9n/9n3 budget coilovers - £175 delivered
Rides fine assuming you don't drop it 100mm, sit it on the bumps tops and expect it to drive ok!
Not sure the TA's would go any lower than the AP unless they are silly high? I could probably get the springs on their own its just not that cost effective and I'm not sure how much lower they would go than the AP.
  • Replies 69
  • Views 15.9k
Ok wont be worth the risk if its not going to make a diffrence thanks for the reply
What's the lowest these will go wound right down? cheers
120 front without the helpers 100 ish with, rear is a bit higher 80/100 ish.
Hi phil, do you still have any for a 9n ? And how much are they delivered ? Also what brand are the ones you have now ?
Thanks joe
£175 delivered, TA technix. at the moment.
is the ride stiff in these? i dont fancy bouncing around...
Firm but not bouncy assuming you aren't riding the bump stops.
I'll be buying these in the next month, so these are TAs now? But they still are TUV approved? And covered by two years warranty?
Cheers, Marc
are these ta? and would you also be able to supply shortened droplinks?
cheers andy
Ta's yeah, still tuv approved with warranty, can do the drop links for £30 with the coilovers.
okay cheers, might drop you a pm in the next couple of weeks then with an order for coilys and drop links :D
Phil, I'm rather interested in a set of these! are you still selling the JOM blue springs?
they are TA Technix Red springs, check my build thread and you'll see them :)
http://www.clubpolo.co.uk/forum/index.php?...37845&st=25
Cheers dude, ill have to inbox phil when i get paid :p
just want to check will these fit the 9n 1.4 tdi ??
They will indeed.
Phil, How long is the delivery time from payment to door step? Finally nearly ready to get some ta's
3-4 working days usually but the 9n are out of stock till early next week.
Thats good, Wont be ordering till when I am back off holiday, Cheers Phil
Are the 9n ones back in stock yet ?
Just to enquire about your coilovers?
do you have the 9n's in stock?
also do you sell a diesel specific kit for the 1.4 tdi?
how much for a full kit including shortened droplinks.
if you could pm me it would be much apreciated.
thanks
These in stock yet ? Really want some!
9ns are out of stock for the moment. Should be back in very soon though.
