1977, yellow mk1 polo n
omg i want a mk 1
this one looks so lush keep up the good work
  • Replies 384
  • Views 63.7k
  • steady on Dan, it was only an offer lol
  • Finally, found my way back to the garage.....and hopefully would like to see it finished before the end of May. May last year was the last time I did any work on the car, so Iv'e got a lot of catchin
  • Thanks for the comments guys. I've not made my mind up on the colour of the centres yet Nick! although I haven't ruled out yellow Haha.......you know you don't mean it Olly Car will be in primer
good lad!!!
i said you would get to the point of tears!!! looking great mate I'm so chuffed for you.
:-D
looks sick Andy!!
Looks so good. Will be doing the same as this to my mk2 underside wise, so will re read this in full soon!
Are you painting the topside as well?
Have you brushed any of the underside or is it all spray? What are you doing inside the jacking points? Mine look like they have surface rust inside.
good lad!!!
:-D
Thanks Kiz :biggrin:
Did you say you had a brake pipe flaring tool?
Got one in MK
Cheers, and good luck doing the underside of yours.
I haven't decided weather to have a full respray yet.
Sprayed the primer, sprayed the stonechip with a shultz gun, and brushed on the the 2k yellow.
yer, did you want to lend it?
Lovely work on the bay mucker.
Cracking effort, just one question, are you happy with the way in which the bay has turned out? :biggrin:
If your happy then it should be the best engine bay anyone will ever have seen in a polo :)
Winning 8-) 8-) Look forward to seeing this in the flesh again soon ;)
I'm happy ish, and in the process of refilling a couple of small areas, it will be far from 100% perfect though, after all I have no bodywork experience!
Wow steady on, there's lots of polo's out there with amazing engine bays, so I doubt very much it will be anywhere near as good as those!!
Edited by tominator
Your engine bay is looking awesome, good work
Upon closer inspection of the primer in the engine bay, there's still more fine filling to do, to eliminate pin holes and fine scratches.
And at the moment I just couldn't be arsed :mad:
So I moved on to cleaning the years of dirt off the inside of the front wings, to then stripping the underseal down to the primer, I shall re-prime, stonechip, and give em a couple of coats of yellow.
Edited by tominator
i cant say I'm not suprised Andy, to get that bay right the first time would have been incredible! stick with it and remember the long it takes and the more work you do - the better it will be. dont cut corners or you will regret it!
keep up the good work mate
KiZ
Yeah, cheers kiz, I'm sure I'll be back on it over the weekend.
Can anyone recommend a fine filler/stopper to be applied over primer?
I've been using this shite which has kinda made things worse as it appears so hard to sand!
http://www.carplan.co.uk/index.cfm?product=253
Cheers :smile:
what kiz is trying to say is :
dont rush it or itl turn out like erics
:lol: :lol:
Spent the day finishing the cleaning up of the inner side of the front wings.
Both wings had slight surface rust, the drivers side more so.
I've applied a couple of coats of Jenolite to the rust and tomorrow I shall prime and stonechip :-D
And then hopefully get the engine bay sorted by the weekend.
This is amazing! How did I miss this!
Anything been happening to the polo? been dying for an update
Not done much to the car in last couple of months, busy with work!
I'm hoping to get stuck in now, and get it finished around the end of January, I'll keep the build thread updated as and when I get back to it. :-D
can i interest one in a set of chrome for this yellow delight???
No!! It wont suit chrome.........
Just read this thread stunning car and super colour. Would love your garage.
