Polo 6N Open Air - Fixing/Replacing the roof
Yes, I did searching a lot. :) There is lots of good advices like how to replace or refurbish roof lining, how to get a new roof lining if old is damaged (also - does normal one fit to my Open Air if cutted? Yes.) and also that the Roof is actually Webasto 400 model which can be ordered from Webasto or carhood.com for about 200£...
Anyway - my problem seems to be unanswered. My Open Air seems to miss something from the lining. There is just a hole before the roof mecanism and the lining is just hanging there. It is just attached to the roof with anything around the sun roof hole. Can someone please send me a detail photo from inside of Open Air so I can see how the lining should be attached to the roof around the hole.
--- EDIT : I will answer this to myself, because I think that this might help someone else also... ---
Now I have the part numbers for the roof and image.
1 6N0875101B fabric sliding roof cover outer 1
6N0875101B 6DE schwarz
2 6N0875503 roof lining with bows 1
6N0875503 Y44 pearl grey
3 6N0875241 gasket 3892MM 1
4 6N0875481 guide piece left 2
6N0875482 guide piece right 2
6 6N0875387 glide piece front 2
7 6N0875417 sliding shoe left rear 1
6N0875418 sliding shoe right rear 1
8 hexagon nut, self-locking
9 6N0875031A frame 1
10 N 90644801 torx socket fillister hd. bolt M5X9-CH 2
11 6N0875945A clamping frame 1
12 6K0875491 torx socket fillister head screw, self-locking M5X11,5 24
13 6N0875227 beading 3580MM 1
6N0875227 X09 pearl grey
14 6N0875445 covering 2
15 6X0875125 spoiler 1
6X0875125 GRU primed
16 6X0875127 protective foil 1
6X0875127 908 transparent
17 N 01100517 hexagonal nut M5 5
17A N 0116653 washer 5,3X15X1,6 5
18 6X0875841C cover for electric drive 1
6X0875841C Y20 pearl grey
20 see illustration: 959-10 (Which I dont have. :D )
21 N 10045703 countersunk bolt M5X25 2
22 6N0875243 gasket 1
23 357877439 spring plate 1
24 6N0875442 covering 1
25 6N0875383 guide tube 5
Edited by Lanttu42
  • Views 4.8k
