Mk3 polo's
I got mine for free of my old man, 1lt genesis breadvan and over the course of 45,000 miles it's had fuel tank, water pump, rear wheel bearings, cam belt, battery, gearbox.
It now needs Dizzy cap, Rotor arm, ignotion leads and i think it needs new front wheel bearings.
  • Replies 27
  • Views 3.1k
If you concerned about it being mega slow and insurance friendly why not do some 'invisible' mods
1ltr- 1.3spi throttle body and matched inlet plenum, a chip and a full gt exhaust including the manfiold
1.3spi- Just a chip and gt exhaust system
Both make a noticable difference over the standard engine. I've had both of the above and both are good fun. Granted its not as fast as a gt (not a world away either), but the above mods will cost you around £40 if you search carefully, dont recall a gt setup being that cheap.
As for actually buying the polo id say buy the best looking standard one you can and do any modifying yourself. I've found some things on standard polos i didnt know were there having previously brought a modified one.
Always check the chassis legs, battery tray too, Jacking points, sills, arches. Even if they are solid with some cosmetic rust its a good bargaining point.
If the owner doesnt mind then you can take off the drivers side rear door card with nothing but a phillips screwdriver. Id be amazed if the fuel pipe cover hasnt completely rusted away, this can lead to rust in the rear quarter that you cant see from outside.
Edited by shaun_89
first negative comment :o
just buy a mk2 and convert it to GT mk2's are way cooler 8-)
