Help me shop
ha ha... Jerry Jerry Jerry Jerry.
Ok well thats 1 for and 1 against, lets see what Bass Mek has to say.
Thanks for answering my other question, couldnt remember if I was meant to make it ported or not. :lol:
  • Replies 165
  • Views 50k
ahhh foxie, you are a dick :lol:
i doubt it'll make the slightest bit of difference to the sound, as long as its the right size for the sub, it'll take ages to make a good quality and strong box, but if it means that much to you then make one!!
i have made one :)
heres an old pic... with the old amp i blew up 8-)
it makes a HELL of a lot of difference.
post on www.talkaudio.co.uk and see what response you get :)
it'll take ages to make a good quality and strong box!!
itll take ages !?!?! 6 bits of wood 12" x 12" bit of glue and screws cut a circle in one.. some terminals...and you're done... homebase or B&Q will probably even cut it up for you for free.
ok ok, I'm just tryin 2 be difficult now, not surprised you blew that peice of crap, ym mates got some magnat stuff, its not the best!!
Where did you get that connection thing from to plug the wires in?
I wasnt going to have just flat edges a few screws and glue I was going to make proper ends for it, cant remember what there called.
You cut alternating squares out and the ends then slot together nicely.
cad do them too.
Save the money and fix your rear quater :D
:lol::lol::lol: Good call, If I can manage to get it in the body shop that should be done in the next couple of weeks too. :D
magnat stuff is mint for the price! good quality budget stuff.
it was a self-inflicted blowing.... involving 2 wires and them touching together! :lol::lol:
Change of plans............
I pick it all up tomorrrow as along as the 4002 amp comes which should have been delivered yesterday.
But I still cant decide on how to do the boot build.
Either false floor with the sub in the middle.
or false floor with sub on the side.
Or I was looking at building the sub into the side cubby thingy.
Then if it doesnt look to stupid some cut out perspex bits for the amps.
Anyone got a previous boot build or anything they can show to give me some idea's?
i guess you could check out the gallery on....www.talkaudio.co.uk
Dont under estimate the importance of a good sub box it will completley change the sub in my opinion. Its money wasted putting a £400 sub in a cheap motorworld 15mm mdf box!
I used a halfords one as a short fix for my JL W6v2 and yeah it sounded good but the difference when i built my own custom slot ported box was immense, the clarity was vastley improved, it was punchyier and just made such a massive difference i was kicking myself to why i used a off the shelf box. For the sake of buying some MDF for a tenner and getting B&Q to cut it exactly to size its worth the effort! :D And heres a picture for any one interested:
I have more of the build :)
nice work :)
what it tuned to and what size ?? 8-)
Doh! i've been away for a while and so have missed the whole of this thread!
Looking back the choice of components and subwoofer are spot on, although as said a pair of Genesis amps would have been slightly better, but then again there is nothing wrong with the MTX ones you have selected.
As for the installation, make sure you keep the wiring nice and neat and sound deaden as much as is physically possible.
Good luck with the install too! :)
Should I sound deaden anything I can get access...
If I make a false floor should I sound deaden the insides of it or is that going to cause more problems with regards to keeping the amps cool?
nice work :)
it was tuned to 33hz and approx 1.6cuft, one of the old CAD guys drew up the designs for me :)
I would def have some smal fans if your not going to have them in the open air, all though most newer amps come with internal fans and heat sinks, also thermal protection!
The main points to sound deaden would be the door cards, floor pan and tailgate!
Yeah I think they have fans and stuff lke that inbuilt but I was going to put 2 more fans for extracting and putting some cool air in there anyway.
With loads of bloue flahsing neons to the music, nope sorry that last bits a lie
Thank god :lol:
You can do it a few ways, run them off the main power distribution blocks on a switch.
Off the boot light, but will not be much use as only works when boot is open.
Or best way have asmall relay built, which turns the remote turn on into a 12v source to run small things like this off, also has the benefit of coming on with the ignition!
There is a guide on www.talkaudio.co.uk in the FAQ section on how to do this!
Cheers. Yeah I read that last night. Also those kick pods. But I'm going to give them a miss as I dont want it to look like I have a system in the car.
I'm going to speak to the guys at the shop about the fans hopefully they can tell me about it in simpleton terms. :lol:
Picked it all up today, grand total was £1290. :?
haven't got a clue how to put it together though haha far to many wires for me to figure out!!!
easy peasy- wiring diagram below i knocked up in five mins.
any questions fire away :)
Cheers dude.
Now I took in a print of what you said i need but I'm sure she has missed something of. I haven't got a fused dist blcok.
I have a mini power block, is that the same just minus the fuse?
How think/thick should the earth cable from amp to car be. Would it be in the box with the amp?
I think I'm missing wires from the dist block to the amps.
I need someone close by to help :( Mass Mek fancy coming manc for the weekend haha
lol :lol:
dude if i had the time i actually would but I'm so busy now a days its ridiculous!
are you going to the donny show? I will be there on the BBG stand all weekend as I'm organising the whole stand. feel free to pop along and il have a chat with you? More to the point there will be guys there who know a hell of a lot more than pretty much everyone on this site. I'll be attending with the dealers from source sounds (Iasca winners) and LM Car Audio (also iasca winners!)
more to the point its an excuse to go for a drink :D
