1.3 spi in mk2 1.0
Hi guys
I have found a 1.3 I am intrested in buying, its a 1.3 spi. I'm planning to run a weber carb
All I will get is the block head, and inlet and out let. What parts can I use from my original engine? Starter etc. Current engine is a a 1.0 hz.
Just wondering if this is a straight swap, any thing I should know about when doing the swap? Just a bit worrid it will give problems ad the new engine was injection but my old engine is carb. Guess I will need a facet pump?
Kyle
  • Views 450
