fast gt's
True true....
I think it'd have to be forged to run that sort of power reliably and would need standalone management which would be extremely costly!
I guess it's an area that isn't very well covered and therefore people aren't willing to tread... an just go G for easyness!
I say.... do it toby! haha
  • Replies 72
  • Views 5.2k
Its a possibility in the future. If i haven't moved onto cars with real power *cough* fords *cough*
fords and power just shoehorn a pinto engine into the polo tobes lol
why piss around with engine conversions when you can just work with what you've got? the 3F lump is a good enough engine tbh...
Its just the 1272cc engine which has already been stretched by VW with a high compression,mpi and one of the most sporting cams they've ever fitted to a VW, just to get it to 75bhp.
As standard its a spirited little engine which can be mildly improved upon,but the basis to set the world on fire it aint got.
Hardly the 100bhp 1.3 the Peugeot 205/106 Rallyes got as standard.
The 3f lump is probably one fo the most unstressed engines of all time- remember this is essentialy the same bottom end as a G40 minus the pistons, rods and crank reported good for 300bhp. Try and get that out of some French tinfoil!
Main reason why people don't boost the later AFH and GTi 16v motors is the bottom end. Look at any serious German 16v Turbo/Supercharged build, and they've all got uprated rods (£500+), forged pistons (£500+) and usually steel cranks (££££). Which, in turn then makes a G40 motor look very good £/bhp.
I've got a power curve from a G40 at 223bhp- I'm aware of a boosted AFH which is far beyond this, but has cost approx 4 times more...
As for 3F tuning- we've got a map that will give good increases with just a 4-2-1manifold, breathing mods and de-cat, just under 100bhp, I'd expect a healthy engine with a 268/268 cam to make just over that.
I ran an 80bhp shot of nitrous through my 3F with mods to the ignition system, ran a 15.3 at Santa Pod like this (although it was missing), probably had a high 14 in it, which is good going for a n/a 1.3!
All it has in common with the G40 is the bare block then? I've heard it reported that even that has thicker cylinder walls on the G40.
100bhp with head work and a well sorted exhaust,quite impressive. The Pug managed it from factory with a catalyst though.
The GT is old hat,as is the G40,both long replaced by a Polo engine that drops in and made 125bhp with cat in standard factory form in the way of the Polo 1.6 GTi engine. No charger re-builds,no problems with the MoT, plenty of low mileage examples available for a few hundred quid.
Sure,if you want big power from a short block,like 200+ then a highly modified G40 has a good argument.
But not the GT for any value,when AFH's have 100bhp in factory spec - with catalyst - for the price of a GT Piper cam or stainless tubular manifold.
R5GTT? seen them tuned to over 500bhp, tbh i don't think i've even seen a G40 any where near 300bhp, never mind a 3F engine
if you really want to talk about under stressed engines the saab 9000 2 liter turbo engine has to be way up there, it's proven good for 500bhp on stock internals and still reliable, in standard guise they are about 170bhp iirc?
the only 'internal' modification on that engine are volvo t5 valve springs
Edited by McLOVIN
Saab motors are bloody strong- but if it's 170bhp stock, then a 300% improvement gives 510bhp.
Polo GT Lump (for arguments sake gives 300bhp with turbo) is a 400% increase (this is cheating slightly as 3F has different casting to PY and the webbing is different in the block)
The R5 motors are impressive- but you won't see many (if any) with stock internals at those power levels. Check:
http://www.rtoc.org/cgi-bin/leader_board.cgi
Some very impressive cars mind.
100bhp can be done on a 3F without headwork. I'm not saying this is best bang for the buck by any means, but if you've already got a Polo GT, and a few hundred quid to spend, then a nitrous system and 3f motor will see off any 16v AFH/GTi motor purchased for the same amount of cash, and alot less effort.
The original topic is about 'fast gts' not fast GTs with 16v engines in :lol:
where are these 300bhp gt's, and how many of them run standard internals?
Edited by McLOVIN
No 300bhp GT to my knowledge- but same rods/crank in some G40s over in the father land running close to 300 ponies.
My engine is 223bhp with a stock bottom end bar the pistons. Original engine is 75bhp, that's a 300% power increase with stock components.
VW did an imrpessive job- you can't knock that. Even more impressive if you consider the base engine was designed before the PY/3F came about, and they only had circa 50bhp in mind.
I'll ask this in here
Most cam makers (piper/schrick etc) make a 268 for the GT
Why is it that catcams make a 269 for the GT?
I'm considering either, probably whichever i can get for the cheapest. But, what's the difference in terms of power, usability and where the power is between the two cams
Anybody had any experience with catcams?
I'm guessing that an Abd/gt is a Abd bottom end with a 3f head? How does tht compare to a afh bhp wise and difficulty converting a mk3 polo?
ABD is a 1.4 8v golf bottom end (or whatever else it came in)
No difference in power i dont think, its just more of a torque'y lump.
Straight swap, everything is the same as a 3f bottom end.
It even uses the same head, minus the GT cam and possible double valve springs.
Literally plug n play? Or different looms. Thanks for info :D
Bottom end doesn't have anything plugged into it?
So yes, same loom :lol:
Lol I was thinking maybe I could Just change the cam instead of swapping the complete head but didn't put it down :D & would it still be pretty much the same to bike carb the abd
Yeah, you could just swap the cam tbh, everything will be the same.
I nearly ABD'd mine, it may still happen at some point. From what I've heard its a good engine running bike carbs, just not as revvy as a GT is.
so you can get a 3f lump up to highly tuned py power on standard internals? Surely the pistons would need changing at the very least (isn't this how the 3f gets it's boost unfreindly c/r?).
is it just a case of fitting py pistons into a 3f to make it fit for boosting?
Different pistons guy.
Pistons- are different
Crank- in my experience I believe the 3F crank is cast and the PY is forged- the turnings when lightening them are very different, journal width and stroke are exactly the same as G40, again weight of the 3F is slightly more compared to the PY, I've got the drawings for both but neither have material spec, I'm no metallurgist either so I can't tell 100%.
Rods- I've only weighed one set of each, so not really a good cross section, but 3f lighter than PY, both the same big end specs and little end, wrist pin same spec and rod bolts the same with the same torque on all mains and bottom end fastenings.
Block- Webbings visably different on PY to 3F, obviously provision for a knock sensor on both, but only drilled/tapped on PY, I've never understood why it was on the casting of the 3f block- I'd like to compare a Mk2 PY block to a 3F and PY. Cylinder spacing, wall thickness and cooling jackets all the same, no oil jets in either, fitted to the 1W though.
The rest- oil pump, bottom end fastenings etc all the same, head bolts for G40 1mm shorter (and alot more expensive from VAG).
To answer your question- yes, 3F with a change of pistons and knock sensor is boost friendly, G40 block did have a drain feed for the charger, but you might not need this (eaton/turbo etc).
Hope this helps,
Yoof
yes so what i was asking was are the pistons the only thing stopping a 3f from running boost? if i stick some PY pistons in a 3F is it now ready to strap a turbo to it?
EDIT: posted this before i saw yoof's post :lol:
Edited by McLOVIN
Around 400bhp is more like it for the 2.3 litre B234 motor in the 9000, much more and they do tend to throw rods, spin bearings and hole pistons. The 2.0 litre B204 motor has a reputation for liking to rev a lot more, but it's no stronger. I'll let you know how weak they are in a year or two when I finally get around to strapping a massive turbo to one of my Saab motors.
The newer B235 motors in the 9-5 are much weaker though - much like VW did going from Mk3 to Mk4 Polo engines, the bottom end (particularly the rods!) got a lot lighter and therefore weaker making them less tolerant of massive tuning.
Anyway, back on topic - Polo 3F motors... 8-)
S'all about the 1272's
the graph i posted was from a 2.0 lpt the spec for it is
holset hx35 turbo
630cc siemens injectors
3 bar map sensor
2nd hand walbro 255 fuel pump
sachs uprated clutch cover
aero clutch plate
used 3" jt mild steel exhaust
he's currently fitting this and aiming for 550bhp
Yup- having said that, here's a pic of a 3F motor (fully stock) just with a different inlet and turbo bolted on the front. Hasn't been run yet, so I don't know how reliable it actually is.
8-)
Boost on a completely stock internal 3f ?!?!
