Another Build Thread
Cheers. I can't even seem to get the horn to work using the steering wheel horn push, there must be a break in the circuit somewhere.
If you have twin horns try unplugging one.
  • Replies 1.3k
  • Views 121.6k
  • prankstar2003
    prankstar2003
    Thanks Jake. Last few days I've been putting the doors up. Apart from a few small things it's done
  • prankstar2003
    prankstar2003
    Good weather (still) over the last few weeks means I've gotten the boards on the roof now. This will in time be covered in corrugated steel but for now it's reasonably water proof until I can get hol
  • prankstar2003
    prankstar2003
    Garage all painted (I'll get pics) and the car is moving in on Sunday. I may even get to work on it over the summer ;-/
Thanks Max, possitive as usual :wink: I am going to look into powdercoating for the next stage. Any idea of the sort of temps it can take?
Gaz, twin horns? I don't even have a horn atm, just had the multi-meter connected to the horn wires. There were two wires btw
Good work fella, just a quickie, where did you get your monaco blue mixed? is it a good match? I could do with several cans of the stuff but want the best possible match.
Auto colour match, it's in banbury. Match seems to be good, but its hard to be 100% with the body work in its current state. It's 2k as well, which some people advise to avoid (see above posts!). If your in no rush, I could grab a few cans for you, I'm sure we'll cross paths at some show
Edited by prankstar2003
I hope your having bolstered seats in this lol, your gonna be getting thrown about quite a lot!
By the way, this looks so classy and well executed.
No bolstered seats :-( I was going to get a set of 'rocco fronts when I was going to have a custom recovered interior. But I'm sticking to the standard pattern now as its so rare and its really grown on me. So I'm just gonna have to hold on!
Finished this yet
Certainly lol, i stuggle to stay in a set of rocco seats in a pretty much standard engined breadvan GT in the twisties!
I can't be too skinny for them lol, it might be because there not boltered enough, but i can't sit deep enough into them, if that makes sense?
Have you got me mixed up with someone else lol?
LMAO, i'm 5-11" and 12.5st , that ain't that skinny!
Simon, why avoid 2k because its solvent based? If you can get me 4or so cans mayb, drop me a pm and we can sort something out
Compared to me..... your a stick insect :badgrin: i remember you being smaller than that mind, you've growd up all big :paranoid:
:unibrow:
My old golf seats i had in the bready were lovely and supportive. Not that I often chucked her about, but i never came loose!
Higgo: 2k contains isocyanates which can lead to asthma. It is recomended you use an air fed mask, but I've been talking to a few people in the trade, and they said with the right mask (i have one, £23-ish quid), using aerosol (small amount of the toxic hardener) and only doing small amounts, thus reducing your exposure it should be ok (of course there is still a risk, its up to you to weigh the benefits/hazards up). Earlier in the thread people were getting quite agitated that I wasn't taking all the precautions so I must pass those warnings on. I however will continue to use in small amounts with the equipment I have. The stuff is pretty pricey btw - roughly £15 a can. It does give a lovely finish thought. The pictures above are the 'straight from the can' results. No flatting or cutting compound used yet! It does however take a little longer to dry, and it does run a little easier than celly due to this. It also stays tacky for longer, so make sure you have a dust free area to work in. If your in the area, feel free to pop over and I can show you the results and run through my procedures if your a little concerned etc.
Simon ,hope your well and great thread by the way .
This is my input into the 2k paint debate , i love the stuff, its great to use gives a superb finish however it deserves great respect as it can be very dangerous in use as I'm sure you know :p .
The problem is simply that you dont get used or desensitized to it as such , you actually lose your tolerance to it over time with the isocyanates building up in your blood stream with prolonged use . This doesnt just cause Asthama it causes DEATH so should be treated with the respect it deserves .
As I've said I'm not judging or criticising its use BUT at the very minimum you should be using a suitable respirator FUll dust suit and goggles as it can be absorbed through the skin and even your eyes .
Like I've said i dont mean to judge or criticise just saying :-D
Cheers Mark
Look after yourself simon :-(
Thanks boys, I have been taking suitable precautions.
KW suspension on today with camber adjustable top mounts. Not sure about the camber business, seems a little hit and miss
try 5-10'' and 16st... LOL built like a brick shithouse yo! hahahah
simon, please dont die! lol wings look great though
Your 16st!!??
You don't look it dude, hide it well :unibrow:
haha yeah last time i jumped on the scales they shit themselves lol. i hope to god they were wrong! that was a couple months ago though, lost a little now.
cheers babes xxx
This is the only forum i know where practically every thread goes wildly off topic.
But since we're all sharing, 6' 1" and 12.5 Stone. Cool?
Indeed. It'll be a Vauxhall one in a years time :retard:
Um, yeah? maybe... ha! for sure it will. Got half term next week, so I'll have a good time to get it done. Welder Dodger was meant to come over yesterday to sort the exhaust. But I think Big Bear had a sore heed
Right, still trying to get the rear brakes to work properly. For those of you following, I thought I had the calipers on upside down, so yesterday I flipped them over. Turns out doing this means the rear handbrake adaptors won't fit and they foul the rear beam. So after yesterday, i had actually gone backwards, with parts off the car! So I'm going to keep the calipers on 'upside down' and have a third set (!!!) of rear hoses made, with banjo bolts so they don't stick down so far. I just hope this eventually sorts the problems out.
On top of this, I can't seem to find any nuts to fit the KW thread on the rear shocks. I have tried m10 x 1.5 and m10 x 1 but these thread pitches don't seem to be right :-( So I've ordered some m10 x 1.25 in the hope this is the correct pitch. Failing that, are there any other potential thread pitches to try?
