F/S - Kenwood, KDC-BT30 - Mp3/iPod/Bluetooth headunit. BRAND NEW
Ok so due to buying a different headunit, this one is for sale.....I think I bought it around christmas time from caraudiosecurity. It hasnt been used AT ALL, completely brand new......taken out of the box once just to check its all there etc.
Kenwood: KDC-BT30
Spec....
•Bluetooth Car Stereo with Aux Input on front panel for iPod/iPhone or portable MP3 player
•Key Features:
•Bluetooth with handsfree profile built-in
•Microphone integrated in front panel
•MP3, WMA & AAC files playback
•Illuminated front AUX input
•Remote sensor for optional IR remote control unit
•General Features
•DIN Size: 1 DIN
•Detachable Faceplate
•Protection Case For Faceplate (Soft Case)
•Key Illumination Red
•Rotary Encoder & Control Knob
•Music Search function
•Attenuator with Smooth Volume Return: only by optional IR remote controller
•Touch Sensor Tone
•Optional IR remote controller: KCA-RC405
•Digital Clock (24H) Yes
•All-off Select (20/40/60 minutes) Yes
•Built-in Connector: Molex 16 pin
•ISO connector
•Bluetooth unit built-in
•Display Features
•Display Type: Fluorescent (FL) Tube Display
•Display Layout: 13 segments x 11 Characters
•Dimmer Control: 2 steps - Manual
•Demo Mode
•Special Character Display Russian Characters
•Cosmetics features
•Front/edge: Black Injection
•Dress plate: Piano Black
•Volume & operation knob: Chrome Plated
•Preset key finish: Piano Black
•Escutcheon finish: Black Injection
•Triangle Illumination: Red
•Volume & operation knob: illumination Red
•Key illumination: Red
•Tuner Features
•Radio Data System
•Radio Text
•Program Type Function (PTY)
•FM Reception
•AM (MW/LW) Reception
•Presets 24 Presets (18FM / 3LW / 3MW)
•Mixed preset memory (FM & AM) 6 presets
•Automatic Memory Entry (AME)
•Up/Down Seek Tuning
•Tuning mode (Auto1 / Auto2 / Manual)
•FM Stereo / Mono Selector
•CD Features
•CD-R/RW Compatible
•MP3 Playback with ID3 Tag Display
•WMA (Windows Media Audio) Playback
•AAC (Advanced Audio Coding) Playback
•CD Text Support
•Supreme
•D.A.C. processing 24 bit
•0 bit Mute
•Random Function (Track/Disc)
•Repeat Function (Track/Disc)
•Scan Function (Track/Disc)
•Audio Features
•Maximum Output Power 50W x 4
•MOSFET Power IC
•Auxiliary input: Front mini-jack
•Pre-out: 1 RCA
•Pre-out Output Level 2V
•Preout Rear / Subwoofer Switchable
•Subwoofer Reference Level Adj.
•Source Tone Control & Memory: Bass / Mid / Treble
•Balance/Fader Control
•Att.(-20dB) with smooth Volume Return
•System Q (Preset Sound Control)
•Bass Boost Circuit
•Low-pass Filter
•Connectivity
•OEM Wired Remote Control
•Power Control (P.CON) wire
•2-way (Tel/Navi) mute wire
•Bluetooth General Features
•CAS Technology
•Hands free Profile (HPF)
•Serial Port Profile (SPP)
•Headset Profile (HSP)
•Phonebook Access Profile (PBAP)
•Phone numbers hold: up to 1000 per registered phone.
•Object Push Profile (OPP)
•Synchronization Profile (SYNC)
•Short Message Service (SMS): reading only
•Phone device status display
•Signal strength display
•Remaining battery display
•Bluetooth phones to register: 5
•High-quality noise canceling microphone: built-in
•Bluetooth firmware upgradeable
•depends on phone model/make
•Audio Specifications
•Maximum Power 50W x 4
•Output Power (DIN45324,+B=14.4v) 30W x 4
•Preout Level 2000mV / 10kOhm,
•Preout Impedance ≤ 600Ohm
•Speaker Impedance 4Ohm ~ 8Ohm
•AUX Frequency Response 20Hz ~ 20kHz (±1dB)
•AUX Maximum Input Voltage 1200mV
•AUX Input Impedance 10kOhm
•Bass Tone Control 100Hz ±8dB
•Middle Tone Control 1kHz ±8dB
•Treble Tone Control 10kHz ±8dB
Kenwood’s KDC-BT30 is the first in Kenwood's range of Bluetooth hands-free solutions. Your phonebook list is displayed for selection and previous call logs can also be used. In coming caller number or name is also displayed before you allow connection. Mobile MP3 players such as iPods can easily be connected via an illuminated front audio input socket (AUX). A cool blue display gives easy visibility even in sunny conditions. A high power 4x50watt built-in power amplifier will fill your car with high quality sound from any source.
All still boxed exactly how it would come from caraudiosecurity etc...
Selling dude to upgrading to a double-din
I paid £134.99, it is now down to £94.99 seen here http://caraudiosecur...s_id/13944.html
I would like £90.00 POSTED ono, or cheaper collected from Taunton, Somerset
I will also throw in an Aux cable for ipods etc
Pete
  • Views 172
