RH Cups 15x7 - Just referbed
Hi guys, got a set of RH Cups that i have just refurbed. Zero kerbing, painted met silver/grey and lacquered - Not show winning but very presentable. 4x100, ET50 but come with 20mm spacers and longer bolts....just need tyres.
I'm going to put these on the jetta but thought i'd see if anyone has anything interesting rims to trade before i shell out for new tyres.
This is the only pic i have at the moment and i would say that its the worst wheel out of them all because as you can see, it had to have a wheel stud drilled / chisseled out. The damage will be pretty much out of sight when you've got a wheel bolt in there anywho.
I do have 2 original centre caps but they are a bit scruffy to say the least.
Located in Gloucester, feel free to call 07935 271239 if you have any q's.
Cheers.
  • Views 163
