1977, yellow mk1 polo n
Urgh, this is gonna be SO good.
Nice work!
Perfect response.
  • Replies 384
  • Views 63.7k
  • steady on Dan, it was only an offer lol
  • Finally, found my way back to the garage.....and hopefully would like to see it finished before the end of May. May last year was the last time I did any work on the car, so Iv'e got a lot of catchin
  • Thanks for the comments guys. I've not made my mind up on the colour of the centres yet Nick! although I haven't ruled out yellow Haha.......you know you don't mean it Olly Car will be in primer
Nice work!
Thanks Max, my body filling and sanding skills aren't very good, so I'm not expecting the finished bay to be that good to be honest!
I'm running out of patience now and tending to rush things a little, I'll just be happy to see it in paint. :-)
If you rush it you'll regret it, take your time you know it'll be worth it in the end!!
Nice work!
I did too when i got to this stage, the only advice i can give is do not move onto the next stage untill YOU or happy with it.
Otherwise it'll bite you in the ass, and you'll always regret not getting things spot on.
Kinda know the feeling you seem to have, you'll end up doing it twice if you rush cause it'll slowly get to you
When I finally finish the bodyfiller in the bay, there's gonna be a lot of bare metal and filler! Iv'e read that you can't use etch primer as it will react and lift the filler!
So what primer would i apply onto the filler and bare metal? once the first coat of primer is on i shall then use high build.
Should you not have etched the bare metal areas before applying filler?
No Dan! filler is applied to bare metal, if you apply it to etch it will start to lift off, thats what I'm led to believe!
Edited by tominator
Well I don't understand your issue of not knowing what primer to apply after your filler work?
Looks good and! Should've give me a shout if you want a hand filling dude..
always put filler on bare metal which is well keyed. you really should just be using etch primer as a treatment to bare metal which you wont filler or prepare and just put paint over the top.
dependant on what you buy my advice would be to use an epoxy primer which you can key for filler. not all are like this but a good automotive refinishing supply store will be able to sort you out with what your trying to do.
etch is acid based an will eat filler whether its applied on top or under. you shouldnt put etch over any existing paint either as that will lift off.
you could cheat like i did and sand the whole bay to bare metal and spray it with reface, then once you have got areas done you could expoxy it bit by bit until your ready to do one big prep and primer.
i can lend you my reface gun if needed
I have applied the filler onto bare metal!
My question is when I have finished the filling and sanding, what primer do I use to then cover the bare metal and filler as a first coat??
Edited by tominator
Managed to get a couple of coats of stonechip on the underside this afternoon.
Next, put the jig onto the passenger side, flip it over and give it another 2 coats.
you make me sick with envy
:lol: :lol: :lol:
:lol: :lol: :lol:
lolololol awww kiz hahah
when you gonna join the cool kids and get a mk1 or mk2? :p
grest work dude. looks smashing!
I need a garage..and a mk1, and some patience.
So excited!
KIZ, your inbox is full!!!!
its always bloody full - full of noob questions to answer (not just you pmsl)
I've emptied it a bit and replied
hi m8 haz you are polo got a 60/40 kit on it? lol
or, wheres the coilover thread gone ha
that bloody coilover thread has me wanting to cut Guys fingers off!
Andy, I'm massively busy at the minute but I'm sure i will get some spare time to come and do that wiper bracket soon. Also i cant remember if you sorted the brake line clips?
No rush mate! what do you mean by the brake line clips?
i cant remember welding them back on
I guessed that was what you mean't! and, no you didn't.
