more bits for RR day collection
Got someone on clubg40 offerin askin price, if it falls thru ill be in touch. Ta dude
  • Replies 40
  • Views 2.2k
bump
updated...
open to offers on anything, full G40 conversion has sold tho I'm afraid
Hi, do you still have the g40 ecu for sale?
no soz mate
hey grunge
I'm wondering about the pistons and rods for the 1.4..
am assuming the its jst a longer stroke or has the engine to be bored to a different specification?
I'm no info'd up on the differences of bores between engine codes.
also do you know milliage and usage of these?
would you advise the rings to be changed ?
will fit in a PY or ABD block, PY block is preferable as it is tapped for a knock sensor and oil return, not sure on age of them, and the rings were fine when fitted to tommos motor, may be worth doing as a matter of course when rebuilding up a new engine, saves doing it later in situ
ps yes its a longer stroke and requires no extra bore modifications
Edited by grungeisdead
Ah a see! So crank rods n pistons included..
You have an idea how much in total
With postage to ky7 5js
After 150 postage would be around 20 pounds solely due to the weight of the crank!
Would the pistons and rods fit a gt block? Or wrong bore size? Very interested.
will fit into an abd block, unsure if they will fit in a GT block. i assume its just the stroke that affects the capacity and the bore size is the same.
bump
all parts left can be collected at teh RR day
  • 7 months later...
a load of this stuff is still here
