Mk2 4wd 16vt Bready
I must say, I'm impressed with the level of work and the engineering of this pete. I hope it all works out for you.
Please tell me you're going to do it justice with decent finish to the body work as well.
Keep it up
  • Replies 1k
  • Views 110.8k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
Yeah lol, not "poundland" spray paint again!
Can't really tell what i'm looking at , but it looks good!
new parts update pretty happy with some new parts i just got
mk4 golf rear carriers: 99p winning bid £3.95 delivery :)
G60 rear alloy calipers for vented discs: £36.05 winning bid £10.00 delivery not bad should work alot better with the AWD
G60 pass driveshaft: 99p winning bid £10.00 postage just need a syncro drivers side shaft now or will get a g60 one and shorten it
Passat K03 turbo manifold: £14.99 winning bid £9.99 postage just got adapt the manifold bolting and port match for my afh head
so turbo build is a go go
keep tuned for me I'm hoarding parts atm while I'm pretty much disabled but surgery next tuesday then i should be on the mend :)
Good look with the OP mate, hope all goes well :-)
Get some pics up!
right another update and more presents for the car yippee
air ride setup I've started to collect
http://i1268.photobucket.com/albums/jj574/...mx/IMG_0366.jpg
http://i1268.photobucket.com/albums/jj574/...mx/IMG_0369.jpg
http://i1268.photobucket.com/albums/jj574/...mx/IMG_0367.jpg
just need to get the airbags which i have already sourced just need to buy
:( Please don't put it on air ride.
I need to other wise the car won't Leave my housing estate
Edited by StinkyPete
Why not put it on air ride?
Poor handeling, excessive weight
This won't have poor handling and tbh it's not adding a lot of weight
Just leave the passenger seat out to make a excuse for adding the weight :p
Really impressive build here. Work is top notch.
Good job!!
Surely bags of air instead of proper suspension will be poor handeling..?
How much weight does it weigh out of interest?
loving the amount of work going in to this car, cant wait to see it driving about!
Where did you get all your fuel fittings mate? After some for mine lol.
BTW you have text ;)
Torques is the company and i bought it all through the ebay shop
You still have the majority of the usual set-up, coilovers etc, then you've got the compressor and lines, and the rest of the gubbins.
Is that for me max or for Charlie and il do an update later
Cheers for this Pete :D I'll get on it when I've got it back on the road and can fiddle :-)
Charlie. An air ride set-up will add more weight than a conventional set-up.
Il need some Of the extra weight in the back to help get better traction on the rear wheels so in a way it does help but I can lighten other things to compensate I'm aiming for 850kg max weight of the whole car
Better go buy some more cutting and grinding disks Pete :lol:
Nah it's all about the hole saw lol and just bought an air reciprocating saw last night to go with my air shears as don't want to grind inside the car if I can avoid it and the air shears are so quick and neat
Are they them nibbler things? Any idea what size compressor they need?
Ah right, didn't realise you were actually using air-ride, you not worried about the handling aspect?
The air shears are like a nibbler but I wanna get one of them too and my compressor is from aldi £99 2.5hp 24 litre it's great tbh and a lot cheaper than ones I've seen that aren't as good and 2 year warranty
As for the air ride why is it so bad handling wise mine will be corner adjustable so that will help more wont it
To be honest, i don't really know about air ride & handling, but i thought they were regarded as a no go for performance cars?
Aye i'm trying to get one of them compressors, but its been a while since they last came up on the deals thing.
Are they quite loud?
