Single 15" BBS RX2
Hello,
I've a single wheel for sale - built up using spares from a refurbished set of 6. The rim has 3 heli-coils in and the center had to be filed around a bolt hole by about 1mm, all due to the bolt heads snapping off when I split the wheels. I have partly refurbished the wheel to make it presentable, however as this was the most corroded rim of those I had it is not in amazing condition. The rim is polished however evidence of the corrosion remains as seen in the pictures. The center has been touched up only, and the inside of the rim was sanded (not to bare metal) before being primed, painted in VW Reflex Silver and lacquered. Again, although presentable it is by no means a perfect finish. I would be happy to have this wheel on our Polo GTI should one of them become damaged, however I do not need 2 spares taking up space so I have to sell it. Collection from Gateshead please, £40 or £45 with the grey center and a couple of spare bolts included.
Thanks,
Antony
079633122592
MORE PICTURES HERE
Edited by Swalsey
  • Views 228
