Replacement rubber door seals
Hi there,
also wondering if it is possible to get replacements for the seals around door aperture? It's a 4dr 97R 1.4CL, and there's ben a problem with water trickling in under drivers door, which I reckon is down to badly crushed/pinched rubber seal not doing its job properly in that area. Anyone experienced this?
There seem to be lots of generic aftermarket P-section seals that might do the job, but would obviously prefer to replace with correct part that should fit more easily!
Thanks in advance.
  • Views 711
