My first polo
Still waitin on my polybushes and rear springs :(
Found some bonnet pins in one of my toolboxes, dunno where they came from but they're fitted now. There are 2 perfectly placed holes in the panel with the bonnet catch on so I just drilled up through the bonnet with the grille removed and fitted them.
  • Replies 56
  • Views 7.4k
Installed an air intake temp gauge today. Well ok that's not strictly true, it's a thermometer out of a fridge with the probe stuck in the air intake.
and that works? if ti does thats a cheap and effective method, car looks great btw
Thanks,
Yeah it's temperature range is -30 to +70 degrees so should operate fine. It also runs on a battery so no need to wire anything in. I did have to file the switch hole down a few mm to get in in there but it's almost a perfect fit.
Edited by hammerong
pretty smart you got any pics of engine bay? i love the paint work
I'll get some pics of the engine bay tomorrow evening after I've cleaned it and painted the rusty rocker cover. Nothing special going on under there just yet.
Edited by hammerong
kool cheers, now you have said that i need to clean mine too :)
No engine bay pics yet. Something better came up.
This morning I took delivery of 20ft steel pipe. So off came the old leaky exhaust and out came the mig. I cut the downpipe off and welded a whole new exhaust right up to the silencer where a standard silencer will bolt straight on.
I knocked 1/2 inch off the diameter as the standard exhaust was designed as a compromise between the 1.0 and the 1.3. According to my haynes manual the 1.05 didn't have any centre boxes, just downpipe to rear silencer so that's what I've done. I'm carrying around the haynes manual with me in case a police officer wants to argue this.
It has a nice tone but is almost silent, well as silent as these old cars get. Torque is definitely better but I'm not sure if this is down to the smaller pipe or the exhaust not being full of holes. I should hopefully see more fuel economy with the added backpressure.
After that I cut some ply and lined the boot to stop the sub falling in the tyre well. I found the factory jack in it, has never even been removed.
Suspension now level, fitting polybushes tomorrow. Cut a rev counter in it today, sorry for crappy pic, it was dark. Will get a decent pic in daylight.
looks smart :)
Thanks, can't read it from the drivers seat though so am gunna put a voltmeter there and move it to the a pillar.
Polybushed the front end today, made a press to get the old ones out using a g-clamp and a random bit of 2 inch pipe.
Welded up a twin exhaust tip, twin 1 1/4 inch pipes. I'm not getting a pic of underneath or you'll see what happens when the mig welder wire feed gets grease on it :(
Pic of tacho, not much better tbh, need a better camera.
Wedged a cb radio in it today, not perfect so gunna find somewhere else to mount it.
Also got tired of hearing the exhaust knocking so cut a lump of steel out:
Where did you get the thermometer and the screen from? That's a really clever idea, kudos.
Took a wing off today to sort out some rust. Didn't have any grey paint so used stonechip paint. Had a load of dirtbike stickers floating around. Will laquer it all tomorrow.
No problem, if you wanna fit it in the same space I did just remove the blank and file the hole til it slots in.
I suggest you order 2, I did and only one worked.
Chucked in a voltmeter today, you'll have to excuse the crappy blue vinyl work, I was trying something out, it didn't go well.
Edited by hammerong
Got bored so installed my CB radio properly. I installed a stud mount for the antenna in the hole where the rear wiper used to be. I then fed the cable through the bodywork and rubber tube where the wires used to go. It's a completely stock looking install with no untidy wires floating around.
I used 4 metres of cable but 4.5 would have been better. Just waiting for my antenna to arrive and job's a good'n.
Looking good so far :) I see you've took the camo off the bootlid?
I started taking camo off the bottom to sort out various bits of rust etc. It then started to look stupid with half camo so it all came off.
I hate undoing hard work, especially as it looks great but it had to be done. Took me 14 hours with a hairdryer to get it all off :(
14hrs for just the bootlid?! It took me 10hrs to fit the whole car :( You leaving the sides camo'd still?
No, 14 hours for the whole car. I took a fair bit of paint off too :(
oh :( Colour code is in the boot near the catch if you need it :)
