Help me shop
its all opinions at the end of the day, mtx is really good value for what it is, and acky wants nice sq, which i think will be great from focal, focal subs are really nice musical and fresh bass IMO, anyway he's already bought the mtx/focal stuff so..... :D
  • Replies 165
  • Views 50k
so you're telling me Genesis amps matched with Resonant Engineering components and sub wont sound just as good ? if not better ?!!?
no not at all, but the focal/mtx setup is just a different setup, nothing wrong with either of them, its just opinions. you are realy argumentative arent u foxie!!! :lol:
yep 8-)
the mtx focal setup will sound mint though
fuck it I cancleled my order and re instated it with 1k's worth of sony explode subs and amps.....
:lol:
noooooooooooooooooooooooooooo
thats a fuck load of shit for £1000 :| id rather go to the farm and shovel some pig shit into my boot.....
What about a genesis amp to power both the sub and components?
what about: hes already ordered the inferior MTX amps........
I am joking dont worry. :D
Anyone got any advise as to what thickness of wood I should use for the box and false floor etc?
The guy in the shop said they will be more than good enough.
Only the test of time will prove that.
this thread is a bit hard to follow, the sarcasm etc. doesnt come accross on the interent.... :lol: oh, the confusion, yer just get like 6 x-plod subs, they're 1000watts!!!! weeeeey better than that shitty focal or wotever it si, thats like 300watts or sumthin, how shit!! :lol::lol:
I could be wrong but i think its 12mm mdf usually used for boxes, but I'm not 100% as i have never made one.
cant really say what wood to use for your boot build as different wood for different jobs, ask a woodyard or something when you get round to making it.
12mm ??? :lol:
18mm MDF for a box no less.
for false floor... whatever really... 12 or 15mm MDF will be adequate
:lol::lol: foxie, if i ever see you, I'm gonna slap you in the face!!! :lol::lol:
Yer, i used 15mm for a false floor, over time it bent.....so supposrt it well or use thicker.
Haha Love this thread!
Ok no worrys I'll speak to the guys in the shop anyway,
Think my idea for the build has gone down the bin cos of the sheer size of the amps. :(
Might make them covered totally with some cooling fans, then an automatically opening cover for when you need access to them.
It opens by passing your hand through a laser which when broken releases the magnet which holds the spring loaded cover. How I'm going to get that to work I'll never know!!! :lol:
Probably wont happen but it was something to think about when I was trying to sleep.whether thats dedication or pure sadness I dont know. :D
:lol::lol: good idea that!!!
nice to see some very constructive replies in here :roll:
Acky, good decision to upgrade to the 4002. Always nice to have moer headroom at the front, I suggested the 3002 to keep it within budget but 4002 will definately be an improvement. 8-)
When it comes to the install theres a few things to bare in mind.
The majority of people tend to install components in the "traditional" way which is tweeter up near the A pillar and midbass in the OEM location in the door. The general reasoning behind this is to raise the sound stage to the base of the dashboard and provide a more direct image in front of you.
Whilst there is nothing majorly wrong with this, you will be enormously better off if you take the time to build a set of kick pods and place both the mids and tweeters in there. Raising the soundstage is all good and well but seperating the mid and tweeter by a big distance usually will make the system VERY weak tonally and THATS where the misconception lies. On a generic level kick pods can keep the soundstage just as high with proper aiming and auditioning but more importantly they provide a point source keeping the music cohesive and tonally accurate. They are gerenally more likely to feel more complete accross the frequency range without many gaps whereas split systems often have a hollow gap in the middle of the frequency range.
With regards to the focal components this is particularly important for another reason. Some people say that focal tweeters are slightly "harsh". I disagree! They can be a little bright but by having them in kick pods this increases path lengths (the distance from the drive unit to your ear) resulting in a more balanced sound. On top of this whilst the focal mids will run comfortably in the door, they will sound much more dynamic and punchy in a sealed kickpod.
The most important point that no one has made is pay attention to the install itself. I have heard installs with £700 worth of kit sound better than systems with £3K worth of kit simply due to the level of attention taken when the the system was built. I cannot begin to stress how important this is!! TAKE YOUR TIME AND DONT CUT CORNERS
sound deaden as much as you can afford, particularly in key areas (door panels, boot floor, boot lid etc)
I'm bit busy at the moment but will do a proper write up setting up and other bits when i get a mo. If you need anything else drop me a line :)
Ta
Faz
Bit busy and you write all that? Ha.
Cheers again mate.
When you get a min can you explain kick pods?? Is this just having both speaker and tweeter in the door???
When speaking to the guy fromt he shop he said you could spend 90quid on wires etc and have great sound, or you could spend 160 and have totaly superb sound. Is he right or just trying to get more money of me??
Cheers again mate.
Example of Kick pods:
The two drive units in the kickwell in the little red fiberglass enclosure are in a kickpod. check out www.talkaudio.co.uk FAQ section to get an idea of how to go about building them. Also there are a lot of people on there who can provide some pretty decent advice.
As for the cabling, a decent 4 gauge kit will be enough although you will need a fused distribution block as you will be running two amplifiers.
What you will need in terms of cable and distribution:
1 Fused distribution block - either AFS or AGU fuse type (1 4gauge input, 2 8gauge outputs- anything more than this is a bonus as it allows for future expansion but not a requirement)
1 ANL Fuse Holder
5 meters 4Gauge power cable (from battery to fused distribution block)
2 meters 4Gauge earth cable (from chassis to amplifiers)
2 meters 8 gauge power cable (from fused distribution block to amps)
2 meters 12 gauge speaker wire (for subwoofer)
10 meters 16 gauge speaker wire (for front speakers)
2 x 5 meter RCA cables (from head unit to amps)
5 meter remote cable (from head unit to amps)
looks like a long list but you will find that you can get a wiring kit with most of the stuff that you need in it for about £50ish and then buy the fused block/fused holder seperately. £100 should MORE than be enough for this.
the following items combined would cover the whole lot:
fourth one down the page £54.25
http://www.nexxia.co.uk/CarInstallaccessor..._wiring_kit.htm
ANL fuse holder £9.99
http://www.caraudiodirect.co.uk/product_in...roducts_id=1521
QX 12Gauge Speaker Cable - £1.29 a meter x 10 =£12.90
http://www.caraudiodirect.co.uk/product_in...roducts_id=3412
Total = £77.14 and does everything you need with plenty of headroom.
What you have to remember with cable is not so much the shielding, but simply does it carry enough current to do what you want it to do.
:lol::lol::lol:
:lol::lol::lol: bastard!!!
Cheers again Bass Mek!!!
I cant wait to get it all sorted now.
Do you think I'd be best of just buying the stuff you have advised there or wait till I go to the shop?
I've decided to go for simplicity for the build now, just the sub enclosure and a false floor hiding the amps and wires etc. I'm still going to try and keep it nice and tidy underneath the false floor. Just have to see how big the amps are when they arrive.
Cant see the pic of the kick pods or get on that forum at work so I'll wait till later, but fiberglass sounds a bit hardcore for me....
Another question...
Should I use any sort of sealent on the inside of the sub box? or do is not need to be that sealed?
Also if no slealant is needed, what about those rounded edge peices of wood you can get to put on the inside? So the air rebounds smoothly rahter than hitting a right angled corner and deflecting everywhere... or am I reading far to much into it?
Oh, also where can I get cooling fans? Any advise or are they pritty much the same.
The questions will keep flying out so sorry :D
are you really dead set against buying a standard square type box? theres nothing wrong with them and it's much easier than making one.
i think cad do fans.
Onyl reason I haven't looked at getting one is becuase I wasnt sure where my sub was going to be.
If it is really that much easier and worth it then I may well get one.
here i go again.......
:lol:
oh rob u idiot.....a pre made box is usually very poor quality and usually only shitty 12 or 15mm MDF and a crap size..
for the sake of a few quid some silicone screws and mdf id rather build a box.... especially as hes spent like a grand on this setup..........
its 10% equiptment 90% install ;)
ACKY: yes seal it as much as possible. airtight. make it out of 18mm MDF and dont worry about round bits of wood inside it..its not a ported box the air isnt going any where so wouldnt need it!
