my gold bready
first ride and....
some stripes near my house LOL :)
  • Replies 85
  • Views 12.8k
cleaned today and now I'm waiting to go to Bogg Bros for setting up carbs propely
Edited by Adamos_20
Looks good dude nice work :) Just wondering what front lip you used and where you got the clear side indicators? Thanks
WOW!! awesome work wish i had the money and knowledge to do this
Sounds awesome!
its from golf mk1 , and indicators are from ebay
if you intrested one of my mates is stripping golf mk1 and he got same splitter, can ask him how much he want for it?
will send you PM tommorow
http://imageshack.us/clip/my-videos/715/4w9r.mp4/
Edited by Adamos_20
you fail, they are like that from factory
Cheers mate :)
as can't find oem dorcards from mk2 , i've install today mk3 genesis dorcards
and how looks my old one
than fitted today dizzy without vac. advance
hope tommorow will finish exhaust...
also I'm thinking about fitting straight stainles steel pipe from downpipe to back box and something like that on the end
found on it some small saint:
RACE USE ONLY :-D
what you think?
Edited by Adamos_20
engine looks mint mate keep up the good work :)
also whats the difference between vac advance and none vac dizzys??
vac advance need vacum pipe from ie inlet to chenge ignition on higher rpm, but i preffer standard one
good work sounds great ,my door cards look just like your ones but il just recover them with somthing, exhaust will probly be very loud with that thing on the end haha
Looks sweet there one down the road from my gf's and always thought it looked nasty. But i love this.
Was that your first time fitting carbs? how'd you find it?
yes it was my first time with carbs, just use FAQ on these forum, most dificult was to prepare manifold, carbs still need to be adjusted, and ignition too, but rang already to Bogg Bros and houply within few days will go over there :)
Edited by Adamos_20
today picked up my new stainless steel exhaust pipes with scorpion on the end
Car looks lovely!! :)
It be interesting to see if the none vac dizzy works properly.. you could have just used the mk2 one and remove the vac advance.. :)
It that exhaust made in 1 peice?
stupid question but i like those door cards are they a straight swap????
loving the progress btw :D
none vac dizzy seems to work ok, exhaust is two piece
front dorcards fit almoust plug and play, you need only to remove two clips from new dorcards (from wing side) and you need to use 2F dor handles
rear dorcars fit without any mods
only door handles? not the window seals or anything? score!
seals stay the same, you need to swap these plastic triangle near mirror
I followed the 'rear door cards fit without any mods' :( not in a breadvan I'm afraid.. The middle pillar is wider than normal coupes :( just a heads up for other people..
my rear dor card are from mk2F breast so fits spot on
need clean them :)
Edited by Adamos_20
need clean them :)
How? I have the light grey ones and they look filthy.
