Removing Badge Glue
Hi,
Just got an x reg 6n2 in alright condition. Some toe rag has nicked the rear badge, leaving the foam/glue - how do you get it off, before replacing it with a new one?
  • Replies 7
  • Views 1k
You have a couple of choices.
1. heat the glue with a hair dryer and rub it off with your fingers. You will certainly burn your fingers and wear the skin off your finger tips (I know from experience
2. try some Autoglym Intensive Tar remover. Wet some kitchen roll with it and hold it onto the glue. It will break it down and it will rub off very easily. Have a look here http://www.autoglym.com/enGB/product-prodd...=GD&Range=1
Edited by BRABUS
household polish...spray it on and leave it for a bit... ORRR boiling water....
I'm ocd and kinda love doing this....cos I'm a girl i can like do it with my nails that dont scratch paint.... ;)
Because of this everyone gives me this job!! lol :)
Brilliant - that sounds a lot better than the two other suggestions I've been given by dealers - white spirit and nail polish remover!!!! :o
So, it's the hair dryer, tar remover and good old finger nails (might have to grow them a bit first, unless you're offering LOL)
Thank you :)
Thank you :)
I really would.....haha :)
You don't need finger nails, I dont have any and all I do is once the tar remover has started to soften/disolve the glue I rub it with the kitchen paper I applied teh tar remover with.
Its a real doddle.
sorted - I started with a hair dryer (worked realy well to get rid of the big foamy stuff).
Then I moved on to the tar remover (just normal cheap stuff I found in my garage) with a bug cloth used lots of muscle, Worked it with kitchen roll - then back to tar removerand it sort of polished the residue off
Then the last layer of glue came of with a little meths. Looks really good :)
Thanks for all the help :-p
I would of used a toffee wheel, they are bang tidy at removing crap !
