scott aspect 45 2010 model bike
Got this bike back in 2010 for going to work and back and recently stopped using it due to getting my coupe so now for sale. The bike does have a little bit of cosmetic damage due to a slippery path i went down, the cosmetic damage is pictured below.
here is the spec of the bike;
It is the Great componentry of the Scott Aspect 45 2010 Mountain Bike which tends to make it so popular, it consists of a New Frame Alloy 6061 Performance geometry, Rock Shox Recon SL Pop loc lockout / Rebound adjustable 100 mm travel Forks and XT Gearing.
Frame:New Frame Alloy 6061 Performance geometry
Fork:Sun tour XCR with Lockout 100mm travel
Front Derailleur:Shimano Acera
Rear Derailleur:Shimano Alivio
Shifters:Shimano SL-M 360 EZ-fire plus
Chain set:Shimano FC-M361, silver
Chain rings:44/32/22 Teeth
Bottom Bracket:Shimano BB-UN 26
Cassette:Shimano CS-HG30-8l 11-30Teeth
Chain:KMC Z-72Pedals:Xerama SP-910-S
Front Brake:Tektro Auriga Comp
Rear Brake:Tektro Auriga Comp
Brake Levers:Tektro Auriga Comp
Handlebars:Scott Aspect OS 620mm, black, 31,8mm
Stem:Scott JD-ST66 (OS 31,8mm)
Rims:Rigida ZAC 19 SL D-Wall, black
Front Hub:Scott Disc Team
Rear Hub:Shimano FH-M475 Disc
Spokes:15 G, stainless, black
Front Tyre:Schwalbe Black Jack 26 x 2.1 50TPI
Rear Tyre:Schwalbe Black Jack 26 x 2.1 50TPI
Seat post:Scott HL SP-238 / 31.6mm
The bike is located in Runcorn WA7, can be picked up Monday to Friday from 4pm onwards.
The bike is now listed on ebay - Ebay
Price - £350 could consider a swap depends what you got.
Cosmetic damage
Edited by pascoe92
  • Views 319
