Jamie's Coupe Stroked AFH.
Nyom Nyom Nyom . Made a start last night and took the grinder to a few rust spots .. may have to use some krust or similar as theres tiny bit of pitting and don't want the paint to lift a year down line
  • Replies 349
  • Views 32.7k
Car stripped
AfH stripped down .
New heated leathers to go in ..
Not much progress as not much really i can be getting on with part from paint prep and saving for bits.
Coilovers coming shortly ;)
Geez!
Didnt realise you were this much into it.
Nice work!
Looking good..in peices lol how many lil rust spots are there? How much of the prep/paint you doing yourself out of interest?
Well I've got a compressor and DA.
So going to do as much as i can .. Hoping to get it to the stage of ready to base coat. My mate owns a body shop down the road so ill just trailer it there or something and flat it . So hoping preety much all the prep is going to be done by my self and a few mates :) ..
Needs to be done in two hits though as door's, bonnet, boot and wings are all coming off :)
sound good man! i just wansnt sure how far you are capabilitys went lol
good to see you getting stuck in your self tho!
when i done mine, it made me like the car more lol.
Cheers man :)
I've done everything to the car myself ..
First car and i said i would just lower it and put wheels on . Paha no that soon changed,
After i done this i cant think of one thing i've not changed/fixed on the car. Litrally everything has been done by myself on this car with abit of help from mates on a few things.
1. becuasue I'm a tight arse and dont want to fork out for a job which i could teach myself and do for free lol
2. I know whats been done and how ;).
At the end of the day polo's are piss to work on and its just like mechano, nuts and bolts lol ..
Paint on the other hand, I've helped out in my mates body shop but we shall see how well it comes out ..
Looking good and I posted in your big end bearing thread have you seen it
Bit of an update.. Both wings are now off .
Seen better days so after a set of good condtion wings ;)
Inside of mine where the arch liner bolts are missing etc :/
Blocks sent off to be honed .. had a few minor score marks but lets hope honing takes it out :)
I think I should have honorary first passenger ride down the strip at pod to see how my engine has moved on :)
Yeah mate ;) .. You at action .. Hopefully Be finished how i like by then
Other news .
Got DA
Got 15meter Airline
Got compressor
Other little bits..
So gonna start sanding .
Then filling.
Then flatting.
Then who knows ;)
Get some pictures up you bum.
words are boring ;)
Having no car is boring :( lol
Ordered you some bits matey, be in tomorrow, will bring them up Saturday.
Didn't get to TPS for rod bolts though
Much loves :)
might just bite the bullet and go vw direct :/ lol
Did some boot reprofiling on this on Saturday evening ;) very special indeed.
Yeah, more airflow and dent solutions ..
Still undesided on what to do :( lol ..
UPDATES
Sorted tank out ..
Few pinholes in filler neck chemical metal'd
Lick of paint just to stop rust
Stripped beam down and cleaned it up abit .. Krust has become my freind, stuff like this its sick for
First coat of hammerite
New cylinders .. Used the bigger ones to see if they work any problems i will just swap over
Painted stup axels up and got the beam built up
Something to allow me to have a decent amount of lows and have some more comfort than the budget shocking kits
Props to the main man, you know who you are.. :) steal of a price too ;)
Will allow me to play with spring rates abit to if need be :)
Cut the bump stops from this to about 15mm
Should allow some travle now haha as they were massive :p
This is my old block what got honed, Few score marks but if one does not come up in time i will just bite the bullet and use this one
Also got a piss pot to wipe on my windows ...Only size what will fit in arche tbf and rarly use it, more for MOT's 1.2 liters lol
And here's maxmax
Plan is for this month
Fit beam and rear coilovers
Fit washer bottle and poss front coils ?
Build engine ready to drop in
Max's coming down at some point to help me with his fab skillz on a few things
Then next month car will be prepped to fuck and sprayed hopefully ;)
Keep peeled
Jamie.
Yay progress. Washer bottle is fine man! Think iv only topped mine up once since fitting it actually, goes a lot further than you think.
Yeah i swear the 4 liter one lasted me all year lol ..
Never use it as i used to keep car clean :) ..
May need a bit of you are hand soon, Thumb if poss ..;)
Looking really good mate - some real progress has been made! gunna be a cracker! send me a pm if you have any little bits you need as i broke a mk3 not long ago and I'm having a clearout sonid rather give them away if i have them then take them to the tip.
CHeers mate :)
Ill have a think if theres anything i could do with, more than likley be something silly i've forgot lol
Bit of a gutter as the compressor i was using decided to stop workign :( wouldnt kick in at first without reseting it, now just humms when i press reset button :/
sounds like the starter. change the capaciter on it firat or swap it for a known good one and see what happens
Rear beam and coilovers fitted, Just need to fit my new hoses and connect the handbrake back up.
I see what you mean about the spacer dude lol, Without it the tank would be on the floor :o lol
Ill have a look at capaciter also check valve is ment to be a problem from what i've seen .
