Top mount movement. 6N
Right, recently lowered my 6N on TA technix, which can i say are far more comfier than raceland!
Anyway, one i lowered it, i had to get my camber adjusted, because it was at -3.00! When it should of been -0.25
After that, when i was driving home, and i turned, i heard a little noise coming from under the bonnet. So just now i turned my wheel full lock, looked under the bonnet, and my top mounts looked at an angle, so i could see under them slightly. Is this because my camber is adjusted, or is it just fucked somehow?!
Also while on the subject, i'm getting 10MM spacers for the front, and 15MM spacers for the rear, any one help with what wheel nuts i'll need? Cheers in advance :D
  • Views 444
