My first polo
Thanks, I did wonder, couldn't see it under the bonnet.
I wasn't happy about removing it as it looked great but I needed to know what was going on under the paintwork. The wheelarches and drivers door were a bit rusty.
  • Replies 56
  • Views 7.4k
Spent 2 hours yesterday rewiring the car. I was originally running my CB, voltmeter and rev counter off the ignition live behind the stereo. I decided this wasn't ideal so ran a 30amp feed off the battery, to a relay which comes on with the igntion.
Now I know 30amps seems a little excessive but I don't know what else I'll be adding in future so I over engineered it. It's currently only got a 10amp fuse in it, as I add more stuff I'll change the fuse.
While I had everything apart I installed a Sniper alarm with shock sensor. Someone keeps knocking my wing mirror as they push past my car (I leave a gap of about 3 feet so it's intentional) hopefully this'll make them shit themselves/ have a heart attack.
Edited by hammerong
Oryt mate see you fitted the sniper alarm I've just done this but couldent figure out where to wire the shock sensor up to??
Doesent seem to mention anything in instructions.
Can u help me??
Cheers dan
Dan
Yes mate, on the sensor red wire to +12v, black to ground and the remaining wire (blue or white usually) to the input wire on the alarm (either the one that goes to the door pin or the bonnet pin switch, blue or green wire on the alarm unit iirc.
Made a sticker: Photo-0037.jpg
Maybe this should be moved to the blog section....
Anyhoo, had a morning off work so fitted some classic mini headlight grilles. Cost £10, came in chrome but I sprayed them matt black. Attached using 4 cable ties and 6 hot glue gun sticks.
No more cracked headlights for me.
Edited by hammerong
More stickery goodness and now a 2 tone paint job. Not sure whether or not to paint the bumpers too....
