Annoying ABS light
I have a Polo 6n which failed it's MOT because when the ignition was turned on, the ABS light didn't flash up on the dash board.
I fixed this by replacing the bulb.
I then drove the car and the light would stay on, so I plugged in diagnostics and it said the rear right sensor had a problem, so replaced it, cleared the fault code, and now the diagnostics says the car is fine.
But even after driving the car the ABS light still stays on the dashboard? Even though there is no problem, ABS works etc.
Any ideas? How to reset etc?
  • Views 595
