Ford Capri 1.6
I recently picked up a mk3 1.6 Calypso Capri but due to some work changes my finacial sitution has changed so i need the space and cash.
Its a 1.6 Calypso, 33K miles genuine by looking at the service history. Its in a 2 tone blue and silver/grey.
Interior is mint and blue/grey.
Has near enough a years MOT and tax until November.
I paid 1500 for it a month ago and drove it the 3 hour trip home fine only issues I've found is the passenger door probably needs replacing as its the only bit hit by bad rust. The heator motor needs replacing and a small dent in the rear which should pull out fine.
The other problem is at low revvs it can cut out if your not careful, a local garage suspect it just needs the carb taking apart and cleaning but i do not have the time to get this done myself. As i said, its still drivable just needs a little more work. Great rolling resto project for someone with time.
as i said i paid 1500 just a month ago, so would take 1400 or a sensible offer.
I'm based in Bradford so not far at all.
Pictures can be seen here.
http://s84.photobucket.com/albums/k2/ropayy/Capri/
You can text me on 07783332381 or email on nic.w.roper@gmail.com
Cheers, Nic.
Edited by RopAyy
  • Views 262
