Popdragin's MK3's
Rich, your nothing but a cheap hussy every one's had a touch of you!
I've got a few things on the fuel and air side, aswell as a G40 exhasut system. Its currently running a CL system.
The T/B is totaly stock, do have a de wedge butterfly to go in, is it worth porting or fitting bigger butterflys?
  • Replies 59
  • Views 9.9k
I wouldnt go swingin wi your little white slag!!! :lol: shes not mature enough for me :-D
owt new going on pal???
HAHAHA, thats what i heard about you!
Few pics, started building new engine,Doing what i do i thought i really ought to have a balanced bottom end,
So i picked up a GT bottom end on the way back from the RR day, also a rather ill G40 bottom end(i'd heard a rumor that they have steel cranks)
G40 block
Damaged piston
The two differnat cranks
Not Sure which crank i'm going to use,probly the GT crank as i want to remove a fair bit of weight and keep the G crank for a latter project!
That piston.. I love how you say 'damaged' asif its minor :lol:
I was jus guna file some new rings and stick it back in :p
Who is Noel Fielding anyway?
I'll introduce you tommy!
Sweet man, I want to experience his skillz.
His skull skilzz?
  • 4 years later...
Hi mate digging out an old post here any difference in the crankshafts between gt and g40?
