fast gt's
Now this interests me...
  • Replies 72
  • Views 5.2k
Yup
My take on the engine choice debate...
If you've got a non-GT engine'd Polo:
Cheapest way to 100bhp = AFH on original injection
Cheapest way to 140bhp = 1.6 AFH on original injection (as per Jez's original 1.6 AFH build)
Cheapest way to 160bhp+ = G40 motor
If you've already got a GT and you want 100bhp, spend £250 on a secondhand nitrous kit and fit some 50bhp jets and go rape some AFH'd Polos.
Or you could fit a higher rev limit chip and a filthy cam and get the power that way... The 100bhp GTs I've seen generally have had an aftermarket, but still fairly mild, cam and a 4-branch manifold along with a decent chip to suit. I'm sure with something lairier than 268deg you'd get more power.
Around 400bhp is more like it for the 2.3 litre B234 motor in the 9000, much more and they do tend to throw rods, spin bearings and hole pistons. The 2.0 litre B204 motor has a reputation for liking to rev a lot more, but it's no stronger. I'll let you know how weak they are in a year or two when I finally get around to strapping a massive turbo to one of my Saab motors.
the graph i posted was from a 2.0 lpt the spec for it is
holset hx35 turbo
630cc siemens injectors
3 bar map sensor
volvo t5 valve springs
2nd hand walbro 255 fuel pump
sachs uprated clutch cover
aero clutch plate
used 3" jt mild steel exhaust
he's currently fitting this and aiming for 550bhp
He'll probably make the power, but I doubt he'll be able to do 10,000 miles before the bottom end shits itself if he actually drives it in that state of tune. Actually, scratch that, the gearbox will shit itself waaaay before then, lol. They're made of the same chocolate as Mk4 Polo 'boxes...
There's a guy on one of the Saab forums with around 700bhp from one, but rods and pistons aren't standard and neither is the cylinderhead/valve train. Big dyno numbers are possible from most motors, but reliability and driveability are much more difficult to achieve.
Block- Webbings visably different on PY to 3F, obviously provision for a knock sensor on both, but only drilled/tapped on PY, I've never understood why it was on the casting of the 3f block- I'd like to compare a Mk2 PY block to a 3F and PY.
The early AAV engines also have the provision for a knock sensor - but later AAVs don't. The later block casting (at least on the AAV) is different in a few places on the exterior. Not sure about the interior. Perhaps the same applies for early/late 3F engines too.
Andy the 1.6 AFH - mk4 1.6 bottom end, or mk5 gti bottom end?
Yup- having said that, here's a pic of a 3F motor (fully stock) just with a different inlet and turbo bolted on the front. Hasn't been run yet, so I don't know how reliable it actually is.
it will be interesting to see what happens with this, there are always threads being started about this sort of thing but the answers always seem to be that the C/R is too high and it would cost too much to get the engine strong enough to take boost. they then get told to buy a G40 instead :lol:
gti bottom end, afh head :thumbsup:
GTI bottom end IIRC
A mates doing it to a valver atm, running on TB's and some pretty savage cams.
I'll ask this in here
Most cam makers (piper/schrick etc) make a 268 for the GT
Why is it that catcams make a 269 for the GT?
I'm considering either, probably whichever i can get for the cheapest. But, what's the difference in terms of power, usability and where the power is between the two cams
Anybody had any experience with catcams?
Anybody? lol
Also, whats the lairie'st cam you can get away with before having to fit a vernier pulley etc? I've also heard valve/piston contact (or something along those lines) being a problem with some cams?
Hmm, inneresting... haven't been on here in months but been hovering for a week and already building up specs in my head haha. Ah well we shall see eh.
Strong work on getting that mk3 pretty much laying frame, its a real ballsy effort!
Could you run a gt inlet and injectors on an AFH and the just get it mapped to run right? Or is that why people use bike carbs?
The 8v and 16v engines have both different inlet and exhaust posts so the manifolds aren't interchangable! I'm also interested to see how yoofies turbo gt goes,and agree the afh bottom ends are fragile and wouldn't in standard form take kindly to masses of boost
Can't remember who it was but a member on here is running an AFH on a mish mash GT/AFH inlet and GT injection system and ECU iirc. Was also running unmapped but running well according to the owner.
Looked nice and tidy in the engine bay too.
Is it Yoof's project or someone elses?
Not mine- it's Dave's (built bike engine'd derby) well, it's now his friend who's got the engine in a Mk2 loon.
He was in paractical classics? or retro cars i think (some magazine like that)
With a garage full of porn haha!
Was a unit shared with a few mates i think. Load of oldscool VW's
Retro Cars. His latest Mk1 Polo project is in the pics, but not mentioned in the text.
I had a chuckle at all the Polo "Coupes" they kept talking about - they all had boots!!
Yeah, i saw the MK1
Was a MK3 in there somewhere too iirc?
Its all about the ha engines tbh :lol:
yeh the guy did, again i cant remember his name, but it wasnt just a simple bolt on solution, required some inlet manifold bodgineering
i wanna know how long the standard internel'd 3f turbo runs
What is the spec on a factory GT cam? any one know?
Also just came across this, thats a pretty heavy 8v motor!
http://www.servimg.com/image_preview.php?i=67&u=11029504
Edited by popdragin
Geez I'd like to know how much that engines cost :/
