Richs Red Rota
that last picture is perfect IMO
and to be fair i hate red cars..
this actually makes me want a red 6n :S
  • Replies 960
  • Views 97.1k
Wow. Last Picture = :shock:
Looks awesome bud!
:-D
looks tidy matey, will look even better with powerlooks ;) lol
That's the plan! :)
Thanks man, some of my pillars are peeling :(
and for the headliner I just used normal spray cans lol.
Aw okay, I'd use satin black on mine if i was to do it! surely the headliner will feel horrible and crusty??
Yeah it's crusty, but I don't ever actually touch it so it doesn't bother me lol.
Killing it dude. last pic is brilliant.
Cheersss :)
Ha thanks man :D
looook sweet dude
Cheers bud :)
alright mate those roofbars you used ages ago what were they do you have any pics of it with them on from front view and how much were they thinking of getting some for show season next year with a wind fairing on the front thx
Don't think I have any front view pictures of them on, If I do they'l be in this thread somewhere.
They were just from Halfords and I think they were about £70 new.
In other news had some trouble on the way home from work today, the car randomly pulled to the left and side to side and made a lot of messed up noises.
Ended up pulling over 3 times and on the last time found this.
The rear right wheel had pushed itself out about 20-30mm, de-cambered itself and the arch was sat on the tyre... :(
Managed to get it home on a truck and now the wheel has gone back in the arch how it was before...WTF?!?!?
Pics!
Broken1 by Rich Armitage, on Flickr
Broken2 by Rich Armitage, on Flickr
Broken3 by Rich Armitage, on Flickr
Broken4 by Rich Armitage, on Flickr
Broken5 by Rich Armitage, on Flickr
Anyone got any ideas???
probably need to sheck your hub bolt mate sounds like it came loose and the camber shim managed to moove itself
sweet bit of poke though not really practical lol
Yeah. Looks like the hubs worked loose, locktite them. Maybe the shims have even come out? would explain how it managed to loose ALL the camber, then you said it went back to how it was with the camber. If the bolts were still how they were with the shims, then if the car had moved to the side, the wheel would have leaned in to the side in effect? Are you with me aha...
I checked all the wheel and hub before I got it home and all the wheel bolts were fine, the wheel was attached to the hub as it should be and I could feel the camber shim all the way round the hub still in place, there was no movement between the hub and axle.
So not really sure yet, might be a wheel bearing?
I'll have a look tonight after work, hopefully it's not too bad.
Bit of a shitter about the rear wheel :(
On another note, I pretty much hate you. This has really come on man, looks gorgeous!
hmmm.
He just needs to drive back from work first! hahaha
I'm getting a lift home :p
Wheel bearing has blown...knew it!
Problem is, its stuck on...proper stuck on!
Tried cutting through it but it's difficult, can't get a proper cut to go all the way through, any ideas???
Bearing3 by Rich Armitage, on Flickr
Bearing2 by Rich Armitage, on Flickr
Bearing1 by Rich Armitage, on Flickr
change the full stub axle?
Rear disc conversion it is then :)
Fecking hell Rich! how did you not feel that working loose! Your ride must be worse then mine!
Hahaa this happened to mine the other week, i tried all sorts to get it off! I just ended up chopping the stub axle and bought a new one from GSF, was about £20 iirc
Might have to if it wont come off.
Dunno about that :p
No idea man, it had been absolutely fine then suddenly it went!
Did you try grinding it off?
How come you chopped the stub axle off if you were replacing it with a new one, could you not have just unbolted it and bolted the new one in?
Edited by Richibobs
Yep, but they're case hardened, wasn't going anywhere quickly :L
I did try that but because I got spacers on the back of the stub axles, I couldn't get enough clearance to get it out between the beam and brakes without disconnecting everything so just chopped it to make it easier
u gettin winter wheels dude?
I'm just putting my old steels on with some old vw hub caps, should look funny :p
Fixed! :)
IMG_0987[1] by Rich Armitage, on Flickr
ahh shit one mate...wheel bearings do suddenly let go with no warning sometime!
id change them regular one this kind of application, always checking mine due to offsets and such, its not ideal on the bearings being loaded uncentrally!
always love this though, i need some camber shims!
Cheers mate.
Quick shot of the car on winter wheels :p
winter1 by Rich Armitage, on Flickr
PMSL! no more pics needed! PLEASE! NO MORE PICSSSS!
Hahaa that's horrific, let's hope this winter's a short one! :lol:
