polo GTI or TDI help
I know how diesels drive, I drive them all the time, if a car revs to 4k then it's boring! Regardless if it pulls, you want to hear a nice noise,
When I say numb that's not saying slow it's saying numb how when you boot it nothing happens then you get the torque then it runs out then you have to do it again, I hate the power delivery of diesels.
If your willing to travel to me I'd more than happily go out in your jettta, then I'll take you out in the G as an exchange gift :)
I've driven plenty of diff diesels and they are impressive considering the way they have developed lately but I'm still never going to own 1 as a performance car, the 335d twin turbo could break my neck with the power and that's for reall, there one hell of a machine! YouTube the things and see how they pull, it's un reall
  • Replies 61
  • Views 5.5k
I'm with you on the type R thing too, there is such thing as to much revs I guess, although Vtec is a great bit of kit I think the way there so quick is because of that rev range! A 1l saxo would go through 2 gears by the time a Vtec has to change, they go for so long with out changing gears! I would say I like changing gears but I'm just about to go SMG so I'm trying not to think about it :(
mate i hear plenty of noise, any one on here that experianced my jetta will back me up on that lol, have you ever heard a turbo with no air filter about 2 foot away from you spooling up to over 35 psi? :lol:
even with the bulk head in the way it sounds like a 747 taking off, add to that the straight through 3" pipe and you have all the noise you would ever need.
i've driven plenty of diesels as well and non of them drive like my jetta does now, maybe it's because these were all modern tdi? i'm not sure, but unlike the others i've driven mine doesn't get to it's peak power then drop to nothing, i can and do ring it's neck, it behaves more like a petrol in that even after you hit peak power it does still pull, just not as hard (just like a petrol does). maybe it's the way it's been tuned and the fact they don't have an ecu controlling every thing, instead using a mechanical pump that is easily manipulated to change the way the car drives and how it delivers its power. it used to drop off like others before i hit it with the tuning stick and modified the diesel pump, but now it's getting more fuel than it needs all the way through the rev range, and all the boost it needs to burn it off... and then some :lol:
"if a car revs to 4k it's boring" that comment is right up there with the one saying 'diesels have no power band'
there are tuned v8's putting out over 300bhp that reach peak torque at 4300rpm and peak BHP at under 5k, but i guess that would be boring due to not needing to rev the balls off it to get into it's power band :roll::lol:
also this makes 1550lb/ft of torque at 1600rpm, so going by your theory it must be almost impossible for the driver to stay awake through boredom when driving it :lol:
saying that a car will be boring because it doesn't need to rev very high is just small minded and slightly stupid imo, it sounds like some bollocks some one that knows absolutely nothing about car's but owns a V-tec would say to try and argue how amazing his car is :lol:
if you drove a car that didn't have a rev counter meaning you didn't know what the engine reved to or where in the rev range it was... how would you ever know how fun the car was? :shock::lol:
i don't own a td for a performance car, i own it because i wanted cheap fun motoring, which i have got. i still own petrol's and enjoy driving them, but i also enjoy driving my diesel, all car's deliver power in different way's, no matter what fuel they run on, so all car's need adjustment in your driving style to get the best out of them.
Edited by McLOVIN
nutter :lol:
Edited by leonh
I didn't say it was boring when the torque kicks in I said the diesel engine in general is boring, the amount of them I drive makes no difference regardless how fast........I find them boring, changing gear all the time and having no nice noise and no nice redline,
I'm not saying there not impressive and they do shift but regardless of what anyone says changing gear The time and not being able to meet the maximum revs in gears and not being able to scream doesn't appeal to me, your jetta might be different I'm not sure and if it's what you say it is then you must drive all these other diesels and get the same feeling,
I'm not aiming this at your car I'm aiming it at the general modern tdi,
One very annoying thing is how naturally aspirated petrols always get compared to turbo diesels, lets compare a n/a diesel to a n/a petrol or a turbo petrol to a tdi, and see which is considered better.
that's because turbo diesel's in general are designed as an alternative to a n/a petrol :retard:
the newer 'sport' tdi's are designed to be more a an alternative to the turbo petrol's but for the most part tdi's were just a sensible man's n/a petrol. they weren't meant to be quick, they were just mean to be more drivable than the n/a diesels and thus, make them more spellable. comparing an n/a diesel to an a/n petrol isn't going to happen they were both designed for totally different purposes and totally different markets.
you said if a car revs to 4k its boring, what else were you trying to say if you weren't trying to say that any car that doesn't rev high is boring?
just out of interest what sort of charger is your G running? :paranoid:
It's just me, I love to make engines scream and a 4k redline or there abouts to me is like doing Megan fox with ear plugs in........I want to hear that bitch scream lol
It's running a Ported R1 spec at the mo, was going to go down
The eaton root but the thing is too brutal for me now and fancy
A change so I'm just going to get rid :(
Who says you would be good enough to make her scream?
Don't think it would go that far, I'll be done the moment she takes everything off :drool: lol
You're a better man then me, I am done as soon as i see her on that bike in transformers 2 :drool:
At 0.05 secs!
