Mk3 handling?
i found my previous TT's limit..shortly after i rolled into a field :lol:
  • Replies 47
  • Views 3.6k
Also do not buy 195/45/14 falken tyres. They were garbage.
Agreed on the subframe comment, but tyres...Whats wrong with them? Better alternatives in that price range?
So rolling into a field is with a TTs limits but once you try to move on the grass it's game over? :lol:.
I quite like the fact the inside wheel seems to have no interest what so ever in gripping in tight bends even in the dry :lol:
So true, its terrible round roundabouts! but quite fun on country lanes i find, can be very fun to drive. and better than a few cars I've driven!
After driving with a stage3 subframe for 3 years jumping into my sisters mk2 was truly terrifying :lol: and even more so when you forget there is no servo. :lol::lol::lol:
Someone said about Corsa B's, Saxo's to the same thing, tight bends were fine but sometime on a slight open bend......"oh Fuck!!!" *Cue facing back the way I came* :lol:
Yep, but powering out of a roundabout with your front wheels still facing as if to got round it is a skill :lol:
my mk3 handled mega, philj shocks and springs with g40 rear beam still had a little body roll and you could always tell when it was going to understeer/oversteer was pretty good around the roundabouts in MK just a shame it was just a 1.3cl so was down on speed big time. i did find it squatted on its arse alot though!!!!
is it worth fitting a gt/g40 rear beam would you say? i have a 1.3 cl (it is an NZ though so it has 1000% more power :lol: ) and my mate has a gt beam lying around somewhere but i don't know if i can justify swapping it or not yet, as it will take some effort
They're a polo for fuck sake lol,
But in my opinion, my coupe handles very well, granted its got a stage 2 subframe (any front brace will do)
Aftermarket shocks, -80mm lowering springs, custom anti-roll bar mounts, custom glass filled nylon arb + tca arm bushes and a custom rear anti roll bar :lol:
lol, there pretty wank tbf.
until you start fitting subframes and polybushes atleast.
Its not that much effort to fit a GT rear beam. 4 bolts, brake lines and handbrake cable. And then the brakes if your swapping them over.
do it in an hour if you know what your doing.
Was gonna say, unless you're adding a least a stage 2 subframe and polybush/ Gladerseite blocks then it'll be pretty rubbish :lol:
Mk5's aren't much better, even with coilovers, understeer like a bitch :lol:
I'm the same as Enthuiast, except with a scirocco, it handled pretty well on stock suspension, its like its on rails with coilovers but it scares me as still not found its limit!
doesn't sound too bad but i need to get somewhere where i (my dad really :roll: ) could do it first, and finding a day when i could do it, and i've had the handbrake cable changed recently and had the brakes done, so its all going to removed again, but if it is worth doing i will :)
I honestly don't think subframes and poly/nylon bushes are the main essential.
The best things for me are the custom ARB blocks, rear ARB and lowering Ofcourse.
mmmm u want my beam eh? lol
maybe :ninja:
its definitely a lot down to what condition the suspensions in too, in theory my mk1 golf should handle a lot better than my old mk3 polo, (both just on coilovers and wider wheels) but with the polo, i knew where i stood with it. with my mk1, it just feels so floaty and doesnt seem to be much response when you turn the wheel coz my suspensions fucked. i do chuck the golf about every now and then but i used to give my polo hell and trusted it a lot more
I just found them to be bad in the wet and the dry on my G40. Crap in the wet and even in the dry just didn't feel all that confident on them. I prefer toyos even though they don't last quite as long and aren't that great in the wet. Although I didn't drive the G40 very hard in the wet so that didn't matter too much (170bhp made it a bit of a scary experience in the moist). Had them in 195/40/16 flavour too and they were just gash. Swapped to 15" wheels with 195/45/15 toyos and the car was a different vehicle and so much more a pleasure to drive.
Don't know what else to try, Uniroyal rainsports? Toyos come in that size too. Could even move to 185/50/14 tyres to widen the possibility with yoko and continental tyres being available in that size.
Edited by demolover
I'm rolling on continental sport contact 2's at 195/45r15 :-)
custom rear arb... you fitted it then? ;)
Yeah, right before I took it off the road for the winter :lol:
I mounted it like yours i think dude, coupled with all the other stuff i've done, awesome!
They do handle well with a few tweaks- subframe essential, stops chassis leg cracking and you can't go anywhere near sticky tyres without one.
Rear ARB makes things twitchy, there's so little weight in the back of a Polo, and with most of the time on track spent on 3 wheels, there's little merit in one (imo).
My car chasing down a Porsche Carrera 4S, and a Lotus Exige (Lotus on track rubber too):
http://www.youtube.com/user/yooftuning?ble...u/1/dACtgBkLgVs
That's also enough lateral G to put the oil buzzer on, on an anti-clockwise circuit ;)
Yoof
majority of cars are designed to understeer by manufacturer...this is so anyone driving can realise they're not going the way they're turning, and its easier to correct than a sudden rush of oversteer, by at which point little old granny is already backwards with cars piling into her before she could even react to it
The Mk3 Polo is a turd in the handling stakes. You can polish the turd with subframes, arb tweaks, coil overs etc but at the end of the day you're left with a polished turd. Any modern car will out handle it and plenty of older cars too. There are worse though....which is a frightening thought.
Its one of the worst handling cars I've ever driven - even worse than a micra - but it is incredibly comfy and sees off speed bumps which is nice after my board hard primera which hanldes nearly as well as an alfa
