Those with "Old School" Polos.
My mk3 is not my daily and is constantly annoying :lol:
  • Replies 84
  • Views 6.8k
i drive my MK2 everyday since i passed my test (late october) first problem i've had is this weekend where my electrics have been a bit...... off...
My mk3 is my daily, it's the most bumpy, rattley, loud and even least reliable car I've ever driven, but its my favourite out of any of them. I borrowed a 57plate punto a year or so ago, and it was far worse to drive, no feeling to it at all, and I actually felt more comfortable sitting in my little mk3.
And as for breakdowns and things breaking, I'm no mechanic but I will always try things myself, and usually on a mk3 as long as you have some common sense and a haynes, nothings too hard to do yourself.
My mk2 gt is a daily.... used everyday in between engine conversion and respray and is brilliant... only now when I've stopped using it due to no job has problems started happening... like leakiy radiator, busted alternator, heated rear window not working, fan only works on number 3.... most I've sorted but they are things that are gunna go on a 165k engine....
Try driving a 1968 Wolseley Hornet for 7 months solid with no carpets and drainage holes in the floor (alot of road noise), not to mention it filling with water every time it rains and has ice on the inside of every window in the winter, with a scary max speed of 75mph (at a real push with your eyes closed) and doing roughly 34 miles a day to work and back.... then you will appreciate the 80's cars lol coz man the polo is a Roller compared :D
My mk3's a daily at the mo but I'm considering putting my 16v back on the road purely because the seats are comfier lol
my first car, it's bumpy due to the worst suspension i could ever have, rattles a fair bit but thats, again my fault for letting things get loose.
reliability though... never ever gone wrong, and all i've done is service the thing. 30k in 18months and as you do with first car, simply abused it and its still going strong as ever.
8-)
Put some different seats in and 16v the bready.
I'm not sure how many times I'm going to have to tell you this Dan, but i shall continue until you see the light hahaha!
I kinda use mine as a daily, id say its reliable. but i dont need it to drive to work so it makes no difference if it breaks
Its had 2 of the most common faults go on it (5th gear and hall sender) but its on over 110K now so its to be expected i think.
I'm struggling to understand where all these reliability problems are coming from? My Mk2 and Mk3 Polos never had any issues at all, the only fault of either was the head gasket on my Mk3 when I detonated the head gasket by playing with the fuelling and timing... Up until it failed it's MOT on trivial things and sat for a few months, my Mk2 GTI has been totally faultless as well and it's on about 150k or thereabouts.
I'm thinking about getting another Mk2 Polo but it definitely won't be a daily... Hillclimbing instead.
Exactly, people get the assumption that mines un-reliable.
Its not, its just me constantly messing with things and upgrading that causes it to be off the road so much haha.
I used to have a mk2 bready that i used as a daily and i loved it. Thinking back now, i think it may have been because it was my first old polo and it was quirky. I've now got a mk2 coupe and to be honest, it does bother me quite a lot as a daily. i find myself wishing i had a normal car quite alot now, may be because the mk2 isnt working due to alternator and fuel pump....
My mind may change when I've got my new engine in it and refined it a bit more.
I've had my mk3 3f for three or four years now and it's been used daily with now problems whatsoever (all bar me shredding a cv joint and boot by playing with it in the snow at -6 degrees) :lol:
BERG CUP STYLEEEE!?!?!?!?!
My first Mk3 1.0 I owned for months without issues, even passed an MOT needing very little, it only shat itself when I was silly and advanced the timing too much on the GT cam. But that was my fault not the cars.
Then I had a Mk3 GT sometime later, it too was no hassle. Got a few sensor issues but they were sorted when the offending sensor was unplugged and the car continued on its merry way. This was the GT that was sadly crushed in a terrible accident involving a Merc in 2009.
Shortly after that I bought a Mk3 1.0 with a failed HG. Drove it 150miles home just having to top it up with water a few times and then it got used as a farm car until the engine came out to make way for an AFH. The project never really made progress so now Andy (Polo6n1600i) owns this car and its currently running a GT.
So far then no all these Mk3's haven't annoyed me...well I was annoyed when my GT got crushed and I still want another one, but they themselves haven't annoyed me.
My Mk3 G40 I have just now though does annoy me, simply because it is constantly starring at me from my drive saying "Fix me!" but it needs so many little things its hard getting the motivation to do it...but I will!
i drive my 1 litre mk3 loon everyday moved from a 1.4 6n to it and it was the best decision i've made :-) i love driving it . had only 1 problem of the exhaust falling off but thats it so far. only been driving it for 3 months though
use mine as a daily driver had it on the road for about 4 months so fat the clutch cable went twice as the replacement was faulty, my alternator packed up, fuel tank started to leak (because its to low), sump gasket has gone, crank oil seal has gone, and there probably is other problems. and before that i did the headgasket and had to give it a full respray. but its such a nice car to drive it sticks to the road like glue but the suspension is solid but i think it effects the passengers more as there not used to it, but its never overheated the hottest it got to in bad traffic was 100 degress which isnt anywhere near the red (Y)
use my loon as a daily and its fine you get few problems but that can be true with any car but rather drive that than my old pug which was 15years newer more comfy but not as much fun and evey time i drive the loon is an expereince going buy a passat so i can rebuild it though not lookin forward not driving it everyday
27 year old golf. Pisses me off daily, but soo easy to work on and repair. It's a 1300, so nothing complicated at all. They do your head in but i'd miss the querk if i shopped it in for a modern diesel.. although I'm getting ever more tempted to buy a caddy van.
haha i recently did the opposite lol i sold my van because i couldnt work on it its all sensors and wires and computers, i liked it but the golf is so much easier and cheaper to fix/mod than a 6n or a caddy
I've ran my Mark3 daily for the last 6 years, covering 70k, and not had any major troubles. The hall sender once went, but was kind enough not to leave me stranded anywhere, and I've been through 2 clutch cables with them snapping, but other than that can't fault it.
Just pay it a bit more attention than you would a more modern car, carrying out prventative maintenance as well as regular servicing, and I can't see it giving you any issues.
My GT has been great,
most people on here that moan about them being unreliable have modified them. an arrogant opinion i know but after owning a modified GT before i found that all of my problems were self inflicted. you cant beat a good standard mk3 if you want reliability.
As Karl says, maintenance is key.
Edited by jay135
Hehe, not quite. Reason for choosing an early Polo is that they are narrow enough for the climbs I'm thinking of doing, certainly not gonna be making one wider! In effect, the car will more than likely be very close to standard bar a bit less weight and some carbs.
the '09 pug has been no benefit over the Polo in the harsh weather - but for a thermometer readout on the dash,which i take with a pinch of salt anyway.
but without the temp readout how are you supposed to know if its cold and icey!!!??? :ninja:
those of you that dont like driving a mk3 daily must be seriously homo.
i used to drive my beetle daily and loved it, apart from the lack of heaters.
my mk3 polo is the most fun daily iv had. iv had a 1.8gt2 rocco, 2.1 wbx type 25 van, a 2 litre aircooled beetle and I'm afraid to say a 1.4 zetec fiesta over the last 6 years or so. my 1.3 spi mk3 is by far the best daily. fun to drive, heaters work, good on fuel and you actually drive the car, it dont drive you... unlike moden cars.
mabbo
got to admit my genesis is the best car iv had out of all of them and thats quite a few iv had! when i got it i thought this is guna be a laugh but iv fallen for it 4 speed all the way :lol:
Correcto here jay.
I've had many modded GT engine cars and they have all had problems.
where as my stock GT i got was near perfection bar worn parts which is to be expected.
been driving my mk3 coupe since november (i think, can't even remember when i passed my test haha) it needs a new thermostat which seems to have lead to the headgasket being slightly worse for wear and means it leaks a little bit of oil and burns a little bit of coolant. it's got 127k on it, and so far i've not had any problems. other than today going to college when one cylinder wasn't firing but that was just moisture and after a bit of running it came back to life. and there's when a lead slid against the fan and scared the absolute shite out of me with the disgusting noise it made which carried on when i turned the engine off making me momentarily bewildered haha. but that's not an actual fault, so yeah, mine's fine so far despite being ever so slightly knackered :D
