1.4 8v SE with 1.4 16v AFH conversion
http://www.pistonheads.com/sales/3216320.htm
I am selling a 1997 P reg Polo, the engine has covered around 90k miles and the gearbox has covered 155000. The car is registered on the log book as a 1.4 8v SE but has the 1.4 16v AFH conversion and a full stainless steel scorpion exhaust system. The car is running and drives fine, no MOT and no tax because I was going to use it for the engine conversion into my polo. The SE edition comes with standard Black seats which are all in good condition except the passengers has a small tear on the gearstick side, the black dashboard and door cars, although these have been cut to house some speakers which the car had in it, I am looking for around £600 for the whole car with the full body kit, which does need some attention and the 5 spoke 15" alloys with legal tyres all round.
Good bits:
-1.4 16v AFH engine running at around 100bhp
-Full stainless steel scorpion exhaust system
-service history from 79000, when the engine conversion was done
Bad bits:
-Bodykit needs some attention especially on the side skirts as they have started to crack, should be a cheap fix
-small rust hole under rear passenger side light, again a cheap fix if you would just fill/ weld a new piece of metal in
-dents in wing on passenger side from the previous owner lifting the car to jack it up
-very small rust patches around the rear arches, typical of this age Polo
-Gearbox has done 155000 miles, although it doesn't grind in any of the gears
call or text 07584568537 for more information
  • Views 210
