mk3 all parts available
It's NOT a PPP frame, it's a completely different design to ours, and it's red!
If you continue to advertise it as one of ours, I'll remove your advert entirely.
I suggest you check the PPS site, and the PPP site, and stop trying to sell a cheaper product as a more expensive counter part.
Thanks,
Yoof
  • Replies 75
  • Views 3.4k
why dont you get the car jigged?? can tell if its twisted then. Does it crab down the road badly?
still got the clocks?
i aint folking out no more money to sort it cost me silly money allready
so what sub frame is it? i'm confused, surely yoof would know if it's one of his :?
Edited by McLOVIN
PPS subframes dont look cheap, you obv haven't found one :lol:
There site isnt up atm, so you cant have found it on there.
PPS subframe
Bearing in mind, they have changed in design over time.
I'm pretty sure Yoo knows his own subframes.
Nice edit. I'll re-port your original reply (in case this was originally moderated instead of Gaz_golf_gti editing it, mod feel free to edit this post too)
how the f**k can you see from that pik and if you could then were the scratchs are its black
and when i looked at your piks thinkin about buying one before it looks exactly the same otherwise i wouldnt of bought it
how can i check the pps site when iv never heard of them please send a link
New reply
ha ha ha iv just found them and mine looks nothin like that they realy do look cheap
This is DEFINITELY not a PPP frame.
Look at the mounting point in this picture
Now compare the same point in this picture
http://www.poloperformanceparts.com/gallery.php?show=3
That's how you tell them apart. The PPS one has a tubular construction, the PPP more squared.
Your arrogance is astounding Gaz_golf_gti. Man up and admit you're wrong.
No, i said you cant have found it on there site :lol:
PPP one.
ok so now i see the differnce couldnt find a pik of ppp one as yoof no longer sells them
yet again iv been done over by one of the mupets on this forum will amend the discription
yoof i appolagise but honestly i had never heard of pps until i put this post up
so to clear it up to everyone who was interested its a PPS subframe
On a more serious note... lol
How much for the carbs if you decide to break the engine?
look i cant be arsed with all this if your not posting about buying stuff then basically fu*k off as it says in the rules
We're merely clarifying the details of your advert so that no-one gets ripped off. A seller with manners would take on board what I originally posted, do their research and then reply in a mature manor. You didn't.
Who'd want to buy a subframe off a bent car is beyond me anyway. It's either bent in an accident or been adjusted/re-manufactured to fit this bent car. Either way it won't be an easy fit or be as capable of it's designed purpose on any other car.
already sold
Bugger :lol:
I even read through the thread to see if the engine had gone haha. Did i miss a blatant post?
just to clarifie mate the car was bent before the subframe went on and its only bent at the back from a rear ender found damage after replacing the bumper
and to be quit honest mate you could of put the piks up in the first post and it would of saved all this plus why would i investigate sumthing when i was led to believe it was a ppp item i even saw a receipt normally when you see a receipt things are what they seem
Bugger :lol:
lol no mate your eyes are fine it was by pm
Gaz just sent you the money for the engine mount
B-Shaw - nur nurrrr :p :D
nice one mate i shal get it posted as its already off the car
"just to clarifie mate the car was bent before the subframe went on and its only bent at the back from a rear ender found damage after replacing the bumper"
I stand corrected
"and to be quit honest mate you could of put the piks up in the first post and it would of saved all this plus why would i investigate sumthing when i was led to believe it was a ppp item i even saw a receipt normally when you see a receipt things are what they seem"
You're relying on me to send you pictures to prove you wrong???? What the HELL are you thinking??? You should know your own items pal.
Edit: I won't post any more replies in this topic, nor rise to your silly arguments.
Edited by cheys03
Mate u have pm can u send me one back at lest to let me know if u have the stuf
replied too ;)
ta for the pm, trying to send one back but your inbox is full! delete sommat :p
lol sorted and deleted a few things ;)
would u b interewsted in some sort of swap pal? I've got a mk2 golf an I'm wantin to get anuva mk3 coupe :) its lowered on springs and dampers, g60 arche, big bumpers, stealthe shelf, aftermarket rev counter in vent mount, poly bush kit still sealed an boxed never used, got a 1.8 8v gti engine for it an piper 285 ultimate road cam an single weber carb, few other spares too an probably bits I've forgoten. its on log book as a 1.6 driver, 3 door, in white with sunroof. pm me if you are interested pal an will see if we can cum to sum sort of arangement :)
cheers
sorry dude i would never be able to insure that but feel free to buy the shell off me if you want another ;)
was mainly the engine an subframe i was after but thought i would try my luk for a full swap :)
how much for the plastic bits over the archs and across the sill ?? pm me
theres only the sill covers worth selling mate the arch covers are battered
