Polo 16v Turbo 158 Bhp 173 Lb-ft Torque
The dta ecu such a better unit so thought why not. I shall try get a vid up soon of a 0-60 run
  • Replies 227
  • Views 34.3k
Woop progress :) get that boost upped!!
definatly potential for more with that setup! thats not far off a well specc-d 16v n/a spec :p come on lads, go go go haha. Naa ona serious note, bet its great fin to drive :D
once those new rings are properly bedded in I'm sure you'll break 200.
How much boost you intend on running? Seeing this should be built strong you should get 250hp easayy
Taking it back up jdm dyno in a few weeks once I have done 1000 miles to get the boost turned up to about 10 psi should see me near 200bhp but first I need bigger injectors as the ones that are in now Are near there limit! They are 6n2 gti injectors! What other injectors should swap right over? Do the 20v injectors fit?
G60 maybe?
Yeah g60 injectors check your other thread I posted on there
Don't suppose i could steal some megasquirt knowledge from you could i?
Just need to know how what pins you used for wiring the throttle position sensor
cheers bud
Pics up soon!!!!!!!!!!!!!
Edited by DANZ_16VT
I'll just leave these here for you Dan ;)
Cheers bland.
Hope you all like will be at edition and action for all to see and ask questions.
Hope you like!!
Dan
So come on, whats that manifold off :p looks shexual!
Top secret but I can supply if anyone interested!!
Whats the spec on these piston /rods??
I need a set...
You can supply a manifold? naa thanks, getting one myself when i go turbo. Just curious to know what that one of yours is off :-)
how much can you supply one of these manifolds for then is it just a stainless 20vt one with the flange changed to suit the valver and what turbo is that your going to run now
anychance i can have some info on the pistons your running price and where from please as i may need to get some at some point
Sick yeah! Rev it! Haha
It won't let me watch it
Fuck that sounds good!
you have any idea what that flashing handbrake light means ?
I've got it on my 20vt conversion and i think its due to taking the ABS off..
is there an abs plug? is or open circuit or closed? if so open it or close it and see what happens, if it goes off all is well ;)
I've taken everything related to the abs off
wiring
pump
sensors
everything :lol:
