4372 by pjdirtjumper, on Flickr
IMG_4373 by pjdirtjumper, on Flickr
IMG_4376 by pjdirtjumper, on Flickr
IMG_4388 by pjdirtjumper, on Flickr
engine bay bulkhead so far
IMG_4043 by pjdirtjumper, on Flickr
IMG_4044 by pjdirtjumper, on Flickr
machined some bronze bushes for my roll over jig so it will turn smoothly
IMG_4335 by pjdirtjumper, on Flickr
also made a flare tool for flaring the holes I'm cutting into the panels/bodywork to put strength back into them
IMG_4321 by pjdirtjumper, on Flickr
started lightening my drivers door
IMG_4322 by pjdirtjumper, on Flickr
IMG_4324 by pjdirtjumper, on Flickr
IMG_4327 by pjdirtjumper, on Flickr
IMG_4328 by pjdirtjumper, on Flickr
IMG_4329 by pjdirtjumper, on Flickr
IMG_4330 by pjdirtjumper, on Flickr
IMG_4331 by pjdirtjumper, on Flickr
IMG_4332 by pjdirtjumper, on Flickr
also flared the holes in the door but cant see it very well in the only picture i have atm
IMG_4385 by pjdirtjumper, on Flickr
stripped and lightened my new boot lid (Kiz sorted it for me so thanks to him)
IMG_4361 by pjdirtjumper, on Flickr
IMG_4362 by pjdirtjumper, on Flickr
IMG_4364 by pjdirtjumper, on Flickr
IMG_4381 by pjdirtjumper, on Flickr
IMG_4386 by pjdirtjumper, on Flickr
IMG_4390 by pjdirtjumper, on Flickr
IMG_4393 by pjdirtjumper, on Flickr
IMG_4394 by pjdirtjumper, on Flickr
IMG_4395 by pjdirtjumper, on Flickr
so thats the majority of work up to date also been planning the inside rear body work to close the shell off from the outside
buying parts for this is now on hold due to me trying to get the deposit for a house together
then once that is sorted i can finish buying parts
luckily I've got enough work left to do on it to keep me busy for quite a while but it may mean not being finished this year which is a bit gutting but a house is worth it.
Edited by StinkyPete
Jeez dude hats off to you i haven't been on the forum for about two years and remember your first posts when building this i cant believe the route its going down now its amazing! Keep up the good work
Wow! Do you still have a lot to do?
Nice work, how are you mounting the windows now you have cut the doors out mate?
Updates?
Pete's having tinterweb gremlins folk's but progress is still ongoing and will be updated soon.
Edited by Mk2 olop
Is this planned on being road legal and MOT'd or just for track/sprint fun?
I aim to have it IVA'd and all road legal not sure when it will be finally and may do an update this week if i can as alot of progress has been made and the shell isnt too far off being finished.
I cant wait for this update!!
Sounds good. I know the IVA can be a bit of a pain to pass at times. I know of a few Land Rover builds that have failed because wiring looms arent secured every 300mm and other petty things. Fingers crossed when it comes to it all goes well for you.
On a different note relating to another post regarding your engine build, did you get anywhere with finding valve to piston clearance on a standard cam AFH head on 1.6 bottom end?
Yep going by all the rules for the IVA to try and pass first go but i doubt i will from readin up on it. especially as its more the testers disgression and opinion than an MOT but it is all safety after all and atleast i will know what to rectify.
no reply as of yet about piston clearance was just curious to see really especially because of this cam chain conversion il be running
and the fact I'm using GTI pistons in the 1.4 which no one really does as it drops the CR
Looks good Pete, it's one of the only mk2 build threads I check up on!
Same as Jake and I am wanting an update!!!
no update for a while as my laptops broke so wont be fixed until end of the month now when payday comes around.
lots of progress been made though and the engine is really coming on now with all the custom parts I'm making for it.
should really be one of a kind on the engine alone.
Ska_wars your point being ?
Don't feed the troll Pete your doing amazing mate far far better than many keyboard warriors on here.
good build just one thing about it i got to say is the welding is a bit poor some of it looks like the welds have a lack of penetration and thats no good for a rollcage (i am a welder aswell)
Were do you work Kev13?
