1986 golf GL with PB power
OK I know I've had this for sale before and changed my mind but now its running and I want something more modern and nice to drive so this and the Felicia are up for sale so I can have a nice daily and more importantly just one car!
Here's the spec list;
1986 D reg Jade Green 5 door GL with lots of chrome, non sunroof
Shell has approx 104k on it
8v Digifant GTi conversion
All looms swapped, fully functional MFA
Front electric windows
P slots
Lowered 60mm on matched supersport shocks and springs
GTi exhaust with twin polished GTi backbox
Half tint rear lights, smoked side and front indicators
GTi seats
Jetta GTi blue suede door cards
Golf ball gearknob
Early GTi 4 button steering wheel with jade green vw badge
GTi rear beam (needs fitting) drum rear axle is on currently
MOT till mid-May 2011
Tax just out
Very solid shell
Headliner is spot on
Bad bits;
Dent on front passenger side wing and passenger rear door, might pop out
Side repeater and front indicator need bulbs
Dash lights not working, have loads of bulbs to be fitted, might even do this myself
Electric windows need re-wiring as the GTi the loom came from had manual windows, fairly easy to do, have an easy to read wiring diagram for this, just needs a fuseblock and a few metres of speaker wire to do this
Front brakes are still the 1.8 carb items (solid discs), just needs vented gti discs and pads to be fitted, no mods needed
Exhaust is blowing from 2 joints, needs clamping up correctly.
Clutch slipping a bit due to my greasy hands on it, it did have plenty of meat left on it, a bit of use should see it alright, its only done about 2 miles since I did the conversion
The car is perfectly drivable as it is, all it needs to be perfect is the small jobs mentioned above which should only be a weekends work, also have the gti disc rear beam to fit and a new 16v master cylinder, and a shedload of spares which can go with it. The car is in Lincoln and I'm after £500 for it as it is or £550 with everything I have with it, including rear beam, 16v MC, lights, grille, PB engine block, spare engine parts, alternator, and lots more.
Here's some pictures, also got loads of it during the conversion if you want them.
  • Views 196
