mk3 grill support panel removal
so i'm hoping to finally swap the twisted grill support panel on my coupe this week (since its half term 8-) )
Now i've been cleaning up the pistacio green panel i have as a replacement and have been trying to figure out how the panel is welded to the inner wings. (The replacent has sections of inner wing still attached since the car was scrap anyway)
I've cleaned off the body wax and it looks like theres spotwelds? In which case i should drill them out? Then fill them back in with the mig when it's fitted? However the bottom spotwelds look especially hard to drill out due to access (for the panel on the car).
My dad seems to think that the best bet would be to cut a thin strip of the inner wing out, then butt joining it back together and welding, however since the inner wings are structural i am loathed to do this. Plus it would be harder to fit staight and level.
So before i strip it down i just wanted an experienced view of how i should remove the annoyong wonky panel, then fit the green replacement. :-p(i will be painting it by the way...)
Thankyou :-D
  • Views 513
