most modified polo
I'd say mine is the most modified/standard looking.
my nail of a mk3 would possibly be a contender for that?
Full coilovers set up including custom fronts
16v conversion running standard afh injection/management
Then most other mods were robbed from other vw's like wheels, seats, brakes ect so pretty much blended in
Only the grill and tail pipe (or lack of as it was hiden) hinted towards much
In fact thinking about it now it was probably one of the best examples oem+ on here without even intending to be :lol:
  • Replies 44
  • Views 7.8k
Mine looks so standard it even has a factory tailpipe *gets tape measure out*
GenesisGT too...
Taken from his members gallery thread:
Engine spec:
Standard G40 internals cam and injectors
Jabba R1 charger & induction kit
Boost return mod
Stage 3 high flow head port matched to both manifolds
GT inlet manifold
Dewedged throttle body
flowed charger outlet elbow
currently a decat but will be fitting my PPP 4 branch front section.
Standard mid and rear box
Chipped ECU
PSD toothed pulleys
Standard intercooler
milage is just over 100K (shells about to turn 80K)
Power wise I'm not sure what’s she is running hope it would be about 150BHP.
Engine was rolling roaded about 6 years ago at 170bhp with 170lb-ft but it had a big exhaust and aquamist at the time so i know its down from that.
Chassis spec
Full GT/G40 running gear consisting off:
VWII brakes
FK -40 suspension kit with G40 bump stops
GT/G40 , rear axle, steering damper
Standard polo driveshafts and TCAs
Genuine accessories & OEM/OEM+ stuff is sort of my hobby :oops: so she has lots of them too, will type the list another day for anyone who is interested.
So i hope to make some decent progress on her this year and get her back on the road in 2012.
All bits loom switches are genuine unless stated.
ICE
JVC DVD headunit (tiny screen version)
JVC 12 disk text enabled CD changer
Home made boot built to house the above
4 ohm speakers front and back (standard are 3ohm) still shit though lol.
4 Tweeters 2 rear and 2 front (dummy cover the winder holes)
Reversing Colour camera (works but never drilled the bumper)
Audioscape door pods
3 Schabak polos and bling VW badge on the parcel shelf.
Current OEM MK3 polo bits
Armour door plates
Headlamp washers
Front fog lights and loom
Front and rear rubber VW mats with the polo badge insert
Sump guard
G40 clocks
Headlamp protectors
Battery cover
Heated screen washer jets and home made loom
Electric Headlight aim adjusters & RHD switch and loom (dash loom home made)
Sealed First aid kit (green script) and holder all contents well out of date!
Warning triangle and retaining strap
Boot sill protector
Electric windows, mk2 golf switches, rocco trims and home made loom
Boot side carpets (early Velcro version)
Under bonnet insulation (fire blanket)
Hella raintronic loom and relay (automatic wipers with the electronic eye) now sold
GT/G40 steering damper
Green tinted heat insulating glass (non bonded quarter lights)
50/50 split rear seats
Steel sliding sunroof
GT/G40 Rear axle
Hella Front indicators
Rear seat belt guides
Glove box door lock
Centre consol cassette storage
Leather G40 steering wheel with black trim
Dash trailer warning switch
Charcoal canister blanking plate
Full tool kit with all the clips, plastic tags, rubber bands
Front rear black VW badges
Front and rear G40 badges
Current OEM+ items
“polo” script door sill panels
Heated Seats (passat loom & switch)
Scirocco GTII seats (need the heated pads put in them)
Chrome door handle inserts
LHD all rear rear light and home made loom
Delocked passenger door handle
GT Grill panel rear insert (lets a bit more air at the charger than the standard 1.0L one
Door latch covers
Heko door wind deflectors
GT side indicator blanks
Washer bottle strainer
Black GT sunvisors and clips
Black sunroof controls
New OEM/OEM+ bits for 2012
Chrome and black Golf rear door handles (only if I can find a central locking kit)
Door handle finger plate inserts if the above is used.
Electric sunroof conversion kit loom and switch with mk2 golf internal dimming light
genuine loom for heated washer jets
Genuine loom for the headlamp washers and the 3 bumper clips.
Genuine 4 speaker loom and rear inner wing grommets
VW tyre compressor (blue version that can fit in the glovebox)
½ colour coded bumpers
Colour coded boot plinth
French spec yellow front fog lights
Rear plastic speaker cages
Squareback version foam pads for on the tailgate to stop it rattling.
GT/G40/CL dashboard (no holes round the glovebox)
Cigi lighter loom (never wired it up last time)
speedo cable clip that holds the cable neatly to the heater box (never seen it before but was on a low milage car i broke)
Front and rear mudflaps with the polo script badges
Mk3 golf rear boot catch with built in boot light actuator (home made boot lights using mk2 rocco bits)
GT/G40 Rear load sensor valve (didn’t fit it first time round)
Leather G40 full height gear gator and gearnob
G40 ARB driver side mount with the cut out for the charger belt
14” Rocco mkII steels and centre caps
256mm Audi brakes up front
GT/G40 radiator
Front wings with no side repeaters
Body coloured front and rear G40 badges
22mm brake master cylinder and LHD resevoir (square to match the rest of the car)
MK4 polo sump wiring holder (as the mk3 design is pants)
VW 14” space saver to fit over the 256mm brakes with genuine VW spacer to fit the mk3 boot.
VDO oil temp and pressure gauges and dimmer unit booster (never wired them up last time).
VW picnic blanket
Non charcoal canister models fuel pipe set up and breather
VW dealer bunting proper 1990s spec for round her at shows
Van boot sill trims Stainless Steel (unlikely to fit them)
Van safety net for behind driver and passengers heads with all the mounts and bolts (unlikely to fit them)
Radio volume adjuster linked to the Speedo (goes louder if you go faster)
VW headrest coat hanger
electric window switch & loom (as I make a loom and used mk2 golf ones last time).
Tow bar and loom to go with the Dash warning switch
PCT Towbar (least amount of drill holes into the shell and goes under the bumper)
Yet it looks extremely stock!
Yeah looking at that I retract my previous statement :lol:
that bloke with the massive arches welded to his arches pobably wins this lol, not sure if i should have brought that car up i know its a touchy subject on here. or youngprodigiys
You mean my old Loon or that Orange Mk4 ?
did you sell that in the end steve?
Yes mate its gone to a mate in Derby he has some good plans for it .
Hopefully it will be sorted for next years show season he has his Mk1 Golf showcar to finnish 1st
There's a big difference between modified aestheics and modified running gear. The spec list on yours is awesome JimmyB, but I looked for a pic and (not being disrespectful, it's an awesome looking car) to anybody looking at a glance it's just a low Mk3 with some nice wheels.
I've gone the opposite way and completely changed the aesthetics but left the running gear relatively stock (bar lowering and a GT cam). I'll get some in progress pics up soon, it's probably not to everybody's taste but i've not seen another Polo (or VW for that matter) like it.
Matt
Thats the intent, I just want my car looking somewhat original but with some nice classic touches I didn't want to attract too much attention.
- Jimmy B
9olo mist be pretty high up there
Hmm. See, I think with things like this it depends how detailed you go with your spec.
The only bits of mine that haven't been touched are the rear window and wiper, front bumper iron, rear beam, front wiper motor, mirrors, front/rear VW badges, dashboard (except the clocks), headlights, headlining and arch kit/bumpers.
Everything else has been changed, painted or otherwise buggered about with. And yet, it looks pretty much like a standard Mk3.
I'd say pitted to the post only by Ged McConville's old one.
I'd say kiz's pips both of them tbh, pretty much every thing on it has been modified and he's taken anal to a whole new level 8-)
(Giggles)
Serious face, yes I'd say that's a fair call. Audi TT dashboard for starters...
Pretty much full tt interior too, its not till you see it in person that you realise just how far he's taken it pictures just don't do it justice
in trying to keep mine looming like it came from a showroom and not just crashed thro halfords a lot of my mods are hard to see. in how the arches are flared yet look stock, and the wings sculpted to take the rallye headlights are just a couple of things a lot of people will miss. I've written a spec sheet and to be fair no 1 will read it because its simply to long. it dwarfs the one posted above and is at least double its length. truth of the pudding is in the eating- come and have a look round mine at the poloshow and see for yourselves what I've done. you will come and look, see things.... then come back and see things you never spotted first time.
as for anal Mclovin.... i simply cant argue. only proper anal people colour code cv joints.
Id say Youngprodigys does win it, but Guys mk3 took lowering to a whole new level, as well as a 1.4 16v running standard managment. Oh and creating the the new "Veedub" craze of hanging rabbits heads off towing eyes :lol:
Have you still got a picture guy?
Edited by mattpolo5491
i own half of it lol :-D wish we had the key for the petrol cap then could make a bit more progress running wise
done some work freshening the engine bay and got plans for a porsche interior...
yer because i showed him! lol
those at the poloshow must concur that my car was the most ridiculously modified polo out there!
  • 3 years later...
Where could you buy body kits for a vw polo mk 2 cl 1.3 1993?
Nobody will beat mine
- Polo 6R hubcaps
- Heko wind-deflectors
- Cheap Sony head-unit
Yeah thats right. Be afraid. :D
