Black Diamond clutch £45 posted!
i have for sale a 200mm black diamond performance clutch
selling it as it could not handle the extra torque of the bike carbs etc on my valver engine but it should be absolutly fine for a standard engine or anything smaller, basically if you drove sensibly for a day or two it would be fine for a short while but when you revved the engine high (8-9k in my case) it would start slipping and glaze over and slip abit for a few days and then be ok again so it is your risk if you want to use it, but as i said it should be fine on a standard or smaller engine
i bought it with about 14k on it and i have put around 4k onto it so just 18k in total, which isnt much for a clutch!
will fit any vw that takes a 200m clutch as far as i know
selling for a mere £45 posted due to the described problem or £35 collected from leeds LS5 3PG
Edited by dubownerbilco
  • Views 199
