Some people just dont get the whole low thing!
if i ever meet you - ill buy you a pint, or 5, as you amuse me
Ill crack out the jester hat and jokes for a few pints if thats all it takes!
  • Replies 112
  • Views 7.7k
nah, youre not my type xx
When 'lowering' a car, it's not the fact that the car body is lower to the ground that is the problem. This is ideal as the C of G is closer to the ground and you get less lateral weight transfer which improves cornering. The higher spring rates of most 'adjustable coilover kits' cause the tyre to lose compliance with the road when going over normal road irregularities, which is bad if it happens during a corner. The bonus of this higher spring rate is the car rolls less which means when 'turning in' the car takes less time to settle into the corner, and it generally makes the car more responsive to steering inputs. It also generally feels better for the driver in my opinion.
If you had the car 'low' but standard springs on, it would corner better except for the fact that the chassis is likely to scrape on the ground really badly under braking, cornering or going over bumps. If you put a set of adjustable coilovers with higher spring rates and different damping but racked up to their highest setting at standard ride height, you'd still get a shit ride.
As previously mentioned, when the car is lowered the wheel locating links (wishbones) won't be at their ideal angles, which could give it some static negative camber on the front, but to be honest I would say that helps the car when cornering as the car rolls with a loss of braking effectiveness.
Oh and also, everyone keeps going on about 'handling'. I think the correct term people should be using is 'cornering' or 'grip', handling is the ability to control the vehicle and is very different. No modern cars handle badly as far as I'm aware, because all manufacturers manage to get it mostly right through all the experiments with vehicle dynamics in the '50s. I know that sounds really anal, but if you're going to use the terms, they probably should be used correctly.
Stupidly low, to me, is anything more than 60mm. (i also think wheels that stick out, and stretched tyres are stupid) I like the look of some cars with serious lows and stretch/ poke, but wouldnt own one. My mk3 was cornering like a boat, leaning onto its door handles at standard height. Thats the reason i bought a lowering kit, to get rid of the body roll, not because it looks better (thats just a bonus). I had it 60mm all round, but it was scraping its exhaust on bumps, i couldnt drive across fields very well, and i was constantly worrying about damaging the car, and if their would be bumps where i was going. All lowering did initially was make me parnoid about ripping the exhaust off.
I've actually raised it at the back now so it sits 60-40 which is plenty low enough. A good compromise between cornering and ride quality.
i come from a family of vw nuts so they all love it, dont ever really get any comments apart from the lower the better lol, and when i do get some gimp say anything i just say "whats your hobby?"....they reply "football, why" "well i dont get football, wheres the sense in running round like a tw@ chasing a ball, your not a dog are you?"....that usually shuts them up lol
Why would you want to drive across fields?
he's right about modern cars "handling" well, obviously it can be improved, they hve to balance comfort, regulations and such...when you alter it to improve one, you usually compromise another! I have mine low because I like how it looks, even raising it like 20mm I don't think it looks good, that's mainly because of the whole stancing thing is in my head now lol.
My 6n drove pretty well standard, it just rolled around a lot, putting anti roll bars on would have improved it massively.
Majority of race circuits and nice and flat lacking massive bumps in corners unlike roads, being low/stiff on the roads can be dangerous if your going fast, a little bump on a corner could fuck you right up.
Setting up the suspension on an f1 car is simpler than on a road car.
lmao
Lmao...there's less to play with that's all I meant :)
I'm the opposite, my daily is low as fuck because i couldn't care less.
The blue one when its done, will be more performance orientated, although it will still be low for shows when i can be fucked to adjust coilies.
I go low because it looks sick. To an extent, the lower the better.
Yup! I mean, I drive what is essentialy a granny wagen (6n).. so it may as well be on its arse. Its by no means dangerous, its just, I cant get over ANY road fault :|
And when people say being low is a hinder to handeling..nonsence, The garage I go to for setting up my tracking have awards for their race cars they build, they know what their doing - The guy was telling me most garages dont have a clue when it comes to alignment with lowered cars as its not an exact science, even with a 6n theres a right and a wrong way of doing it, its one of the most important factors when it comes to handeling.
I'm down about 85 - 90mm, their is zero arch gap, yet it honestly handles like a dream (for what it is) no understeer whatsoever (if driven properly).. and its mostly to do with the combination of ride hieght/allignment! and I'm on PhilJ coillies.. work that one out.
of corse its an exact sience, its called geometry! do the maths,get the rewards!
^^correct, you have been duped, you can't set up a car for use on the road in the exact same way as a race car due to quality of road surface.
Mags are full of 500bhp turbo'd cars that have had £1,000's spent on them. Yet the speed limit is still 70mph. You aren't legally allowed to go over that and a 1ltr will cruise at 70 easily, yet people still try to follow them and create these over-powered cars. Same thing about consumerism too, if this wasn't the case then why would these companies be selling 'performance' parts for 1ltr cars, knowing full well that there won't be any gains (and they even go as far as to promise 10bhp gains that in fact make small engined cars go even slower). They lie there, if there wasnt a big 'scene' of modders making it 'popular', companies must laugh so much when they sell more 'performance' parts for smaller engines cars than to cars that will actually gain anything from the product.
What I'm getting at is that these people saying that kids are stupid for lowering cars, it's only made for track cars blah blah blah. The same goes to performance, you can't physically use the power legally, so why do it.
All of this said, yes I will lower my car because I like the way that it looks and yes I will bolt on these mods to make my car that little bit faster, even if I never use the power. And I like a challenge and I'd love to build a fast car that is usually considered slow.
People can say what they want and preach as much 'truth' as they like, but people will still do it, it's just personal opinion. And if you are against it so much just think 'hey, at least that's not me' and continue your day to day life instead of criticising people. And personally I feel that if you have a problem with modified cars then why join a forum that is primarily 'modified' cars.
It's not down to you to tell people what to do and not to do to their cars, just let people do as they please and enjoy the outcome.
*disclaimer - this is not aimed at anybody in particular before people try to get all up in arms about a post*
Actually doing 70 in a 1.0l isnt very efficient, the engine struggles a little to stay there.
And to be honest I've lowered every car I've had, it does just fuck the car tbh, so many things have to be taken into consideration. But I'm not a fast driver so I'm not that bothered :)
