Another Build Thread
Yeah, all legal. It's a dog, slower than the 9n! Though it pulls so well, even in 5th! It's very very rich, and I don't think that's helping with power. Also the cam timing needs fettling as it's still a little out. It's fun, but still concerning as it's so much more noisey that the 9n
  • Replies 1.3k
  • Views 121.5k
  • prankstar2003
    prankstar2003
    Thanks Jake. Last few days I've been putting the doors up. Apart from a few small things it's done
  • prankstar2003
    prankstar2003
    Good weather (still) over the last few weeks means I've gotten the boards on the roof now. This will in time be covered in corrugated steel but for now it's reasonably water proof until I can get hol
  • prankstar2003
    prankstar2003
    Garage all painted (I'll get pics) and the car is moving in on Sunday. I may even get to work on it over the summer ;-/
Being really rich wont help at all, even the difference between 10:1 and 11:1 is ridiculous, part throttle.
It just tops out so early, and I don't think it's the gearing as i think I have the long ratio box with 'economy' final drive. It was struggling fo 70 on the dual carriageway. The RR of the wheels is smaller I know, but not enough to cause this problem. The torque is impressive mind, just pulls so well. I can take off in third and not know it
Yeah being rich part throttle sucks majorly, so sensitive to needles.
Guy at work has a bike engine in an MX5, and naturally pulling away is a bit of an issue with such setup, but just tweaking needle heights made a difference between just being able to pull off smoothly or having to rev it and slip the clutch and it bogging etc!
You going to take it anywhere for a setup?
I'll try myself and see if I can get it better than it is. If I want to fine tune, there's a place in Southam that Mark recomended. I don't really want to spend huge amounts as I'm looking to change engines soon. Who knows, I may yet go for an AFR.
Are needle heights adjustable with standard needles?
You have to put shim washers underneath them, though this is going to be making it richer.
My first set of carbs came with what looks like aftermarket adjustable platform needles, though these are not being used.
A mates car that i've set-up has been transformed the addition of 40mm longer slide springs, and a slight modification to the needles.
Get a wideband and do it yourself, its childs play!
Longer springs? Could the same be acheived with stiffer springs of the same length as the originals? Where did he get his bits from?
Cracked on with replacing the front panel today.
The damaged front panel (don't ask how this happened :roll: )
3D29996C-3BF6-4891-A897-9C1A8C91A6B2-414
8B2BB0DC-224B-4D23-AEA6-D8251AE9902E-414#
FF1D1FB3-E882-469D-B440-565E79D66732-414
Weapons of choice!
76EA3E0A-D647-41B3-9F13-24149CEA1160-414
And a very handy manual (although the actual positions of the welds weren't quite as described, hence the overkill on drilling on the middle brace!), thanks Mark!
DEB5BA83-B59E-4C6F-AFB2-633CF50A9961-414
Old panel off
E8F39563-5277-4C6F-B749-EEEACB80C3BA-414
And the old panel, you can see where all the spot welds were, close to 40 in all. Had to take a chisel to a few parts and bend it to get access. So much for minimal damage!
79633421-438B-4A8C-A1C0-F5EA05F5A595-414
AF193C6F-5840-408B-BC3F-E9352C0C1C5E-414
And the new panel. I'm sorry to say the quality is pretty bad. I ordered this back in september and it only arrived wednesday. To make things worse, it's been damaged at some point, bent inwards. A few stern words coming VW Heritages way come tomorrow
The dent/bend is clearly visible just to the right of the middle there
BBB51507-607F-4E42-9C39-CF43A25ACDD8-414
84248A7A-961B-4D05-90B9-8C8187300DDC-414
26BB4646-BE21-4A47-AC02-307C00BEFB3C-414
Not sure what to do about this. I'm reluctant to send it back as it's taken so long to get one. They'll probably say that it's to be expected as it's a pattern part (I oredered a genuine one but they fucked that up, so settled for pattern instead), but I wouldn't agree with that at all. So my other option is to take it to a body shop, get a quote to fix it and charge Heritage. I don't want to do it myself in case I make it worse and they refuse to do anything with it then. Grrrr!
Edited by prankstar2003
Bolocks to it, bought a genuine panel instead from a different supplier. Can't see me getting anything any time soon from heritage and I can't afford to be without the front panel for too long :-(
u sending that one back then?
tbh, could fixed the original by the look of it...
The original blue one, or repro? the original was all stretched under the towing eye. Really would have needed cutting out, shaping and rewelding. The repro panel is repairable, but there's no way I could get it perfect (which is what it needs to be or why bother replacing it) so that means paying someone to do it. By the time I've payed labour on that, I may as well buy a new one. It's as much the time as anything though. They've not exactly been quick sending this one, so waiting for another would have been out of the question. I've found one on eBay, so should be dispatched tomorrow and then with me early next week. That beats heritages 'up to 8 weeks' any day!
If plans go, well, to plan, I may have need for another front panel to chop about, so this one may do for that :ninja: as I'll want one to put it back to standard too
would you sell the new damaged panel Si
I'll wait to see what heritage say, I'd rather get my money back if nothing else as I'd lose out on postage if it needed sending. It's cost me in the region of £45 inc delivery and that's not a fair price to sell to you at, plus additional postage.
Although he doesn't offer delivery, I contacted him a while ago (whilst heritage dragged their feet) and he said he'd package for a courier if I sorted it.
I'll see what heritage say though Pete and get back to you if things change
yeah and thats my offer on the panel on ebay lol ;) quick delete the link before anyone sees ;p if he accepts hopefully i can pick up saturday as il make a day trip from sheffield while I'm seeing the misses and take her shopping in leeds
Done.
I'm actually going to Halifax on Sunday to pick up some wheels I got for a steal this weekend too. I considered going for the one in Leeds but couldn't be arsed fighting with city center traffic!
That is a long old trip for you aint it and what wheels
is this gooing to be done for UD mate I'm thinking about whether to go up or just stay home and smash some work on the car
No chance! Be lucky to be done for Early Edition/Springfest at this rate! Though I have Easter holidays between now and then. Probably start spraying panels in the next week or two. I was going to do the rear quaters etc and then panels, but I'm going to do it the other way now whilst I wait for the garage to be cleared in the next few weeks.
It's quite a drive yeah, but the wheels were only £20 in polo friendly sizes (14 x 6) as these are normally only seen in 13s or 15s and narrow widths. They are the wrong PCD but that's easily sorted. Keeping schtum about what they are though. Although they are not what you'd call a ground breaking wheel, they are rare (one set?) on a polo. I'm just praying the offset is ok :?
Nice work simon, bit of a shitter on the panel mind.
Do you think that panel would mate up to a mk2f front end?
Nope, totally different shapes. There is no panel behind the 2f bumper is there? Or at least it's not so big.
New panel on the way, so won't be put too far back due to this now. Hopefully. Need to get my paint ordered now
i won that panel Si £25 bargain now just to collect and drill the shit out of it lol
I dont mean fit straight on! :lol:
I've been umming and arring about doing something different with the front of mine, and wondered if that panel would mate up ok, would obviously need some sort of bracketry to hold it!
would have to chop and change the front of the wings too Max
What front wings? :lol:
Excellent Pete, that was a bargain.
And Max, I was begining to question your sanity!
Well Heritage said they will replace the panel for no charge, but it won't be for another 3-4 weeks. So I'm glad i ordered the genuine panel now. I'll make use of this one at a later date :ninja:
