Car Audio - Brand New and Boxed!
Evening Everyone
I bought this stuff to go in my Golf but as the car is now going to be a stripped out job I wont be needing any of this.
1. Alpine MRP-T222 Amplifier - £60 + Postage
General
* 1/2 Channel Operation
* BassEngine®
* Subsonic Filter
* Bass EQ Circuit
* Crossover (HP/LP)
* MOSFET Power Supply
* DC-DC PWM Power Supply
* Discrete Pre-Amp Stage
* Double Buffered Pre-Amp Input Circuitry
* STAR Circuitry
* MultiMode™
* Top Mounted Blue LED Power/Status Indicator
* Duo B Feedback Circuitry
* Continuously Adjustable Gain Control
* Speaker Level Inputs
* Gold Plated Power Screw Terminals
* Gold Plated Speaker Terminals
* Cross-Vented Chassis Design
SPECIFICATIONS
CEA-2006 Power Rating
* CEA-2006 Power Rating (40hm at 14.4V = 1%THD+N), S/N 60dBA (Ref. 1W into 4Ohm): 50W x 2
RMS Power (at 14.4V THD+N, 20Hz-200Hz)
* Per channel into 4 ohms: 50W x 2 (0.08% THD)
* Per channel into 2 ohms: 70W x 2 (0.3%)
* Bridged 4 ohms: 140W x 1 (0.3%)
* Total Max. Power: 250W
BassEngine® Sound Tuning
* Crossover Network: 18dB/oct
* Low/High Pass Crossover Frequency (Fixed): 80Hz
* Subsonic Filter (Fixed): 20Hz
* Bass EQ Frequency (Fixed): 50Hz
* Bass EQ Level (Adjustable): 0 - 12dB
General
* Power Requirements: 14.4V DC (11V to 16V)
* Frequency Response: 10Hz – 50kHz (+0, -1dB)
* Signal to Noise (S/N): 100dBA (referenced to rated power)
* Input Sensitivity (For Rated Power): 0.2V to 4.0V
* Slew Factor: Greater than 5
* Input Impedance: 10k Ohm
* Speaker Impedance: 4 or 2 Ohm (Stereo), 4 Ohm (Bridged)
* Dimensions (WxHxD): 172mm x 60mm x 267mm
* Dimensions (WxHxD): 6-4/5” x 2-2/5" x 10-1/2”
* Weight: 1.95 Kg. (4 lbs. 5 oz)
2. Infinity 8023i Speakers - £60 + Postage
8" (200mm) three-way loudspeaker with Plus One® woofer cone and edge-driven textile dome midrange and tweeter.
Plus One® woofer cones - This patent pending technology deliver a cone with more surface area than competing models of the same size. The result is increased bass output and higher efficiency.
Infinity Reference speakers have two-ohm voice coils. This unique approach extracts more power from your amp or head unit. Many factory OE systems include two-ohm speakers. Infinity Reference speakers are perfect for those applications.If your head unit or amplifier is rated to drive a four-ohm load, Infinity Reference speakers are still the best option.
Edge-driven textile dome midrange and tweeter - These are not commonly used w-domes, but fully-edge-driven domes like those found in better home audio speakers. The benefit is increased power handling and reduced distortion at high output levels. This technology also allows for better integration with the mid/woofer.
Tweeter level adjustment - The 8023i also features a tweeter level adjustment located on the front of the speaker and can be set at the reference level of 0dB. If the speakers are located low in the doors or if you are looking for a brighter sound, set the tweeter at +3dB.
# 20cm (8") 3 way speakers
# Power Handling, RMS: 75 Watts
# Power Handling, Peak: 225 Watts
# Frequency Response (±3dB): 49Hz - 21kHz
# Sensitivity: 94dB
# Impedance: 2 Ohms
# Mounting Depth: 3 9/16" (90mm)
# Sold in pairs. Supplied with grills
Sammo
  • Views 238
